Question about Dryers
Is a10' dryer cord safe?
Is a 10' dryer cord safe?
  • 31 Answers
So long its UL approved and designed for appliance use.
Posted on Apr 16, 2009
I have a hp radeon r6, 10 amd a10-7300 i cant boot up, tried to install win 10 aniversery update screen turned blue with sideways face, now i cant boot up
As it tries to boot, press F8 and choose safe mode. Go back to before you tried to update to win10 by using the restore point.
Nov 19, 2016 | HP Computers & Internet
I plugged in my dryer chord to see if it fit and the metal pieces were touching and a poof sound occurred and they got burned a lil bit. Are they still good and safe
This does not sound like the cord is going to still be good.
The problem is that it MIGHT work, but you could lack a ground circuit due to the damage you mentioned. THEN YOU RISK ELECTROCUTION. Get a qualified appliance guy to replace the cord for you.
Incorrectly done, you can actually electrify the case around the appliance. Not good.
Be safe.
Feb 05, 2014 | Dryers
Kenmore Dryer Model #11060932990 Proper grounding when changing 4 prong cord to 3 prong.
According to the National Electric Code, you will need to install a grounding strap from the frame to neutral in a 4- to 3-wire conversion.
Jan 18, 2014 | Kenmore Dryers
Dryer is flipping breaker after 10 minutes into dry cycle.
You have a weak circuit breaker . Should be a 30 amp or higher . If you have access to an amp meter , split the dryer cord , separating the 3 wires (do not remove the insulation ) . If you have a black round cord ( 4 prong ) , carefully slice into and remove the black insulation in a small portion only . Check the amps on both outer wires while running dryer . Make sure the amps being pulled are lower than the circuit breaker amps . On a black cord , test the black wire and the red wire amps . If the dryer has a short , it would not run for 10 min and then throw breaker . It would be almost imediate . A bad breaker will gradually get hot and then flip , but check the dryer amps anyway to be sure .
Aug 15, 2009 | Estate TEDX640JQ Electric Dryer
240v circuit wiring to run my new Dayton Heater (3Vu34A)
On the 40 amp breaker, you should be using 8-3 w/ground. 10-3 w/ground will work on the 30 amp breaker. 12-3 w/ground is used for 20 amp circuits. Your new heater should have the electrical requirements listed in the user/installation information.
Jan 29, 2009 | Dayton 3VU34 Heater
Wireing an a/c plug to a samsung DV316LES dryer I have Black, White, and Red wires coming out of the dryer. the plug I purchased came with Black, White, and Solid Green wires. I am sure it goes color to...
unless you have an a/c outlet close to your dryer the you wont be able to use an a/c cord. also the cord for an a/c i usually rated for 20 amps and your dryer needs to have a 30 amp circuit.
i would not suggest using this cord as it will overheat and probably cause a fire in your house.
if you think the cord can handle 30 amps, then you need to make sure you hook up red and black to the power sides, white to the neutral and green to ground.
seriously, just go back and get a dryer cord that will match the outlet that is close to your dryer.
draw a picture of what the outlet looks like, ie: the position and angle of the plug slots and go back to the hardware store and find the right cord.
it will work properly and be safe to use.
Jan 07, 2009 | Dryers
Sub won't power up
DVD reset procedure for TH-A10
1. Make sure there is no Disc in the tray.
2. Disconnect the power cord.
3. While Pressing "Stop" and "Open/Close" buttons together reconnect the power cord
4. Front display will show "TEST0".
5. Then the display will change to : "TEST1 JC2".
6. Press "Enter" button on the remote, display will show "EEPROM"
7. Press "Power" to shut unit off.
8. Reset is finished
Nov 16, 2008 | JVC TH-A10 System
The power is out because of Hurricane Gustav. I have a 6500 watt portable generator and would like to use our clothes dryer which has a 220 volt requirement. Is that possible, and is there a special...
Dryers require a 40A circuit breaker to handle the current. According to Ohms Law: Watts = Volts * Amps. Therefore, you require a power capacity of 220V * 40A in order to safely run the dryer, which is 8800 Watts. This means your generator does not have enough capacity to run the dryer. If we consider the full power of your generator at 6500 Watts, this only allows for 29.5A, which is not enough to run your dryer.
If it WAS possible, you would need to ensure that you ran a 30A heavy extension cord with the correct 220V plugs and receptacles on the end. This would require at least 10gauge 3-conductor wire, which is quite expensive.
However, that point is moot, since your generator does not have the capacity to run your dryer. You could try it, but I rather suspect that the dryer will trip the 30A breaker on the genset circuit. If you do try it, make sure you run a 10-gauge, 30A extension cord or you could have a fire.
Sep 06, 2008 | Dryers
Won't Turn On
Try reseting the system. Instructions below.
Jun 01, 2008 | JVC TH-A10 System
Dryers Logo
83 people viewed this question
Top Dryers Experts
