Question about Pool & Spa
Restricted flow Jacuzzi spa pump runs fine on low, but seems restricted on high. When switched to high, the pump "jumps" like it is trying to push water but may be blocked. The jets seem to have a reduced flow sometimes, but not everytime. Almost seems like a vapor lock. Could this be an impeller problem?
    New Friend:
  • 77 Answers
Try cleaning the filter cartridges thoroughly. Also test operation without filter(s) in place, temporarily. Check that any adjustable jets are open and not creating too much back pressure on system.
Posted on Apr 22, 2009
I have a new spa with a Pentair Mastertemp 125. We have had issues with the heater running intermittently and making a very loud rattling noise. I've been through a long list of troubleshooting...
Maybe that at lower pump speed the water is staying in the heat exchanger too long, and the rattle you hear is water starting to boil. The high limit sensors will sense the water temp being too high and shut down the heater. If it functions normally at high speed the issue is probably with the heater having problems with slow flow through the exchanger. You may want to consider switching to an electric heater where this would not be an issue. Just a guess without being there.
Jan 18, 2015 | Pentair Pool & Spa
Trouble shoot jacuzzi spa
check filters sound like dirty that will restrict flow
Jul 23, 2014 | Polaris Pool & Spa
Pool pump running low psi
your pump should be just fine once the water starts flowing again. You may have run it too long without enough water to cool the seal.
If it is leaking water between the Jacuzzi Pump housing and the motor then you will need a new pump seal. Those are common pool parts.
Rod
US Parts Center
888-521-6183
Jun 09, 2012 | Jacuzzi Magnum Force Series Pool Pump 1...
My Essence Echo Spa jacuzzi is giving us an error "FL". Can you tell us why it is saying this and how we can fix it? Thanks!
FL stands for Flow. It is a diagnostic code that is indicating that either the the flow/pressure switch has failed, or the pump is not pumping enough water to operate the spa safely.
If it is the pump, you might try to lean out the impeller housing as its common to see a pine needle or other such blockage affecting the pump.
If its the switch, just buy another generic switch and swap it out. It would only take a few minutes.
Apr 10, 2011 | Jacuzzi Pool & Spa
I loose discharge water flow after about 5 minutes of running perfectly. The pump has no air bubble and is trying to push water thru filtration system ( if I open the backwash valve I have very good flow...
If you have a pressure gage it would help .. if the pressure is high then there is probably an obstruction in the return pipe to the pool .. if the pressure is low then there is most likely a restriction in the supply or suction side of the pump .. this would seem more likely to me from your description, there may be something obstructing the flow into the pump, a clog, a collapse hose from the suction, some flap of pool liner .. something like that ..
Please Vote !
Jun 01, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
I have a 2004 great lakes hot tub with a balboa controler. My hot tub heats up fine when the pump runs on high but the temp light never comes on when the pump runs in low.
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Feb 04, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Jacuzzi Laser II: Problem with the Heater/filter setting. The jets come on when it's on this setting. When I turn it to Filter setting it's fine..when I turn it off the jets come back on What gives?
The jets will run while in the filtration / heating mode. If the spa is in the middle of the filtration cycle, the jets will stay on until the cycle time runs out. So, if the spa jets are on during this time, they are on for the full duration, 2-6 hours every 12. You can cycle the jet button to high, but when you try to turn them off, they will just go back on low.
Jan 23, 2010 | Jacuzzi Cyget In Ground Pool Pumps
Pump will not work in high speed
Only three posible problems. High is out on pump. Spa side control is out. Control box relay that runs high pump is out.Does upper controls(spa side) read out a code? Kirk
Feb 12, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Pool & Spa Logo
197 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
