Question about Edirol UA-25 External Sound System
Edirol Ua 25 Making humm noise when recording Mic
Hi: My interface makes some humm noise when y record my Mic,I have to get the volume very down and any ways I still get the noise. What can I do? Thanks Alexis
I had the same problem, it was due to the charger i had for the laptop, this problem can be accomplished by purchasing STEREO leads. I do not know the reason they work, but if anyone does find out please tell me
Posted on Jan 12, 2008
  • 457 Answers
The microfone needs replacing or replace the cord on it.
Posted on Sep 23, 2007
Edirol ua-5 flashing power light flashing
Be aware that SCMS "prohibited" recordings will trip this flashing light, and will not output. You will have to make an analog copy.
Feb 25, 2012 | Edirol UA-25 External Sound System
I am going insane trying to figure out why my vocals are recording so inconsistently - volume all over the place. It isn't obvious until I take the wave file to my engineer who's recording my CD. ...
hmm, it could be something simple such as a faulty cable from mic to pc, it could be a faulty input if you are using a mixer, could be a faulty mic, it could even be a piece of software running in the background that is conflicting with sonar and causing this problem. This should be an easy problem for your "engineer" to sort out. as seeing it makes it 100 times easier to fault find. Thats part of being an engineer!
Sep 03, 2011 | Edirol UA-25 External Sound System
How to use a condenser mic on a mac/in garageband?
If you are sure that the microphone and the cable is OK, it could be that you're phantompower is to low.
Normally you need 48 Volt, you can check that with voltage meter between pin1-2 and 1-3 from the XLR.
Jan 22, 2010 | Audio Players & Recorders
No sound being picked up by Edirol
I discoverd the the digital in button had been pressed in. This was the mic was not picking up any sound.
Jul 09, 2008 | Edirol UA-25 External Sound System
Edirol UA 4FX _Short Audio Signal dropout
try runing a cleaner ccleaner and ace utituies ok that stop those hickups give a atry make pc run alsot faster
Jan 28, 2008 | Edirol UA-4FX External Sound System
Only Hearing Sounds on One Side of Headphones
your headphones are bad sounds like cheak out the new seinhezer hd280 pros ok 99 bucks best they make
Jan 23, 2008 | Edirol UA-25 External Sound System
Playback recordings
Problem with cable? Change in sample rate? Have you changed software/drivers? Could do with more info.
Jan 17, 2008 | Edirol UA-25 External Sound System
Recording sound
What operating system/ computer are you using>?
Oct 17, 2007 | Edirol UA-25 External Sound System
Mic problems: playback works great through interface, microphone isn't being detected
Check in contraol Panel under sounds and audio devices that you are using the Edirol and not an on board sound. It sounds like although the cards installed its not selected as the audio device to record from. You will also have to tel Adobce audition to select the Edirol as you audio card of choice as it to can be changed to select input from other sound devices.
Mar 31, 2007 | Edirol UA-25 External Sound System
Edirol UA-25
A computer has line out and that means sound out from the computer to your speakers. A line out can also be connected to a recording device or a pair of speakers with an amp built in. Line in on a computer can be used to record audio from other equipment such as a Dj on his decks to record his set. It can also record audio from mp3 players etc. Line in can be used for mic's and also you can use mic in as well. To record any audio onto your computer use line in. Line out can also used for headphones and the mic will plug into mic in so you can talk online.
Oct 27, 2006 | Edirol Roland UA-25 External Sound System
Edirol UA-25 External Sound System Logo
363 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
