Question about Kenmore 27032
Kenmore wont agitate or spin
At first I noticed a slight clicking sound during wash and spin cycles, but the washer stil performed fine. Today it stopped washing and won't spin. The motor makes a revving sound during both of those cycles. The model # is Kenmore 110.92281800. Thanks to anyone who has a idea of what is wrong.
  • 1 more comment
  • mindurrs Sep 16, 2007
    THANK YOU! THANK YOU! THANK YOU! YOU GUYS SAVED ME MONEY AND TIME - THANK YOU SO MUCH!!
  • Anonymous May 04, 2008
    i need to know how to get the front off of the washing machine
  • Anonymous Mar 26, 2014
    spin cycle wont work
    President:
  • 331 Answers
Mindurrs, your motor coupling has gone to the great beyond. Time for mourning has passed and now it must be replaced. The job takes about an hour and parts run about $10.00, ready? First, go to your local appliance parts retailer and purchase a coupling, part #285753. You'll need this for repairs. UNPLUG THE WASHER!!! Standing in front of the washer, you'll see two screws on either side of the control panel... remove these then flip the control panel over. Now, toward the right side, you'll see a wire harness that plugs into the top of the top panel, disconnect this. Now, on either side of the top panel, you'll see two brass colored clips. Take a screwdriver and poke it into the hole, use it as a pry bar. Pry the handle of the screwdriver toward the wall behind the washer, the clip will pop out. Now tilt the entire cabinet of the washer toward you to about a 45 degree angle then lift it out of there and set it aside out of the way for now. OK, now we're into the guts of the washer... Look below and in the center, you'll see the drain pump (it has 2 big hoses attached). Behind that, you'll see the motor... that's what you'll be taking off. On the right side of the motor, you'll see the electrical connections. Remove the long white one from the motor. (CAUTION!!! THIS NEXT STEP MUST BE DONE, OTHERWISE PERSONAL INJURY MAY RESULT!!!) You'll see a black round thing mounted to the motor on the right hand side, this is the capacitor. It has 2 red wires on it. (It's basically a 120 volt battery that is just waiting for you to touch it so it can shock you, badly) THIS MUST BE DISCHARGED (voltage drained off) BEFORE CONTINUING. Remove the 2 wires using insulated needle nose pliers. Now, discharge the cap by touching both terminals of the cap at the same time with your needle nose pliers. This will discharge the capacitor so it's safe to handle. Now, above and below the motor, you'll see 2 clips mounted on it, remove the screws that keep these clips in place then (with a flat head screwdriver) pry the clips off the motor. The motor and pump will drop out of there. Rotate the whole thing off to the left (with the hoses still attached to the pump). Now you can see the broken coupling (compare the old one and the new one). Pry the old pieces off the motor shaft and the transmission shaft and throw 'em away. Install the new coupling (notice the semi-triangular shape of the inside of the plastic coupling? I use my screwdriver handle... poke the handle into the coupling, place the coupling squarely on the shaft, then tap [don't BANG] it home with a hammer) and rebuild in the reverse order of dis-assembly! Sounds complicated, but it's not. I've done a thousand of these and it took me longer to type this than it would have for me to do it for you! And, for what it's worth, you have a good washer there. It's actually made by Whirlpool, and well worth the repair.
Posted on Sep 16, 2007
    President:
  • 878 Answers
Min, sounds like you broke a motor coupler, This is not that hard of a fix. Part number 285753A. Take a look at number 13 on the pic, you will have to remove the cabinet to get at this thing. The cabinet comes off from the front. The consol flips up, remove the 2 snap springs, unplug the lid switch, remove the pump and motor. Install the new coupler, check the second pic, Catriver. The reason Im not suspecting the lid switch is because it stopped agitating too. Catriver
  • Ron Marek
    Ron Marek Sep 16, 2007
    break down
  • Ron Marek
    cabinet removal
SOURCE:
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Washer won't spin during rinse cycle. agitates fine during was cycle.
The lid switch is probably your culprit. the washer won't spin or drain if the lid switch is defective. Try pushing down on it with a pen or small screwdriver and see if it will spin then. There should be a slight clicking nois when it is activated, although it will sometimes click even though it is not working.
Nov 15, 2010 | Whirlpool LSR5132PQ Top Load Washer
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Agitater does not spin
the transmission needs to be replaced
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore Mod 110 keep spinning
the holes are sapose to be there it filters the lint out.it sounds like you have a bad transmission.
Nov 02, 2008 | Kenmore 24032\24036 Top Load Washer
Thumping/knocking/rattles during wash agitation cycle
Mine is doing the same thing. I opened it up to see what was happening and it was the drive belt tension arm bumping around. Soon, the belt started slipping during the spin cycle. Now it won't spin and the belt starts to smolder from the friction of the drive motor. If you haven't checked your belt, that's a good place to start.
Jun 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 27032 Logo
678 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Paula Hamilton
