Question about Broan-NuTone N-LS100SE Exhaust Fan Exhaust Fan
I need a manual for a NUTONE MOTOR 86933000. I managed to install the motor but can not install the panel for 2 lights and my manual has vanished. The numbers I can see are: 8663 RP "B" and 8663/8673 Series A for home product. Hope you can help me. Thanks, George McKenzie
    Scholar:
  • 95 Answers
Look under the documents tab and the installation guide is there. https://www.centralvacuumstores.com/item.php?id=5015
Posted on Jul 01, 2009
Five conductors are needed to wire 8663rp does that mean five wires is needed to wire fan?
It's a NuTone household fan.
Five conductors usually means five wires, though for example two of the same may be for the same purpose, 0V eg.
The fan also contains two lights. The control of fan and lighs delends on how you choose to wire it up. -
"?For?separate?control?of?fan,?light,?and night?light?three?wall?switches?are?required.?See?NuTone?Catalog?for?accessory?switches.?For?separate?control?of?fan,?light,?and?night?light,?five?conductors?are?needed?between?the?wall?switch?box?and?the?fan's?junction?box" (p1 of manual, below)
For instructions on wiring see manual for example here NuTone 8663RP Installation Instructions Manual p2
12.February.2015
Feb 12, 2015 | Dryers
Is there a quieter, alternative motor that can be installed in a NuTone 763RLN bathroom fan?
I just installed one of these; the directions were not really helpful, and I'm fairly handy doing these things. Anyway, the 'specs' say this is 2 sones, and mine is pretty quiet. I did have to tighten the acorn nut that is under the light bulb, that holds the light fixture to the rest of the unit pretty tight. My noise was coming from vibration, not the fan 'noise'.
Jun 25, 2012 | Broan-NuTone N-763RLN Combination Light...
My model 8663RP "B"-Unit Combination
It sounds like the fan blade may be loose on the motor shaft. You can purchase a new motor for this fan online.
Look here: http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/S97017705-Motor-Assembly-.php
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=8663rp&Search.x=0&Search.y=0
May 02, 2011 | Broan-NuTone N-8663RP Combination Light...
I have a Nu-tone 8663 RP Combo fan and light. The unit has been a great unit for a good number of years. The fan is shot. Motor bearings I think. How can I get a replacement fan assy. ?
I just ordered a replacement fan motor for this same exhaust fan. I got it from here, http://www.electricmotorwarehouse.com/aosmith/nutone/nutone1.htm
It's this one,
1.2 amps, 115 volts 60hz
1550 RPM; Shaft 1/4" x 1"
Rotation = CCW
3.3" Diameter Motor
2 Mounting Studs Opposite Shaft End
Motor Case Length 1 15/16"
2-Prong 115 Volt plug
For Model 8663RP, 8673RP
8664RP (86933-000)
86933000, JA2B104N, JA2B104
can substitute 99080517
Part # 86933
$43.95
It's on the first page, and the 8th motor on the page at the time of this post. Hope this helps!
Oct 20, 2010 | Broan-NuTone N-8663RP Combination Light...
Fan motor does not work.
The replacement motor is available for that fan model. The NuTone part number is the 0696B00. It can be purchase from these sites:
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=qt100l&Search.x=0&Search.y=0
http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/0696B000-Motor-Assembly.php
http://www.ventingdirect.com/nutone-0696b000-power-unit-assy-packaged/p431404?y=16&term=0696b000&x=41
Jul 24, 2010 | Broan-NuTone QT100L Fan
I am installing a intilitech 7 day in wall timer replacing an old mechanical 12 hr timer. The load is a 1/4hp 2 speed attic fan. The original wiring had hot in hot out of the timer. This has hot in, hot...
Utilitec does not make a 2 speed timer.
http://waterheatertimer.org/Program-wire-Utilitech-LW60419.html
1) One possible option is a timer with NO and NC terminals like Intermatic-Grasslin FM1 series rated 1 HP. This example timer would have the motor running continually on either one speed or the other.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/grasslin/fm1%20series%20time%20switches.ashx
2) Inside a 2-speed motor are two separate windings.
Windings are loops of copper wire that cause the fan motor to rotate.
For 2-speed, each winding has to be connected to a different 'switch.'
For example, like a ceiling fan. You pull the chain once, and electricity flows to one winding. Pull the chain again, and the switch sends electricity to another winding.
3) The following wiring diagram shows ordinary on-off timer connected to 2-speed switch: This is the basic plan for Broan Nutone 2-speed switch timer, which might be the product you are replacing
http://blog.airscapefans.com/wp-content/uploads//timer_option1_1-1024x768.jpg
4) Nutone makes a 2-speed whole house fan timer.
http://www.nutone.com/PDF/InstallGuides/CFS2WHins89777.pdf
5) And open following Broan Nutone manual that show the two spped timer wiring
http://www.nutone.com/PDF/InstallGuides/CFS2ins57169.pdf
Jul 01, 2010 | Intermatic Inc. ST01C Digital In-Wall...
NuTone 8310 :fan motors keep burning up
I was not aware there was a fuse in the unit. This is a Nutone8310 side vent system correct?
Here is the installation sheets.
Its possible it is wired incorrectly. Follow the instructions given by nutone from the link.
Jan 01, 2010 | Broan-NuTone N-769RF Combination Light Fan...
Nutone ls80l motor stopped working
If you remove the motor, which usually isn't to difficult to do. I would recommend plugging it in to one of your electrical outlets to check it. There is a possibility that the wiring is messed up or the plug in the housing went bad. If the motor doesn't work you need a new motor if it does work then you could try replacing the plug in the housing. All these parts are still available.
Here is a motor finder for NuTone motors:
http://www.centralvacuumstores.com/nutone/fan-motor-main.php
Here is the manufacturer you can get parts from them:
http://nutone.com/
Jul 14, 2009 | Broan-NuTone N-LS80L White Polymeric-...
The Fan in my Nutone bathroom light/fan is not working...
It is really easy to change the motor yourself. It is about a 15 minute job. You just need to find your model number and then you can buy the complete motor assembly. https://www.centralvacuumstores.com/model_number_help.php
Mar 28, 2009 | Broan-NuTone N-8663RP Combination Light...
NuTone 9093 Heat-A-Ventlite: Ventilation not working
My guess it will be the motor.That would be the first thing I would do is replace it.
Mar 13, 2009 | Broan-NuTone N-9093CH Combination Heater...
Broan-NuTone N-LS100SE Exhaust Fan Exhaust Fan Logo
290 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
