Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Printing is very weak and difficult to read even though I changed and put a new cartridge in the printer It is a Lexmark X215
    Scholar:
  • 103 Answers
The resolution on a monitor is 72 dots per inch. The resolution on paper is about 300 dots per inch. What looks good on a screen often looks bad in print. The picture you are printing is probably saved at a resolution which looks good on the screen but not on paper.
are you using the right quality paper and are the printing settings adjusted correctly? If your printer is set for photo quality paper and you are using plain paper or vice verse, you wont get good results.
*please clean cartridges with the automatic system.
*Tried auto alignment setting
*Try to clean nozzles of cartridges by humid (wet) fabrics.
please try all the steps for the problem to be solved.
Posted on Apr 16, 2009
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
start
control panel
printer and fax
right click your printer, choose properties
go tab by tab and look for print quality and then try
something like this
choose econo mode, or ink saving mode to start.
try to print in grayscale mode and use only the black ink cartridge.
that should be your new default, and you don~t have to change it from winthin other programs
Mar 30, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
LIGHT PRINTING ON LEXMARK X215 I'VE CHANGED THE TONER BUT THE PROBLEM PERSIST
Please check the driver properties and make sure that the printer is not set for "Draft" mode.
Don
Mar 02, 2009 | Lexmark X215 MFP All-In-One Laser Printer
Poor printing
Gain new cartridges, possible that application time ended in yours.
Mar 01, 2009 | Lexmark X4270 All-In-One InkJet Printer
Toner Empty
it it was receiving fax before replacing the toner then it still should be able to receive so just turn your printer once off and turn it back then see what happens.
if problem still remains then please post back.
and rate all answers.
Feb 11, 2009 | Lexmark X215 MFP All-In-One Laser Printer
Lexmark X125 not printing at all.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | Lexmark X125 All-In-One InkJet Printer
My lexmark X1185 all in one printer will not print color.
did you make sure that you pulled all of the tape off the bottom of the cartridge. next recheck your settings. they will not return to normal themselfs
Jun 09, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Printer doesn't print even with new ink cartridges.
Take out the Cartridge & get a new one if the problem persists then get the printer software reinstalled & if still it is not printing then clean up the cartridge head with cotton swabs dipped in hot water!
This should clean the head & black will be on paper
DO THIS AS FINAL REFUGE
If still its not working then there's some problem in the copper contact surface in the printer on the cradle so get a new Printer.
Mar 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
Printer cartridge missing
Hi does the message read insert print cartridge or close door? Are the any numeric messages on the control panel?
Nov 28, 2007 | Lexmark Optra S 2450 Laser Printer
Change all ink message
Your Lexmark cartridges may be like my HP ones--they have a chip that the machine reads so they cannot be reused without doing some tricks to fool the printer.
My HP remembers the last 2 or 3 cartridges and also will not use ones that have passed the expiration date that is stamped on the cartridge. I'll tell you what worked for my HP.
Check the date on your ink cartridge.  I bet it has expired. If you put in a "new"cartridge but it is even an HP one with an older date, it may not work.
I had my printer stop in the middle of a print job.  It was printing fine and suddenly would not print.  So I refilled the cartridge with an ink kit I had on hand and reinserted it--no go!  Then I opened a remanufactured cartridge I had bought some time ago and inserted it.  No go, despite the fact I could see ink coming from the jets.  I finally gave up and bought a new HP ink cartridge, and it worked just fine.  But it bugged me why the new one would work and the other two that seemed just fine would not.
Later I learned that HP has a chip that reads the expiration date on the cartridges and that is what keeps those old ones from printing.  I found one trick of setting my date on my computer back to a year earlier than the exp date on the cartridge.  I saw the date on the remanufactured one I had tried earlier was 2005, so I set my computer date to today date but year 2004.  After forcing me to do print alignments several times and take the remanufactured cartridge out and put it back, I got it to print just fine.  And that 2005 cartridge that would not work earlier is what I am printing with right now.
Be advised, though, if you try the date setback, that HP printer will buck and try every way to not let you use that old cartridge.  You must say no to reflashing if HP tries to pull that on you.  And you will take out and put back that same cartridge multiple times and keep printing alignment sheets 3 or 4 times before you are successful.  But, if you persist, you can get it to work.
Oct 25, 2007 | Lexmark X63 InkJet Printer
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
107 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
