Question about ASUS (CD-S520QUIETRACK) Internal 52x CD-ROM Drive
Ad-5540a dvd drive; wxp installs it as a cd drive only
Windows XP loads a cd drive driver only. All of the DVD write features are not available.
  • 1,006 Answers
Install nero...
Posted on Apr 16, 2009
Dear Sir/Madam, I have a Dell notebook with an Optiarc RW AD-5540A DVD player. Now I have "error code 10" = "the device cannot start". How can this be fixed? I am not computer literate, really. thanks....
An error code 10 error occurs when Device Manager can’t start a hardware device. This error is usually caused by corrupted or outdated drivers, so most often the solution is very easy.
  • The first solution to to restart your machine. Some error messages can be caused by a temporary problem.
  • Next, did you just install a new device or Windows update? If you did, this might have caused the problem. Either roll back the driver you installed, or use the System Restore to undo recent Device Manager changes.
  • The most common fix for a Code 10 error is to uninstall and reinstall your device drivers. If it is a USB device device is generating the Code 10 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall.
  • You might also try to update the drivers for your device, if a more current version is available.
  • You can run an update for the Windows Service Pack. There might be a patch available which will solve your error.
  • If none of the above solved your problem, you should take out your DVD drive and test it in another laptop, if possible, or connect it to a desktop computer using a converter.
  • If all of the above solutions don’t fix it, you might need to replace your DVD drive.
To update the DVD drivers, you have to search your computer manufacturer's website for the drivers. However, here's an easy way:
Use this driver scanning tool, which scans your computer for the needed drivers. It has an option to automatically retrieve them for you.
You can download this free tool from here, or directly from this link.
After you have downloaded the above file, double-click on it and follow the simple steps to install it. Then, when it asks if you want to run it, just answer yes. This is easier than manually searching, downloading and installing the drivers.
Hope that helps.
Regards,
Raspal
For Windows XP Driver Files and How-to Resources, visit XPDrivers.
May 03, 2010 | ASUS (CD-S520QUIETRACK) Internal 52x...
I can't use my dvd rw, when i go to perfical gestion i found this message : Optiarc DVD RW AD 5540A ATA Device (code 10), i know that the problem of driver but i don't know how i can to resolve this...
you can update drivers via windows updates. if you go through the control panel, select updates then choose custom, not the express as this won't allow you to choose the hardware updates, then look for the update for your drive. If there is no update for it or it has just been updated, you can go to my computer, right click on the drive and select properties,driver details and roll back the driver to a previous version.
Feb 16, 2010 | ASUS (CD-S520QUIETRACK) Internal 52x...
DVD+/-RW/CD-RW NEC AD-7203S drivers No problem - just simple me need drivers for this device? for installation on other PC, new system not understend this device and ask driver
Windows 2000 & XP & Vista & 7 have "built-in" drivers for *ALL* CD/DVD drives. So, no specific "driver" should be necessary.
What errror-message(s) do you get?
Does Windows ask to connect to the Internet to search for drivers?
Did you permit it to connect?
Jan 02, 2010 | Sony NEC Optiarc AD-7200S DVD-RW Burner
Optiarc DVD+-RW AD-5540A decoder
If you are using windows with anything less than windows vista Home Premium or Windows Vista Ultimate, DVD capabilities are not built in. For example if you using windows XP or vista home basic DVD will not play. You need a decoder. You have a few options. 1. Buy a decoder pack. 2. Download a DVD player software like cyberlink trial version, install it and check how it is functioning for a few days. Buy and install a DVD player software. However, if you upgraded your compuer recently by adding a DVD drive, you may have recieved a Driver CD disk. Check that disk. check whether a trial version of any DVD player software is included. Most chances are there will be one. Once you got everything fine you can call the customer support for the DVD player software and if you are willing to pay, they will provided you with a key or serial number that will change the status of trial version to a fully working version.
Dec 13, 2009 | ASUS (CD-S520QUIETRACK) Internal 52x...
My laptop does not "read" m Optiarc DVD RW AD-5540A ATA . Code 19 Drivers may be missing or corrupted. Please help.
Try going to the device manager and uninstalling the dvd drive, reboot the laptop and windows will recognize the device and reload the frivers for it. It may even ask to go to windows update and search for a fresh driver, allow that and let windows finsh the installation. Reboot and try the device for function.
Sep 29, 2009 | ASUS (CD-S520QUIETRACK) Internal 52x...
Driver
Is this a windows XP or Vista unit? You are getting that because either the driver is still not installed or you have installed an incompatible driver for your CDROM.
Aug 08, 2009 | Sony Optiarc AD-7170S Burner
Windows Media Center cannot detect a video DVD in the DVD-ROM drive, even when I have inserted a DVD into the drive This is the driver installed in my computer: Optiarc DVD RW AD-5540A ATA Device
Unless you use a DVD player software like power dvd or others, you can not watch dvd on your media player. This is a copywrite and license related issue. DVD players are paid players and this is why, microsoft can not include it on windows.
If you are not willing to buy a player now, try vlc media player instad (click here to get ) . Its free ofcource.
Apr 26, 2009 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
Dvd
Dear Sir,
My DVD/CD is not Sony tape,it is Optiarc DVD +RW AD-5540A solved it with uninstall and install its driver.
Best Regards
Oct 14, 2008 | Sony (1-796-293-13) Plug-In Module DVD...
Optiarc DVD RW AD-5540A (Code 39) Device Driver may be missing or corrupted
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Feb 07, 2008 | ASUS (CD-S520QUIETRACK) Internal 52x...
ASUS (CD-S520QUIETRACK) Internal 52x CD-ROM Drive Logo
162 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
