Question about Emerson EWC1303 13 in. TV/VCR Combo
CASSETTE STUCK IN VCR WONT EJECT I TURN VCR ON IT STAYS
ON FOR A FEW SECONDS THEN TURNS OFF....I HAD TO GET THE TAPE OUT AND IT STILL SHOWS THAT IT HAS A TAPE IN IT.... VHS is stuck in Emerson TV equipped with VHS deck. Will not eject, when we turn this on the instrument turns off. Appears lodged in lower part of deck.
    Scholar:
  • 136 Answers
VHS cassette players usually have a switch or switches that start the playback or "tape in" features. When the tape is placed in the carriage, it activates these switches . The little motors start to run and pull the cassette cartridge in.
The "tape in" light comes on. The tape pushes in, then down.. and the switch is on.
In your case it seems that the cassette cartridge may , as you said (I just noticed ) be stuck in the down position. Which means that you probably need a new carriage or carriage basket as it is sometimes called. I fixed VCRs for several years before they became obsolete with the digital DVD players.
You can do this yourself if you are handy with a few tools you will need to disassemble and remove the old carriage and install the new one.
But if you are not a handyman, do not even try it. You must not force anything to remove it . You could end up breaking the frail plastic parts inside.
You can buy a carriage or VCR parts online for almost any kind of tape player nowadays.
Before you install anything the entire rubber items that run the tape and belts that run the motors must be cleaned thoroughly with rubbing alcohol and swabs or cotton balls. The heads must be cleaned using a chamois cloth or a piece of it . Using cotton to clean the heads is not recommended because they could clog up the heads which are tiny.
They are located on the very shiny spinning drum that you see immediately when you open up the cassette. Or in your case the entire TV chassis.
I recommend you send it for repairs and not take chances on doing more damage to it. But it is your choice. If you do , be sure to do everything without power until you are finished.
it can be done using common sense and being careful. But that is entirely up to you. Bottom line is you need a new carriage and a total cleaning of the unit.
Posted on Mar 12, 2014
    Genius:
  • 1,605 Answers
Turn on the machine. use your figure push on the cassette, when you feel the cassette can't go any farther (don't jam it),and hold it there. press the eject button, you may have to try this couple of times in order for the cassette to come out.
the cassette deck need to have the drive belt change.
Posted on Apr 16, 2009
Cassette is stuck. Cannot eject
Sounds like the tape is dragging and the spindle wont release it because of the torque on it. Can you rewind or fast forward to see if it releases?
Sep 09, 2012 | Samsung DVD-V4600 DVD Player/VCR
Toshiba VCR
Check this link it has some solutions that you can try in removing the tape inside the VCR http://www.fixer.com/no-eject.html
Hope that helps...........
Sep 12, 2008 | Televison & Video
VCR tape was hung in Sylvania SRDV495. Got the
You need the aligniament the eject gears to tape gears.Please remove the cover platen and the rear cover(bottom) and align the gears manually.Obturated the sensors hole and insert the cassette.Verify the eject and the tape belts.If you have knowlwdge VCRs the problems solved in 1 hour.
Aug 21, 2009 | Sylvania Televison & Video
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
When the tape has been removed the carriage deck will still be in the wrong position. The cassette tray has to be aligned so that the timing of the tape will detect that there is a tape in the machine. At the moment your VCR thinks there is a tape still in it because the cassette tray is not in the full eject position. This can be fixed by a service technician.
Mar 26, 2009 | Emerson EWV401 S-VHS VCR
VCR ejects blank tape only
It sounds like the cassette is not releasing the tape so the machine can put it around the heads. This could damage the machine. Don't use it. A two dollar tape is not worth damaging your vcr. Throw it away.
Oct 09, 2008 | GE Televison & Video
My Tv is turning off by itself
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Cassette stuck in VCR
You are almost on the right track. did you look where your finger was? what happened was you did not allow the blocking a photo sensor which mimicked the clear part of the tape and this caused the eject to take place. What was happening in your case was the arm would come fully out and the sensor would sense no tape so the VCR shut off in a trouble condition to prevent damage from ocurrin.
Oct 28, 2006 | GPX TVR950 VCR
Emerson EWC1303 13 in. TV/VCR Combo Logo
570 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
