Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Err f13 on ples399ecf frigidaire stove when bake is selected
Skill Will
  • 53 Answers
SOURCE: Have a frigidaire es510, i
Hi ,
This is the code for a communication failure between EOC (ELECTRONIC OVEN CONTROL) & ESEC system
1. Test harness/connections P4 (EOC) & P11 (Surface Element Control Board)
2. If harness checks O.K. failure can be caused by faulty UIB, Surface Element Control Board or EOC.
Check on the back of the stove there should be an envelope attached to it that has service paperwork in it with diagrams
It will most likely need a new oven control very easy to replace just remember to remove the power to the unit before you work on it.
Please contact me if you have any more questions.
Posted on Apr 01, 2008
  • 1073 Answers
SOURCE: frigidaire electric ceramic stove
replace oven control
Posted on Apr 16, 2008
SOURCE: frigidaire PLES3890
i wouldnt buy one of these products again never!!!!
Posted on Aug 25, 2008
SOURCE: Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Posted on Jan 02, 2009
SOURCE: Receiving Error F13
Turn the breaker to the stove off for one minute, reset time and everything should work just fine. It worked for me.
Ken
Posted on Jun 01, 2009
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Frigidaire stove oven problem
Sounds like the control board needs to be tested for any communication errors and possibly replaced.
Aug 24, 2012 | Frigidaire Ovens
When I try to turn on the oven it say f13 err
Most of the F13 fault codes say it is either the Main board or a temperature sensor.
May 10, 2011 | Ovens
My Oven is displaying a f30 ERR message and won't allow me to use my oven,,,the stove works fine....what do i do?
I have same problem, displaying a f30 err message and does not work oven rest is working. I have changed sensor still does not work.
Apr 17, 2011 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
Frigidaire professional stove, Oven does not work, can't bake, self clean. get an ERR F30 code.
Is the clock set?
In mine - the clock has to be set - or it won't work;
Aug 12, 2010 | Frigidaire Ovens
Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Dec 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
FRIGIDAIRE STOVE MODEL FEF316BSC I WAS BAKING
Don't worry! Your element probably blew out. It's no big deal. It happens. Call us for parts. 9728590929. It's really a simple repair, probably one of the easiest to do. Hope this helps!
Aug 24, 2009 | Ovens
Frigidaire Oven - lights are on but no heat from oven or burners
You must check your incoming power for 220 volts. You have lost one leg of your power. Either a bad breaker or bad wall outlet or bad range cord.
Jun 26, 2009 | Frigidaire Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
107 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
