Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore Elite 75212 fridge doesnt cool off
Freezer part works great but the fridge part on top does not, wondering what im looking at to troubleshoot besides dampers if anything else.
  • ap0gee Sep 16, 2007
    I have removed the top thermostat, to access the back air vent, no breeze. Wonder if a fan is suppose to be pushing that cold air up. It hasnt been run in over a year, and it just got plugged in about two hours ago. Still not a chill up top.
  • 770 Answers
Well there is a diffrence between no air flow and not cooling is the freezer working?? We can go from there
Posted on Jan 25, 2008
SOURCE:
Kenmore 795 freezer on top. Freezer working, temp lights on in fridge, but fridge not cooling and lamp out as well.
If the freezer is located above the fridge, the air from the freezer drops into the fridge to create the cooling in the fridge. So what I would look for is a blocked vent from the freezer to the fridge, which is usually located on the top and or back of the fridge inside of cores. You can get a frost or ice build up in there and block the air flow to the fridge, that is usuall the problem. I would also heck the dial for temp control in the fridge, I know my kids have changed it before on me.
Sep 07, 2012 | Kenmore Refrigerators
Kenmore elite refrigerator is not cooling, but the freezer seems to be working fine.
Kenmore Elite refrigerators come in several styles, including units with a freezer at the top and units with freezers at the bottom. The top and bottom of the fridge work on different systems. Sometimes the freezer may function perfectly, while the fridge performs poorly. Most issues with the fridge cooling are due to incorrect settings or poor cleaning practices. Checking common problems with the refrigerator will help you diagnose the situation and keep expensive repairs to a minimum
1. Check that the Kenmore Elite refrigerator is plugged in. Inspect the circuit breaker of the home if the refrigerator is plugged in but not running.
2. Pull the unit out from the wall and vacuum the condenser coils at the back of the unit.
3. Turn the temperature control in the Kenmore Elite refrigerator to the "On" position.
4. Turn up the temperature on the temperature control, located inside the unit on the wall.
5. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the Kenmore Elite fridge door.
6. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the fridge door.
7. Move food away from the vents inside the Kenmore Elite refrigerator.
I hope i solve you problem.
Have a nice day : )
Sep 04, 2011 | Refrigerators
Kenmore refrigerator top works but bottom doesnt get cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 08, 2010 | Kenmore 64802 Top Freezer Refrigerator
Fridge not working properly on kenmore bottom freezer model 596.7
I have a similar problem, although I have no cooling in the fridge section. Had a repair man indicate that the electrical panal(pcb board) needs to be replaced. It is on order ($200). Sure hope that is the issue. To me, it appeared that the freezer fan(which cools the fridge) was not working. Whether that is the result of a faulty electrical panal is yet to be determined. Good luck!
Aug 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge not cooling freezer works fine?
hi im andy from ac refrigeration in south africa ur fridge is short of gas
Jul 29, 2009 | Refrigerators
Top fridge not cooling enough bottom freezer works
Have you tried changing the setting/temperature controls on the fridge? If it is under warranty you may want to have a technician take a look at it.
Jun 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge stops working when power goes out.
It sounds like maybe the freezer fan is coming back on ??? Do you hear it in freezer?? I would recommend having it looked at ----this definately doesnt sound normal.
Jan 16, 2008 | Kenmore Elite 21082
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
371 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
