Scangear error 2,252,0
I ahve a brand new LIDE 200. software seemed to load fine. When i click on "Scan" I get error "2,252,0","can;t read or write file". help, please!
  • keithreddy Apr 25, 2009
    I have the same scanner and the same problem, but if I use Microsoft Publisher and insert photo using scanner it works perfectly.
    I have asked Canon to help, but it screams software problem to me.
    What is My SQL and what has that got to do with it?
    Keith
I had the same problem. Spent hours on the phone with canon.Problem went away then came back twice. Then I found this solution which works: http://forums.techguy.org/hardware/820712-code-2-252-0-solution.html
Posted on May 05, 2009
  • 1,006 Answers
It can be:
1) Cable is damanged
2) Bugs Problem
3)My SQL is not installed correctlly
Posted on Apr 16, 2009
Can't copy or scan on canoscan lide 25
You need to install the software drivers You need BOTH programs installed on your PC, Toolbox & Scangear. Also use the driver remover first. Then unplug scanner, reboot, install Scangear first, and toolbox second, then reboot, when at desktop next time, plug in the Scanner. Hopefully it should be all good. Read the Help file. http://software.canon-europe.com/products/0010219.asp
Feb 17, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
Canoscan Lide 20/lide30 Ver. 1.02 Will not load in my Mac 10.4.11 Tiger.Had it in my previous vergin mac 10.2 but since I've upgraded scanner tells me I've got error .06 and will not reload. I assume I...
http://www.usa.canon.com/consumer/controller;topic=609.msg7369?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=104&modelid=6624#DownloadDetailAct
Mac OS X (Native Mode)
  1. Turn the computer on. Log in as the first created administrator account to install the software. You cannot install the software when logged in using added administrator accounts.
  2. Place the CanoScan Setup Utility CD-ROM in the drive.
  3. Double-click the CD-ROM icon.
  4. Double-click the MacOS X folder/icon.
  5. Note: Some versions of the CanoScan Setup CD-ROM will not include the Mac OS X version of Toolbox. If this is the case, you should download and install Toolbox from Canon's website. www.canontechsupport.com
    If you will not be installing Toolbox at this time, skip to step 7.
    Double-click the CanoScan Toolbox folder/icon.
  6. Double-click the CanoScan Toolbox Installer icon. Follow the on-screen prompts to complete the installation.
  7. Once the installation of Toolbox is complete, you should then access the ScanGear CS folder also located in the MacOS X folder.
  8. From the ScanGear CS folder, click the ScanGear CS Installer icon. The installer will search for available install locations for the scanner plug-in driver. Follow the on-screen message prompts to complete the installation.
Jun 18, 2009 | Computers & Internet
Canon ScanGear CS driver error Code: 2,252,0 - Can't preview Actually I have the Canon CanoScan LiDE 80 Flatbed Scanner - but this wasn't presented as an option, so I thought I'd try the nearest...
Canon ScanGear CS driver error Code: 2,252,0. Error when trying to Preview scan using ScanGear in your program, e.g. Word, PhotoShop...
I had the same problem, Canon Technical were clueless on this error code. Yes the problem occured when trying to preview first however I could scan but without any preview, pointless really.
I have fixed it for Windows Xp SP3, Canon Lide 80. To Fix:
You need to download the latest ScanGear driver and Deldrv.exe from the canon website. You don't need the Toolbox, http://software.canon-europe.com/
It would help if you have Tuneup 2009 (even Trail version) for the later parts of this fix: http://www.tune-up.com/download/ just click download, you don't need to give them your email address.
1. Save these on C:
2. Remove the USB cable from your scanner - make sure it is unplugged.
3. Run Deldrv.exe, select your scanner and uninstall.
4. Now you will need to go into 'C:/WINDOWS/TWAIN_32' folder; you must remove anything in this folder - safest thing to do is CUT any items and paste them on the C: or personal folder.
5. Now the register parts - you need to purge your registry of any left over values. I found out after several attempts that this final step fixed the problem for me.
Basically through Windows XP Regedit or TuneUp Reg Editor search the ENTIRE registry for first 'ScanGear', second, 'Canon' and third if you have installed previously, 'Canon Toolbox'. Find any entries relating to any Canon scanner software and delete them. I only found around 6 or 7 entries to remove.
