Question about Pioneer PD-R509 CD Recorder
Red light above display flashes but no functions working
Hi, I am using the PDR-509 CD recorder, but when i switch the unit on the red light above the cd tray flashes but there is no display and none of the buttons work.
Hi Dave
I'm not the most technical person in the world but I think I've fixed mine which had the same problem this afternoon, which is how I came to find your message!
Right.. here's what I did. It would appear that you have some kinda mechanism jam (even if there's no disc in it), so... please excuse my non-techie terminology throughout.
By the way, I probably don't need to tell you this but unplug the unit from the mains first or you might light up if you touch something!
Working with the unit facing you (control side), remove the two small screws at the back (on the metal flange) and two medium screws from the right hand and left hand sides of the main casing, then slide it off from front to back so that you can see inside the recorder. If you look in and down at the CD tray transport mechanism you should see a white plastic 'cog' wheel on the left hand side of the unit near the bottom 'floor' of the machine. Carefully rotate this wheel with a finger CLOCKWISE (pushing the wheel from front to back), slowly and gently - don't force it - and you should see the CD tray mechanism and gubbins start to move; keep rotating until the tray comes right out, or as far as you think it goes. Then, plug the unit back in, and switch on - the tray SHOULD then be taken back into the machine, the red light will flash, and the display should come on. As I say, mine has, so try it and I hope it works for you!
All the best (we'll beat these damn machines yet!)
Kev
Posted on Jul 25, 2009
  • Michael McGrath
    Michael McGrath Jan 02, 2016
    Hi Kev I had the Red Flashing Light Issue with a CD stuck inside, took your advice and Hey Presto it worked, Wish I'd seen this before I purchased another CD recorder from e-bay :( but I have a spare now, so not all bad eh ? thanks for your help and Happy New Year ;)
Have pioneer pdr-509 will set up for recording, but recording levels are very low with level knob cranked up. no recording levels lights.
A lot of that depends on your external device. What is it? Please don't say it's a turntable.
When you say it won't set up, what DOES it do?
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/pioneer/pdr509.html
Mar 03, 2011 | Pioneer Audio Players & Recorders
IS IT POSSIBLE TO PUT INDIVIDUAL TRACKS ON A CD DISC WHEN DIRECTLY RECORDING FROM A CASETTE TAPE? JOHN GIBBONS
Yes. Iif you get an audio CD recorder like a Pioneer PDR-509, HHB-30, for example, you can record from any number of sources onto a CD in as many sessions as you like until you finalize it.
Jan 10, 2011 | Audio Players & Recorders
CHECK message on Pioneer PDR-555RW display
have a Pioneer PDR-555RW with blinking CHECK message on display after repeatedly open/close operation. I cleaned ... - posted in CD Players
Jul 17, 2010 | Pioneer PD-R555RW CD Recorder
How can you CD record from phono
One way would be to get a CD audio recorder. Google 'cd recorder'. There are many out there. I've had a Pioneer PDR-509 since 2001 and am very happy with it.
Consumer machines require CD-R Audio media which are slightly more expensive than standard CD-R's.
A turntable capable of self -pre-amplifying it's output to a usable Line Level; or a standard TT routed through a receiver with a Phono Preamp will create the audio signal that the recorder would record.
Feb 15, 2010 | Audio Players & Recorders
Pause/resume function in analogue, manual recording mode
This player has essentially the same guts as my Pioneer PDR-509, so this is what it means...
'Repair' means the player lost power in mid-recording without commiting the track memory to a table of contents. It would likely take up to 40 minutes for the player to reconstruct it from the disk.
There is NO reason the player need be turned off (if that's where it took you) for a track pause.
Just press Pause, flip the LP over and hit Play or Pause again when you wish to continue recording.
Perhaps you don't know how to Finalize the disc either. It's not that intuitive. Press Finalize, after a while it will display a time, like 4:07. That means how long it will take to do the operation. Now press Pause and it will count down to 0:00 and be done. Then you can play it on any other CD player.
Feb 14, 2010 | HHB 830 Plus CD Recorder CD Player
HHB burn it...I record on coaxial from Tascam DAT. 1st five tracks are great but the 6th track sounds horrible like there is a scratchy sounding distorted delay. It does this every once in the while . What...
I had this happen a lot on my Pioneer PDR-509, which is pretty much the same machine, when using marginal mongrel-brand CDR's. It's annoying but I have seen nothing to explain or detect it in real time so something can be re-recorded.
Nov 17, 2009 | HHB BurnIt CDR830 CD Recorder
I press the shutter button a red light flashes in the viewfinder
Your focus or lighting is too low for the picture. Add more light, and hold the button down half way to self adjust to see if it goes away. Change the battery to a lithium battery, which helps the digital cameras work their best.
Let me know if this helps.
Jan 24, 2009 | Toshiba PDR-M700 Digital Camera
Flashing red light and working
i have NV-D60EN model panasonic mini dv camer but when i use to record and play back, its red light falshing for about some second later switching itself off. it does not function any thing so that if you don't mid give me the solution please
yours respectful customer
God bless you !!
May 13, 2008 | Panasonic NV-DS60 Mini DV Digital...
Nothing on unit front display but Red Record light (solid)
how do you hook a dvd player up to a Sanyo sdtv model ht27547 tv ?
Jan 18, 2008 | Televison & Video
Pioneer PD-R509 CD Recorder Logo
397 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
