Question about Canon PowerShot A560 Digital Camera
Lens cover won't close and there is internal dust
I have dirt inside my Canon A560 and want to clean it myself. Is there any website that can guide me in this process?
  • Canon Master
  • 4,738 Answers
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it: 1) Try blowing compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible. 2) Gently slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degres to clear out any debris that may be in there. 3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work (keeping in mind that it usually does), it then may be necessary to open the lens barrel to access the lens cover mechanism.
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Posted on Apr 18, 2009
On our panasonic DMC - SZ6, the lense cover won't open when turned on
Lens covers are delicate things. A bit of dust or dirt inside and the the springs can't do their job. When cleaning doesn't work, to repair this I remove the lens cover and shorten the springs by cutting off a bit and then reattaching them. A small bit of mollyd to lubricate helps too. never use oil or silicone.
Oct 31, 2017 | Panasonic Lumix DMC-TZ3 Digital Camera
My camera powershot A560 .... lens error !!
The lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre.
get estimate before you decide. It will be good to have it checked at the Canon service as you do not have to run around for spares.
May 28, 2011 | Canon PowerShot A560 Digital Camera
I have a Canon Powershot SX130 IS and there is dirt behind the first piece of glass in the lens , anyway to clean it?
You shouldn't try to clean this yourself, find a camera shop that does repair or contact Canon, they will direct you to one in your area.
But before anything you better make sure the dust has any impact on the pictures.
May 07, 2011 | Canon PowerShot SX130 IS Digital Camera
Error 99 on canon 300d
Canon's error 99 is a catch all for several things the short answer is an electronic connection. Something isn't making contact and the first place to go is to the "gold" contacts between the lens and the camera body. Make sure the camera is off and remove the lens, place the camera lens side down on a clean dust/lint free surface or put a body cap on. Take the lens and holding as vertical as possible with the gold contact points down use a soft rubber red pencil eraser to lightly clean the contacts. You can remove any rubber dust and partials with a lens cleaning cloth NOT TISSUE. Make sure the area is clean of lint and dust, place the rear lens cap on or stand the lens up on a clean dust and lint free surface. the camera is a bit more tricky as you need to clean the contacts inside the mirror box. Hold the camera as best you can face down and again use the pencil eraser to lightly clean the contacts. Holding the camera as mus as possible lens side down. This will minimize any dust, dirt or lint getting into the camera body and eventually ending up on the sensor. Remove any rubber dust with a lens cloth not tissue and don't use any liquid, don't use a puffer either all that will do is drive dust partials into the camera. Once that's done install the lens, next remove the battery and do the same cleaning trick with the battery contacts, if you have a battery grip do the same thing. Okay now check out the camera if everything is go and works then you are good to go. If not then I would suggest doing a camera firmware update, all updates can be found on the Canon web site they are free and will correct any issues your camera has with the internal programming which may also be the cause of your error 99.
Jan 11, 2011 | Canon Digital Rebel / EOS-300D Digital...
Lens stuck open position
you can try a couple of things genltly twist the lens one way until you hear a sound,turn off and try powering up again,also particles of dust or dirts can become cloged of lodged in the gears that move the lens, this may cause the lens to stuck,try blowing the area between the lens barrel and the camera body to remove some dust and dirts. hope this helps
Jan 03, 2010 | Canon PowerShot A560 Digital Camera
Lens cover will not open
easy fix. yo turn it on and then very lightly tap the lens cover or push it out. then you should clean the lens because the dirt or dust on the lens is stopping the lens cover.
Aug 24, 2009 | Canon PowerShot A530 Digital Camera
Cleaning dust and dirt from the lens (inside)
Hi Nutty Prof
You will have to open up the unit by unscrewing the screws at the bottom and taking off the top cover of your PB6100.
Right behind the lens is the Lightengine ( where the dust collects )
Take off the cover of the Lightengine by unscrewing the two screws at the top of it . Then blow out the inside of the light engine with Air in a can ( available from most good PC shops )
and then reassemble.
If the dust particles still show after this ( which I doubt it will ) then you will have to take it to a Service Centre to get cleaned out as you will not be able to reassemble the lens once taken apart - it is a HUGE job !
Thanks for using Fixya and Good Luck !
May 24, 2008 | BenQ PB6100 Multimedia Projector
Canon SD600 lens jam
I followed the directions contained in http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/ and by disassembling the camera and turning the rotor just a little bit (page 4 of the instructions), it freed up the lens and it is now working perfectly! The camera had been put down on the lens as the lens was retracting and I assume that jammed the retract mechanism. While the camera was open, I blew out whatever dust/dirt was there (didn't see much). The fix took me probably 20-30 minutes, and I am very pleased with myself!
Oct 24, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot A560 Digital Camera Logo
491 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