6. If you have TuneUp run '1-Click maintence' (correct problems) and afterwards run the 'Register defragger'. Restart.
7. On the next bootup your register should be optimised. Ok, disable any Anti-virus software.
8. Run the scangear setup winzip file you saved on C:. * it will extract a folder to C:. If get an error with the extraction, try running it anywhere else except C drive. Alternatively if you have WinRar, right click and manual extract contents. The scangear setup winzip file/folder (called lide80vst7250a_xpen) only contained a readme and setupSG.exe.
9. You must run the setupSG inside this folder. And you're done. Enable your anti-virus.
9. Now connect USB to scanner, Windows should pick it up. Open Word or PhotoShop > run the scangear program to preview.
10. Done! It worked my end.
Please let me know if this helped you.
Mar 14, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Re: CanoScan LIDE 30 on Mac OS X (Version 10.5.6)
I was able to install the CanoScan Toolbox by doing the following: MacIntosh HD --> Library --> CFMSupport --> Get Info. Under 'Sharing & Permissions', I added my name & changed 'Read only' to 'Read & Write' .
Problem now: I can't install the LIDE 30 Scanner Driver. I clicked on the downloaded driver & a box opened. I clicked on ScanGear CS Installer, but that didn't work. I then clicked on 'Into Plug-In' --> ScanGear CS 7.0X --> Choose Application --> CanoScan Toolbox 4.1 --> Plug-Ins, but couldn't continue as the 'Open' tab was greyed out. What should I try? Any suggestions would be appreciated.
Feb 27, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Out of Focus Scans
You have some limited color adjustment settings in ScanGear that you can play around with. I would recommend recalibrating the scanner. This is done in ScanGear Advanced mode under Image Settings.
May 28, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Canon scanner
TWAIN is the type of scanner driver that is used for this scanner. It is probably the most common type of scanning driver.
Did you install Toolbox? Not sure? Assuming this is Windows, click Start, All Programs, Canon. Look for open CanoScan Toolbox (4.9 I think). Once this is open, click the 'Settings' button. There should be a drop-down menu for 'Select Scanner'. Make sure this shows the CanoScan LiDE 25. If that scanner is not listed, then the scanner driver is not being seen or may not be installed.
Once it has been verified that the LiDE 25 is selected, click OK. Next, click the 'Save' button. Check the box for 'Display the Scanner Driver'. Now click the 'Scan' button at the bottom.
The next window that pops up should be ScanGear. If this happens, then everything is installed and the scanner is being detected properly. Attempt to scan or preview.
If there was a particular application you were trying to use and you are still having issues with it, please give those details.
May 19, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
CanoScan LiDE 50, error code:2,7,0
When you say the error occurs as soon as you press "Scan", is that the button on the scanner, or is it the Scan button inside of Toolbox or ScanGear?
If it is the one on the scanner, try accessing the driver through an application such as Toolbox. If you didn't download that when you got the driver, then go back to the Canon download page and download & install the CanoScan Toolbox. Once that's installed, lauch Toolbox from Start|All Programs|Canon|....look for Toolbox from here. Once you have Toolbox open, click the 'Save' option. Next, check the box that indicates to Use the scanner driver. Click the Scan button at the bottom. This should open ScanGear. Attempt to Preview scan.
May 11, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
CanoScan LiDE 50 error code: 2,7,0
Has your scanner been working before?
If so, has anything changed since then such as new printers or other devices added to the computer, or upgraded to a new OS?
Which OS are you using?
When exactly does the error occur?
Does ScanGear open?
Are you able to preview?
Try connecting the USB cable to another port on the computer (directly to the computer...not through a HUB or any other device). Bypassing a hub, which would have to be a powered HUB, or other devices would rule out any issues with those devices.
Ultimately trying the scanner on another computer would rule out issues with the scanner as well.
May 09, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Halftone setting won't stay locked.
in scanner software there is 2 types od system come
one is defolt
other one is coustm
go in coustm chage che reslution make it 100, 200, ......,1200 dpi
Feb 02, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
2,357 people viewed this question
k24674
jasbo
jasbo
