Question about Acer Aspire 5630-6288 Notebook
If i close the laptop it's not get locked ...(physical lock)
Time is also not get upgraded....i think lock spring is gone
Driver's side door latch won't budge once closed. Locked or unlocked the outer handle acts like the door is locked. Any suggestions?
The outer handle has a spring to return it built into the handle I think, so the fact that it returns does not mean it isn't disconnected inside the door. Time for a shop I think (are the replacement switches really $500? Might check with a parts store instead of dealer to see if they can supply that part.)
Jun 30, 2014 | 2001 Isuzu Rodeo
My maytag nepotune high efficiency model MAH550BWW door does not close properly...have to slam the door several times before the latch closes to set and start the wash cycle
There is wear in the door latch/lock mechanism, It will eventually fail completely and you will have to replace the door lock
Mar 12, 2012 | Washing Machines
1994 pontiac sunbird 3.1 L V6...door locking system has gone haywire. I got home, opened the door to the car, and when I tried to close the door, it would not shut. Can I unhook the battery to reset the...
Your door locks will not prevent your doors from closing, you should be able to lock the doors by hand and then close them with no problem. Take a look on the car where the door closes there will be a brass rod, this is your striker, it is what holds the door shut. This striker lines up with a latch in the door, the latch is on a spring and when the door is open it should be up, when the door closes the spring closes the latch around the striker. Check to make sure the latch is up, if it is not the door(when you try to close it) will typically bounce back toward you. If the latch is down you maybe able to take a flat head screw driver or prying device and twist the latch back up, this should allow your door to close. If you open the latch and it immediately closes it will need to be replaced. Hope this gets you on the right track.
Sep 24, 2010 | 1994 Pontiac Sunbird
My driver's door is locked shut.the key works but won't unlock the door it is not the key cylinder i think it is the locking mechanism in the door.how do i get at the panel with the door closed
its a spring that brakes off on the door latch that hooks up to the lock mechanism. it happens all the time, on my car twice. you gotta get any screws you can off door panel and then get tough with it and pull it off. its not easy. but i havent broke mine yet. replace the spring, dont need a whole latch
Aug 26, 2010 | 2004 Kia Rio
I try to close my laptop it's physical lock not working, time not updated
The locking mechanism on your laptop needs to be replaced. Take it to your local repair shop for assistance.
Apr 16, 2009 | Computers & Internet
If i fold my laptop it's not get locked( physical lock)
The lock need to be replaced, contact Acer service center.
Kevin
Apr 16, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Hi, I have a hotpoint aquarius mwa30, the door lock light flashes and/or not at all. I bought a new door interlock but it still does the same but if i link out the 2 wires in white then it tells the washer...
the spring may have gone in the latch on the door.
close the door and push the handle part by hand to move the latch into the lock more firmly.
to replace the spring or handle assembly remove the screws from the back of the door and prise the front off.
Feb 28, 2009 | Hotpoint WMA74 Front Load Washer
I have a 1993 Subaru Legacy. The power door locks dont work. The front passanger and the rear seat doors will not unlock. I have to physically mash in on the lock lever and pull up on the outside latch at...
probably the spring in the door handles on the inside are broken. you can remove the inside handles and fix them byusing a cotter pin to hold the spring in place
Nov 27, 2008 | 1993 Subaru Legacy
Acer Latch is broken
On most notebooks, there is a VERY small return spring (smaller than a spring from a ball point pen) on the latch that tends to break.
Apr 20, 2008 | Acer Aspire 5102WLMi Notebook
Acer Aspire 5630-6288 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
