Question about SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive
Song files donn't STAY in iTunes
When I unplug my Simpletech 160GB, the songs don't play in iTunes. I get the exclamation point saying "would you like to locate files." How can I solve this?
  • 59 Answers
The songs are located on your Simpletech drive. You have to move them to your music folder and then specify where the library is in iTunes. If you do have music in your music folder, then on XP, after you have iTunes open, go to Edit -> Preferences. Click on Advanced, and then change the library location.
Posted on Apr 16, 2009
It will not play a song it doesnt play instead just keeps changing songs. How do i fix this
If the file is corrupt, then it will skip until it finds one that it can play. I had this on some songs I ripped from a scratched up CD. At a certain point, the files are not clear enough for the iPod/iTunes, and will be skipped. This can also happen if you've unplugged without ejecting the iPod first while you were transferring music. I would recommend either playing a different song, or if it is doing it to all of them, put the iPod into DFU mode. You should be able to google that and have no problem with it. It will wipe your iPod, however.
Nov 17, 2012 | Apple iPod 4th Generation MP3 Player
Everytime i try to put a song from my iTunes onto my iPod touch an error pops up saying there is an internal error in my iPod, or it says it cannot put the song on my iPod. Also when i try to play the song...
There are some mp3 songs that you can add to the iTunes Library but not to the iPod
This is a format issue i believe
if this its your case you should try to get again the mp3 or burn it from th CD again an then try to upload to the iPod
Mar 31, 2011 | Apple iPod touch Second Gen (8 GB,...
I have iPod Nano 2Gb . If I play music each 10sec music stop and start new song. I can not arrive to eliminate this mistake.
This worked for me.
1. Locate the actual song file. You can check this in iTunes, use the 'Get info' command, in the summary tab, there's a 'where' item at the bottom. Mentally note that this is 'file#1'.
2. Once you've find the file, make a copy of this file in some other folder. Or maybe even on the desktop. Mentally note that this is 'file#2', which is a copy of 'file#1'. Do not rename.
3. Go to iTunes, and delete the problematic song. If iTunes ask to remove the file, click 'yes'. If iTunes doesn't ask, manually remove the file from the original folder. You are removing 'file#1'.
4. Once this is done, move back the copied file, ie 'file#2', to location where 'file#1' was.
5. Add the song back into iTunes. iTunes will treat it as a new song. You will lose some data like Rating or Play Count. You might need to add some details like track number and so on.
6. Sync your iPod. Done.
You have to do this steps to every problematic song. Tedious, yes. But it's better than the need to re-encode the files.
Mar 28, 2011 | Apple iPod nano
Computer and ipod
The exclamation mark next to a title in iTunes means that iTunes cannot locate the song associated with that title (original file cannot be found). The cause for this is an incorrect setting of iTunes preferences when copying iPod songs.
Before copying your iPod songs, setup your iTunes preferences as follows
  • Open iTunes preferences (in the Edit menu)
  • Select the Advanced tab.
  • Make sure the box next to "Copy files to iTunes Music folder when adding to library" is checked.
  • Click OK.
Then use a program like TouchCopy to copy your iPod music to iTunes. You can download TouchCopy from here
http://www.wideanglesoftware.com/touchcopy/
Mar 13, 2010 | Apple iPod classic MP3 Player
IPOD NANO SONGS ARENT WORKING!!!
Test the songs that are not playing on the iPod in iTunes and see if the original file is still playable on iTunes if the song still plays re-sync your iPod could be when iTunes copied the song it must have failed or timed out, if that fails re-syncing try restoring you iPod Nano i have had this problem before and I just re-synced and it worked fine!
Aug 26, 2009 | Apple iPod nano
What is the exclamation icon next to each song in library?
the files arent in the same place they were on your computer. delete all of the files in itunes and search for the files on your computer then drag them into your library again.
Jun 16, 2009 | Apple iPod MA446LL/A MP3 Player
I have 2 problems both mac related Problem 1 I have been using Parallels on my Imac for some time. And have not been happy with it. So I decided to switch to VM Fusionware. I installed VM...
Wow... That is just bad Luck.
Your Files on Itunes are corrupted or just not there. i'm not sure how. your LaCie drive may have had a virus or some other such thing. try loading the files back on to your computer again, and make sure you put the files in the correct folder. one thing that worked for me when my itunes library failed, was when you copy the music files onto your computer, double click the the actual file icon, as if you wanted toplay them. this will tell itunes that the file still exists (and it may also play the song). your Parrellels problem is strange. i think that, like you mentioned, you may have to delete the previous VM installation, so to revert to the one you imported.
Good Luck...
Mar 07, 2009 | Computers & Internet
Ipod Black 80GB
The reason for the exclamation mark is because the song cannot be found.
Delete your itunes library then add the songs again.
you must have m,oved the location on your pc and itunes has lost track of them
Thanks
Ben
Sep 28, 2008 | Apple iPod MA446LL/A MP3 Player
Downloading music files
iTunes might not be able to find a file or folder if:
  • The media files were moved from the iTunes media folder to a different location on your computer or to an external drive.
  • The media files were accidentally deleted from your computer.
  • The network or external drives storing the content are unavailable.
Correct the media file path Use these steps to help iTunes find the media file's correct location:
  1. In iTunes on your Mac or PC, select the song, album, movie, or TV show that has the exclamation point next to it.
  2. From the menu bar at the top of your computer screen or at the top of the iTunes window, choose Edit > Get Info.
  3. When you see a message asking if you want to locate the file, click Locate.
    • If you know the file's location, point iTunes to it and try to play your content.
    • If you don't know the file's location, search for it:
      Mac: Press the Command ? and Space keys on your keyboard, then type the movie title, app, song, album, or artist name.
      Windows: Press the Windows key on your keyboard, then type the movie title, app, song, album, or artist name. If your keyboard doesn't have a Windows key, press the Control (Ctrl) and Escape (Esc) keys on your keyboard.
    • If the file is on an external or network drive, connect to the external drive or network volume.
    • If you find your items in the Trash or Recycle Bin, restore them to their previous location:
      Mac: Control-click or right-click the item and choose Put Back.
      Windows: Right-click the item and choose Restore.
  4. After you recover the file, use Get Info again to locate the file, then point iTunes to the correct location.
Aug 25, 2017 | Sony NW-S705FP (2 GB) MP3 Player
SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive Logo
168 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
