Question about Sony KP-53S65 53" Rear Projection Television
Double vision on my samsung HDTV 1080i
Hi, My TV is approx. 3 years old and just recently started to show double vision. It started when I moved it from up stairs bedroom to my living room and approx. a week later it started to double vision. Did the move cause the problem or how can i fix it? Thank you
  • 1 more comment
  • sharondah Dec 23, 2007
    my tv is showing double vision. How do i fix it?
  • Anonymous Jan 05, 2008
    same problem
  • Anonymous May 09, 2009
    I only have double vision when there are bright colors on the screen, pinks, reds, and oranges. Any dark colors and the tv appears normal. Solutions?
  • Sony Master
  • 8,617 Answers
Replace the convergence ICs. you will need two of them. They are located on a large aluminum heat sink with STK numbers. They cost about 10.00 each. They need to be soldered in. Its an easy repair if you can solder. Let me know if you need any additional info.
Posted on Jan 24, 2008
2 Suggested Answers
  • 87 Answers
SOURCE: Double vision on my samsung HDTV 1080i
If one or more of the colors, red, green or blue have separated from each other and you can`t correct the problem using the convergence procedure as described in the users manual, that would indicate you have a convergence problem. Bad solder connections on the convergence output chips are common. If the set had a rough ride down the stairs while moving, that may have facilitated in exposing a preexisting condition. However, the most likely cause is the natural failure of one of the convergence output chips and or related components and not the move. The fix is to have a qualified technician address the problem. This is not a do it yourself job.
Posted on Feb 22, 2008
How much should i charge for painting a two bedroom apt. Inteior only. walls and cealing two bath one living room kitchen and laundry room
About 50 cents a square foot would be a reasonable price for a straightforward paint job (no stairs, cathedral ceilings or furniture to move).
May 28, 2014 | Measuring Tools & Sensors
We recently moved the tv and now when we turn it on it has double vision. It kinda looks like a 3d movie. What could be the issue? Is it worth fixing?
If tv picture was fine before moved then check dry/ cold solder joints/ connections on convergence output ICs and nearby circuit area.
Local tv repairman will resolder loose/ dry solder connections to solve double vision picture problem.
TV worth fixing if picture is good.
Thanks.
Feb 18, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
Can't pick up channels itv, channel4/5 and itv2 on my bedroom freeview tv and down stairs doesn't pick up film4 and a few others?? I have only recently connected the bedroom aerial to the ariel which was...
hi when fitting an new aerial line you need to put a splitter in the line.
4963215_1-oo4k03phwtyaxld0gomgkgbv-2-0.jpg it looks like this. they say satellite/tv on them this will stop interference from the boosters and the tvs on the same line, you connect it on the main arial line. you can then use both boosters if signal is weak but most digital aerials are good enough without them. it you have the right arial for your area. there are meany sizes. but say you are 15 miles from your tower then use a small aerial has the same fitting as this pic. that is out side aerials, inside aerials ie in loft you need a high gain aerial , long type. hope this helps. also if the aerial is not lined up it will not get great signal there is an app you can use on iphone or androids, tables etc to help you position the aerial in the right place it's called Uk aerial alignment . tool on app shows you the towers in your area and the best ones to use and shows you the aliment to the tower for best results. good luck
Jun 22, 2017 | Samsung LE40R74BDX 40 in. LCD Television
Free 2-3 year old rca prjctn tv needing convrgnc chip
I had this problem with my Proj. tv also it cost me $135. to have the convergence chip replaced. i would call a tv tech. to get the true cost.
Sep 19, 2009 | RCA P46920BL 46" Rear Projection...
My RCA projection TV is showing double vision
You can get the STK730-130 convergence IC at the following link which should take care of that issue. Its 24.00
http://servicemanuals.vstore.ca/product_info.php/pName/stk730130/cName/convergence-ics
Jul 12, 2009 | RCA P52920BL 52" Rear Projection...
I am seeing double vision on my television.
I do not know your TV's model number, if your TV is a 3D television, please turn the 3D function off in the system menu.
Jul 01, 2017 | Sony Televison & Video
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
any repair shop can re converge the tv for you.id do some calling arond and get a few quotes to see what it would cost to have them come to you
Oct 09, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Feb 22, 2008 | Televison & Video
Picture looks fine in middle but the sides doubles
zenith 55" projection tv. approx 8yrs old.
the right half of picture is normal the left half of picture is blurry or shows double or triple vision.
Feb 13, 2008 | Televison & Video
Sony KP-53S65 53" Rear Projection Television Logo
1,395 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
