Question about HP PSC 1350v All-In-One InkJet Printer
Power problem: is there an internal fuse?
HP PSC 1350 power problem after lightning strike. The power adapter is NOT faulty, so is there an internal fuse that may have blown? If so, how does one access it?
  • Mike C
    Mike C May 09, 2009
    I appreciate all you have said, but don't you think that if I "have knowledge in electronics" I'd have done all that already? I am merely trying to ascertain whether or not there is a simple fix by replacing an internal fuse (as I did with my microwave cooker) BEFORE opening the printer case or contacting HP for assistance.
    Thanks anyway.
  • 527 Answers
Sir,
If  u have knowledge in electronics open the printer and check the power board if any IC's is burnt? check the whole printer if there any burnt parts inside. If it is YES better to contact HP or local technician bec. it is difficult to identify which parts is defective. so contact manufacturer for better results....
Link 1 for help
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on May 09, 2009
Our hp printer j4680c took a lightning strike. We replaced the power adapter but when we plug it into the printer the light goes out on the adapter. Is there anything else we can try? The unit doesn't...
This sounds as if it has shorted out the main power board inside the printer. Some small TV Repair shops handle out of warranty printer repairs, but will charge considerably for this. Unless your willing to pull it apart it would be more economical to replace the printer. But ask around, someone may be willing to give you a quote, and this should be weighed against the cost of a replacement
Unfortunately with lightning strikes the amount of power surging up the line can destroy many components inside the printer,and not much can be done from the outside.
Sorry it was not the answer your looking for, but lightning is a electrical devices worst enemy!!
Regards GM
Apr 12, 2011 | HP Photosmart Premium C309A All-In-One...
Lightning strike, blows internal fuse (6.3v 125/250) on plug in.
sounds like the lightning strike took out at least the power supply if not more. sorry to be bearer of bad news.
Oct 31, 2010 | Toshiba 24AF41 24" TV
All lights flashing on HP psc 1350 printer
Resetting a Hp printer means switching off the machine, removing the cartridges, disconnecting the usb cable and the power chord, leave it off for few minutes then restarting it again without usb cable connected to it and without cartridges installed. You need to press the power button while it boots up. Leave it one for few minutes and again turn it off. Reinstall the cartridges and plug in the usb cable, again Power On the printer. That's all.
But there's another thing when you say all lights are blinking/flashing, there is chance that there's an internal faulty. Clean the cartridges contact point and the contact points on the printer. If possible, clean the printer thoroughly, including the waste ink tank. This will let you help find out the culprit.
Good luck.
Thanks for using FixYa.
Jun 20, 2010 | HP PSC 1350 All-In-One Thermal Printer
Where can i find a power cord for my hp psc 1350 all-in-one printer, im based in the uk, so must be suitable for uk power outlet, cant find one anywhere.
1 Use the original power cord which came with the printer. All you have to do is to go to any of the electronics shop in your area and get the multi socket extension cord which can be plugged to UK power outlets. Connect the printer through this.
Jan 27, 2010 | HP PSC 1350 All-In-One Thermal Printer
Model TDC2075A Sansui Had lightning storm, lost power no close lightning strike. TV will not power up, don't know if it has internal protection or is power supply went out
you mite try replacing the ac fuse 1 time-if it blows again there is a short in the power supply-i would then check rectifiers in the primary of the power supply-then check the fet-if any of them are shorted replace them
Sep 04, 2009 | Sansui CDVD1900 19" TV/DVD Combo
Need a new power cord, how much ?
Here you go:
Compatible Part No:
  • HP 0957-2094
  • HP 0950-4466
Compatible Printers:
  • HP OfficeJet PSC 1350
  • HP OfficeJet PSC 1355
  • HP OfficeJet PSC 2410
  • HP OfficeJet PSC 2410xi
  • HP OfficeJet PSC 2450
  • HP OfficeJet PSC 2510
  • HP OfficeJet PSC 2600
  • HP OfficeJet PSC 2610
  • HP OfficeJet PSC 5510
  • HP OfficeJet PSC 5510 all in one
  • HP OfficeJet PSC 5850
  • HP PhotoSmart 1315 all in one
  • HP PhotoSmart 2510
  • HP PhotoSmart 7960
  • HP PhotoSmart 7960w
  • HP PhotoSmart 7969
  • HP PhotoSmart PSC 2510
  • HP model numbers Q3435AR, Q3435A, Q3501A, Q3087A, Q3090A, Q3094A, Q3020AR, Q3020A, Q3023A, Q3024A, Q3021A, Q3022A
  • HP Bundle PSC1315+M307 Q5776A
  • HP OfficeJet 5500 Series All-in-One Q3434A, Q3435AR, Q3435A, Q3435P, Q3436A, Q3437A, Q3438A, Q3440A
  • HPPSC 1300 Series All-in-One Q3492A, Q3493A, Q3495A, Q3500A, Q3501AR,Q3501A, Q3502A, Q3503A, Q5532A, Q5534A, Q5763A, Q5765A, Q5766A, Q5767A,Q5768A, Q5769A, Q5770A, Q5771A, Q5772A
  • HP PSC 2410 PhotoSmart All-in-One Q3087A, Q3088A, Q3089A
  • HP PSC 2500 Series PhotoSmart All-in-One Q3094AR, Q3094A, Q3095A
  • HP PhotoSmart 7900 Series Printer Q3020AR, Q3020A, Q3021A, Q3022A, Q3023A, Q3024A Q3090A
For HP 0957-2094 PhotoSmart 2410, 2510, 5510 Printers and much more.Come with power cord. Power Rating: 32V 940mA and 16V 625mA
Note: Amps and Watts are maximum load tolerance. Devices only draw as many Amperes or Watts as they needed
For purchasing you might also contact this link below:
http://cgi.ebay.com/Adapter-For-HP-0957-2094-0950-4466-32V-940mA-16V-625mA_W0QQitemZ250414311173QQcmdZViewItemQQimsxZ20090427?IMSfp=TL090427149005r21586
Hope you like my info
May 25, 2009 | HP Photosmart 2610 All-In-One InkJet...
My HP 1350 all in one printer/scanner/copier will not power up. I have checked the power cord and adapter and they are fine. I recently moved and it powered on for a second but after I insdtall IE 8 I...
Check the in put power cable with the meter....are you getting the required power???...if yes...remove the back panel its a clip on and reinstall it.....
keep me posted
May 05, 2009 | HP PSC 1350 All-In-One Thermal Printer
HP 1402 All-in-one problem
four problems for sure.check out 1 by 1.
1)either the power outlet itself is faulty.
2)either the power cord wire is faulty.
3)either the adapter in which the power cord is fitted is faulty.
4)and last but the costly 1 the jack of the printer in which the power wire is inserted is faulty internally.
Oct 21, 2008 | HP PSC 1610 All-In-One InkJet Printer
Recommendations for power strip, etc. for HP Slimline
Hi when you buy a power strip especially to prevent lightning strikes ensure that the power strip has gas tube protection alongwith the usual MOV and Fuse
May 14, 2008 | Computers & Internet
HP PSC 1350v All-In-One InkJet Printer Logo
168 people viewed this question
Seeker5211
Seeker5211
