Question about Refrigerators
Door seals are hot to the touch..
I have a built in with the motor on top. The seals around the doors are "hot" although the fridge apears to be working fine. We have never experienced this before... I have a frigidair ksrg25fkwho3 side by side with the same problem. I took off the back panel and the fan was not blowing. I left the cover off and it cooled down some. there is no power going to the fan yet everthing else has power. Is the board bad? Is this something I can change? e
    Top Expert:
  • Refrigerators Master
  • 34,188 Answers
The door seals are heated to prevent freezing.
Posted on Jun 22, 2017
2 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: door seals are hot to the touch..
There are 2 or 3 things that would cause this. first make sure the condenser coils are not plugged with dust (vacumn or blow them out) next check to make sure the fan that cools these coils is running, (this is the most likely problem). if both of these check out ok then you would need to check to make sure your interior lights ar going off when the doors are closed as these will add extra heat and cause the center rails to run hot. last and most uncommon would be a freon system problem.
fyi there is a hot gas freon line that runs in between the doors to prevent exterior sweating. when poor or no air flow problems for the condenser coil exist it causes this area to become hotter.
One more thing. if you do determine that the condenser fan motor is bad you can put a normal house fan blowing on to the coil to help cool this area down until you can get the unit repaired.
If you need any further assistance leave me a comment here and I'll gladly get back to you. Thanks Peyton
Posted on Feb 23, 2009
Have a 2 door 520L fridge/freezer (freezer at the top) and the fridge door isn't sealing. We would like to know how we can adjust the door so that it stays closed as in this hot weather the motor is...
is the seal new usually when we put a new seal on the door we use petroleum jelly aka vaseline around the entire door seal and shut the door for about two hours this causes the seal to mold to the fridge door while it is closed and also increases the amount of adherence to the door cabinet as well send me your model number so i can look up your model and send you a schematic so you will be able to adjust the door Thanks again
Rick
p.s please remember to rank or post testimonials when our chat has concluded as well and if you have any further questions message me back Thanks
Jan 05, 2011 | Refrigerators
Very hot to touch between fridge and freezer on front panel
on front panel around the door where the door seal goes up against is this what is hot check the compressor fan in the back of the machine when it doesnt run or is unoperational then the sides around the door get hot you might have to replace the compressor fan
Aug 12, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
The doors are scorching hot to touch on my Maytag 2454. It's always been warm to touch, but all of a sudden it is too hot to even touch. It is in the center part of both doors, along the door seal area and...
It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
Apr 22, 2010 | Maytag MSD2454G Side by Side Refrigerator
Fridge does not get cold, lights are flashing and whoo whoo noise
Lights which previously did not flash but now do are clear indicators of operating failure.
Refridgerators and freezers do not like being unplugged for too long. if yours has been disconnected from the power for more than a couple of days, it could be damaged and need part replacement.
The variables are cold leakage, cooling gas leakage, electrical pump failure, thermostat circuit open, thermal cut-off switch disconnected. All of the above can be dangerous - electricity, gas, over-working pump etc. so always remember what we learned in kindergarten - If in doubt don't' - good advice with anything risky.
If you set the fridge on the coldest setting, place a common thermometer inside, note the initial temperature after closing the door for 15 minutes and then leave the fridge door closed overnight, in the morning carefully touch the heat transfer coils at the back, they should be hot all over to the touch. Open the door and check if the temperature has dropped.
If the whoo whoo noise is coming from the pump (often located in a black closed saucepan-sized unit you need to contact a qualified Whirlpool fitter.
If the whoo whoo noise is coming from around the edge of the door, the airtight seal is possibly defective. The seals often get dust etc. trapped in the accordian-like sealing strips around the entire door so, being careful not to damage the seal, clean the inner grooves - an old toothbrush and household cleaner generally work well.
If the fridge is a self-defrosting type, the lights may be indicating that it is stuck in defrost mode - check the Whirlpool website for troubleshooting temperature settings. There is often a small regulator switch which can break down. If you think that this is where the noise is coming from do not go fiddling about - electricity is a to be treated with care. Look for scorch marks or listen for crackling noise indicating a short sparking. Unplug the fridge before poking around the wires. A connector may have been dislodged and needs to be reattached so double-check that the power is off before reattaching the loose wire. It should be obvious where it plugs in but if not, don't go touching different tabs.
Re-read the installation and operating manual or call a fridge repair service if you are unable to find the fault. You can save time and repair costs by telling the repair person what you have tested and the results.
The built-in thermostat could be malfunctioning and preventing the coolant coils to absorb heat.
Sometimes the defrost drip tube can become blocked. This generally runs down the back into a drip tray. You should be able to check for blockage by thoroughly cleaning the tray end of the tube and blowing through it. Don't ****.
I hope this helps,
jenni.
Sep 09, 2009 | Refrigerators
Stripe between fridge and freezer is extremely hot to touch
It is 100% the condensor fan motor on the back. Its not two hard to replace. Take the screws off the back panel and remove. Then locate fan. Disconnect the wires going to the motor and then unscrew the scews that mount the motor. Take the part to parts store of look it up online. Then simply remount motor and plug wires in.
Golden.
Jul 29, 2009 | Whirlpool ED2FHEXN Side by Side...
Front metal , top heating element very hot
This should be OK. There are heat strips placed behind the door frame to prevent sweating around the door frame due to the metal being cold normally without the strips. Thanks, Sea Breeze
Jul 21, 2009 | Refrigerators
Feb 23, 2009 | Frigidaire FRS23KF7AB Side by Side...
Fridge is hot to the touch
your condenser motor is not running repl it asap before it melts ur wtr lines or seals around door
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Outside freezer hot and seals
Fridge has either mullion heaters around door or most likely steel pipes just inside the skin of the perimeter of the door, this is to stop ice or condensation forming around the door seals, mainly the freezer, they are part of the condenser circuit ( hot part of the refrigeration system).
It is normal for these to get hot, but in your case may be hotter than usual because of the constant running, the running may be caused by hot ambient temperatures, system being slightly short of refrigerant, faulty thermostat or in-efficient compressor.
I suggest if temp is ok inside fridge dont worry too much, if you notice fridge starts loosing its capacity to refrigerate, have a refrigeration tech look at it.
Nov 13, 2008 | Maytag MSD2756G Side by Side Refrigerator
Fridge is getting hot in between the doors
This is called a mullion heater and is perfectly normal as this heater prevents the area between the doors from freezing. No danger at all.
Mar 08, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refrigerators Logo
158 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
