Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fisher & Paykel GWL10 US won't spin
6 year old Fisher & Paykel GWL10 US won't spin. For awhile, the clothes in the very bottom seemed damper than usual. Yesterday's clothes didn't spin well, now a load today won't spin at all.
  • 9 more comments
  • Linda8 Nov 03, 2007
    Thanks! I did do more reading on others having a similar problem after posting,and after reading the suggestions (as you suggested above), it was fixed!!! Thanks to all of you, you are awesome! It was a cheap towel (from Walmart) that had shredded, and pieces of it were indeed in the pump. Saved us a lot of money with the advice! THANKS!!!
  • DundeeNatal Dec 25, 2007
    Mine won't spin either. I still can't figure out how to disconnect the pump even though the instructions here make sense.
  • stevelock Jan 04, 2008
    I have a gwl10. that is not spinning dry and clothes in the very bottom are wet. I tried to get in fault mode but not sure how. power on I hold the spin up/down button but nothing happens.
  • tbcdl Jul 05, 2008
    My FP fwl10 is not advancing on it's own. It's taking me to advance it to the spin manually. I replace the diverter valve/drain pump in 2005. At that time I got the beeps and the error code. This time no beeps just notice that load was taking forever. I advanced it to the spin zone myself, and it drained then complete the spin cylce on its own. I think it's going to be the main control panel now, which is around $200 part, but wasn't sure if any other suggestions were out there. At least it is still working so I can get my laundry done. Thanks in advance for any suggestions.
  • aquilina6 Aug 09, 2008
    We have a Fisher & Paykel Intuitive washing machine and it will not do the spin cycle.
  • Funkleberry May 18, 2013
    Had the same problem. Removed the pump and found a small piece of plastic from a new collared shirttail restricting the water flow. Thanks for your posts!
    Had the same problem. Removed the pump and found a plastic shirt collar stiffener stopping water flow. Seems to work fine now!
  • Anonymous Mar 15, 2014
    loud noise when spinning
  • Anonymous Mar 20, 2014
    wont spin
  • Anonymous Mar 30, 2014
    does all other operations ok
    smells and stops spinning
    Scholar:
  • 146 Answers
If the machine still has water in it, the drain pump is jammed or there may be an obstrution in one of the hoses. It is most likely the drain pump. Switch off the machine at the wall and unplug it. Tilt machine against a wall and look underneath. On the right you will see the drain pump. It looks upside down. Unplug the wiring harness to the pump and remove pump by turning it clockwise while at the same time releasing the little white clip that holds the pump in place. Clean thoroughly and replace pump.
Posted on Nov 03, 2007
  • 1 more comment
  • amateur11 Jan 21, 2011
    Thank you! Thank you! Thank you! As a single mom with two little boys, a new washing machine was NOT in my budget, especially after the holidays. I followed your advice and found one of my two-year-old's socks twisted and caught in the pump. After putting it all back together, the water drained during the rinse and spin cycle as it is supposed to. Quick, easy, and cheap fix! I can't thank you enough!!!
  • Johnstef Nov 07, 2011
    Thank you guru your advice was spot on I pulled the pump off cleaned it put I back and the machine works perfectly I just saved $200-$300 thanks to you fisher
  • msq1
    msq1 Nov 19, 2012
    Thank you, found a tooth pick !
    New Friend:
Ihave a [email protected] 7.5kg washing machine that I ?? overloaded now the machine won't fully agigate , the water keeps flowing in @ not switching off at programed level, programm does not always run full cycle , just beeps , spin cycle works if buttons pushed "to spin cycle ," PLEASEES HELP
Posted on Aug 30, 2011
Thanks! This information was very helpful in avoiding a service call for my Fisher & Paykel GWL10. Mine had a twist that lead to a simpler solution - others may experience the same problem. Symptoms were the same - clothes were still saturated with water. Seemed they either weren't spinning or water wasn't draining. No diagnostic codes, but, when I tried to manually run the pump, it just hummed. Followed the instructions to remove the pump and check for obstructions. First, I had to remove the display console, top, basket, agitator - all just to get the gallon of water out of the bottom. In the end, I could have done this by just siphoning most of the water out. When I finally got the water out of the tub, I tipped the washer up to get at the pump. I look at the drain pump - low and behold, a dryer sheet is all wrapped up around the exposed fan blade of the pump. Really tied up in there. It must have fallen out of some bundle of laundry and blown under the washer. I dislodged that and the motor spun freely. Once I put everything back together, the washer worked fine. Point is, see if you can get a look at the pump before you take the unit apart. Maybe you'll get lucky like I did and find an obstruction outside the pump.
Posted on Mar 26, 2010
  • jt777 Apr 16, 2011
    This worked for me also had a cloth stuck, just removed it put it all back the same, now it works a treat, any house wife could do this!
    New Friend:
We have gwl 15 and tub will not drain.. using info we found here, we bailed out the water, tilted the machine back, located the pump and studied its mounting.
removed hoses..no blockage.. removed pump.. (turing CCW) and releasing the white clip.. FOUND EYE GLASS CLEANING RAG IN THE PUMP. remove cleaning rag, reinstalled hoses and pump..ALL WORKS GREAT... THANK YOU.
Ken
Posted on Jun 28, 2012
2 Suggested Answers
SOURCE:
SOURCE: Fisher & Paykel GWL10 US won't spin
Buy an new one and trash this one
Posted on Sep 13, 2008
IWL16 leaves black specs on clothes
there could be something stuck in the machine between the two bowls. lifting the lid, removing the ring, agitator and inner bowl will easily check this. if the machine has become loud on spin, and the leak is actually from the bottom (more likely) then it could need seals and bearings replaced. don't run it too much more while leaking, electricity and water don't mix XD
Nov 10, 2013 | Fisher Paykel EcoSmart GWL15
I have a 10 year old Fisher & Paykel GWL10 washing machine. Fault code 1 is coming up. The machine turns completely off. The longer it cools down, the longer it goes before turning off again. This...
Code 1 - usually means on the later models of Fisher & Paykel is a faulty Motor Control Module, often though one would have to replace both as well as the display module.
Anyway - it sounds like the electronics are overheating hence the intermittent problems you are experiencing.
May 27, 2011 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel GWL10 begins to spin for about 15 to 20 seconds, just starts to pick up some speed, then machine beeps and shuts down. Seems like the water is draining. Any ideas? It has also been...
Yes it does seem like a control module fault.Bit concerned about the noise coming from the machine even thou it is not running.Please turn it off at the power point when not in use.Now if and when it faults again please reply back with error code as per 1st posting.
Jun 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a fisher paykel GWL10 washing machine. It shuts off while
At this stage i can suggest that the inlet valve may be faulty & giving off this burning smell.open the control box & see if one of the 2 inlet valves look distorted or brown or burnt looking.I'm wondering if it's not filling very fast also,this could also be an indication of the valve.
Jun 03, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel GWL10 US spin cycle issue
check out another website. ths.gardenweb.com/forum/laundry for other fix it tips on FPaykel.
Oct 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Sep 13, 2008 | Washing Machines
its possible that the pump is either going bad or there is somethin gin the pumps/sump assy. on this model the unit generally tends to shut down when the pump overheats, and will only restart when the pump cools off, a warnig obout replaing hte pump if need be is the pump is actually 220v. you MUST UNPLUG MACHINE BEFORE SERVICING. its a foriegn brand remember so theres abuncha wierd wiring and the pump is one of them!
Mar 25, 2008 | Fisher and Paykel IWL12 Top Load Washer
Washing Machines Logo
7,667 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
