Question about Pentax DSmobile Path-Through Scanner
DS Mobile 600 scanner won't scan
I just got a DS mobile 600 scanner and it won't feed the paper through. It just makes a loud buzzing sound. The first time I tried it earlier today it was fine but now it will not work. I am certain that there is nothing jammed in the gears.
Any suggestions?
Thanks,
Joel
Joel, I had the same problem as you. After reading design454's solution, I decided to open up the scanner and see what I could see. There are just 4 tiny screws to deal with, so separating the two halves is quite simple.
There's a system of 4 or 5 white plastic gears that revolve the roller. Within 10 seconds of playing with these, I noticed that one of the tiny plastic gear teeth had broken off and was jamming the gears. After I removed the broken tooth, the gears turned smoothly. Screwed the thing back together, and it worked like new! And all it cost me as a $2 precision screwdriver set.
Posted on Jun 23, 2009
  • 2 more comments
  • iragersh Jan 12, 2011
    The advice of undoing the screws worked for me too. Tiny philips head required. Same buzzing sound, not feeding. There was some crud on the teeny white gears. Removed the crud, screwed it back together, it works. Hurray!
  • spouses Mar 17, 2011
    This worked for me. After opening the unit I could see that one of the gears was not quite 'in-line' with its mathing gear...I just needed to push it back ito place. It seems that a sharp drop of the scanned may have caused the problem. Works fine now
  • scinofi Jul 05, 2011
    My problem was exactly the same as spouses. One gear was slightly out of place after the scanner traveled by plane in my suitcase. I opened it up, pushed the gear gently, and was back in business. Thanks for the helpful comments. I was at a loss until I saw these posts.
  • Daniel Hochman Mar 12, 2012
    Can you point me to the $2 set you bought? None of mine fit...
I have 6 of these and there is a white piece of plastic that holds the roller and gears together on the left hand side. I am willing to bet that this piece is cracked allowing just enough play that the gears are binding. I have tried super glue but due to the oil on the parts, I am unable to fix without a complete disassembly. I will post later if I am successful. You might want to look up the "Ambir TravelScan Pro 600" It looks identical and you might find more info with FixYa links there. Good luck.
Posted on Jun 16, 2009
Thanks! Opened the scanner and pushed the gears around with my finger and screwed it back together. I was skeptical but it worked perfectly. Thank you so much!
Posted on Jan 15, 2012
I'm having the same issue, but I can't get any of my precision screwdrivers to fit into the whole or to fit into the screws. Can anyone point me to the correct size/type screwdriver?
Thanks,Daniel
Posted on Mar 12, 2012
How to replace paper feeding kit on DCP 7020
Most likely all you need is to clean the rubber feed rollers. Use alcohol.
Oct 24, 2014 | Brother Industries, Ltd DCP-7020 Laser...
Scansnap S510 does not feed paper
try to check and clean the paper pick rollers
also let me know if the printer is a inkjet or a laserjet printer
Dec 07, 2013 | BenQ Scan to Web 4300U Flatbed Scanner
Ds mobile 600 scanner says no power to scanner
I had this problem too. Unplug USB cable and plug back in.
Jun 26, 2013 | Brother DS-600 DS Mobile Portable Scanner
Documate error 8
Hello.
I am a Support Engineer with Xerox Scanners.
E8 is a Paper Jam error that could be caused by:
- paper crumpling during scan.
- paper is multi-feeding all at once instead of feeding separate.
- scanner continuously tries to feed after paper has fed through.
if the paper is crumpling during the scan, make sure the inside of the scanner is clear of any obstructions. use the paper guides in the ADF tray to keep the paper straight when feeding in.
if the paper is multifeeding while scanning, fan out the pages before inserting them into the scanner. if problem persists, try cleaning the rollers with rubbing alcohol and a lint free cloth.
if scanner tries to continually feed after the paper feeds through, the ADF tray will need to be reseated. open the scanner and remove the ADF tray at the top. line up the 4 keys at the bottom of the tray with the 4 corresponding key slots inside the scanner. push the tray back until it clicks into place.
We also have an extensive support site and knowledgebase at
http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Jan 28, 2013 | Xerox DocuMate 162 Pass-Through Scanner
My Canon P-150 keeps giving me a "double feed" error and won't scan.
Uninstall all drivers and scanning software. Switch off the comp and Scanner, restart the scanner first and then the computer. Then reinstall software again
Jun 07, 2012 | Canon imageFORMULA P-150 Personal Document...
Avision AV121. Won't feed paper.
my scanner AV121 hanged while scanning documents, first from the software then hanged in feeder and wont scan any more?
Jul 31, 2011 | Avision AV 121
I need calibration paper for the DS mobile scanner
Calibration Sheets and Cleaning Kit $2.98 plus shipping.
http://www.opticsplanet.net/pentax-dsmobile-600-calibration-cleaning-kit-206717.html
Jan 22, 2010 | Pentax DSmobile Path-Through Scanner
Hello, I have an HP OfficeJet 7310 all-in-one print/scanner/fax etc. I purchased about two years ago but don't use very often. Yesterday while I was trying to send a fax I received a loud winding-up...
I have same problem! The copy/scan function would feed the orginal from the ADF halfway and instead of making a normal loud feeding noise it made a horriable alarming sound and displayed an error message. To fix it: I waited a day or two and bang the top of the feeder cover with normal force while the original is feeding. It appeared the problem is resolved. I have no idea what the problem is, however I think if this work for few months at a time is fine by me.
Apr 12, 2008 | Office Equipment & Supplies
Scanning problems
There may be some cleaning in the machine that may need to be done. Surfaces may have become caked on with particles and dust causing drag.
Jul 27, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Pentax DSmobile Path-Through Scanner Logo
1,305 people viewed this question
Top Pentax Office Equipment & Supplies Experts
Johnny Massengill
Johnny Massengill
Abdul Mannan
Abdul Mannan
Are you a Pentax Office Equipment and Supply Expert? Answer questions, earn points and help others
