Question about Liebert UPStation GXT2700RT-208 (GXT2700RT-208B) UPS System
50Hz to 60Hz conversion
Is it possible to set up the unit so that the input is 240V 50Hz and the output is 240V 60Hz? I need to power 60Hz US made equipment in a European country and can use a transformer to step down the voltage but still need frequency conversion.
  • salbok Apr 23, 2008
    I have bought an upscaling DVD player and a high end home theatre system (Pioneer Elite 530 watts and Definitive technology subwoofer and speakers 300 watts) for use in UK. I am going to use a 2000 watt step down converter with built in stabilizer and delay switch. Please advise if I need to consider solving the 50 / 60 Hz issue and is the converter capable of handling the equipment mentioned above. Thanks.
    Brigadier General:
  • 6,966 Answers
Hi, Your idea is basically sound and should work as long as the UPS originally is designed to produce 240V 60Hz and has its own built in timebase. The reason is that the input as long as the voltage matches makes no difference (50 or 60 Hz). By design, the UPS converts the input voltage to DC to charge the internal battery. The battery then powers an electronic circuitry that produces the 240V 60Hz. The input is then isolated from the output in terms of frequency. This is a common design, however, there are some (not many) that uses for its local oscillation sampling from the source and therefore will replicate the input frequency to its output, but very rare; it's better that you know they exist. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards. P.S. The only problem with 50 and 60 Hz is heat buildup which is tolerable and still within safe parameters. The only time the 50/60 HZ makes a big difference is when motors are used, timers such as in the early designs of microwave ovens, washing machines, etc., pumps and other highly inductive consumers. Most electronic devices converts the AC input to DC and therefore the frequency has negligible effect. Of course others may see it differently.
Posted on Sep 16, 2007
  • Louie  Role
    Louie Role Sep 16, 2007
    Hi again,
    of course the power output of the UPS must match if not be higher than the load/device requirement.
Can anyone please tell me what are the implications for change over from 50 hz to 60 hz system?
Posted on Mar 04, 2010
Can lg 50hz washing machine run on 60hz
yes but I will not good IDEA you will have phenomen transistory is electrical term in engineeering electric, you must get support via ONLINE chat or phone with LG.
you must transform the 60hz to 50hz or 50hz TO 60hz.
God bless you
Sep 30, 2012 | LG WM-1832C Front Load Washer
I recently purchased a Pioneer SC-07 in North America(110v/60Hz) and need to convert it to use in Australia (240/50Hz) Am I able to purchase power supply to make this happen?
You need to locate a power converter. This is basically a trqansformer that will convert the 240V system into a 110V system. These are generally available anywhere where travel supplies are sold. You can also contact Pioneer and see if they have a conversion kit which would require the replacement or alteration of the internal transformer on the unit.
Nov 09, 2009 | Pioneer Audio Players & Recorders
What power supply is needed for hp scanjet 2400
It is depends on your scanner power adapter and where u purchase the scanner from. Here if your scanner is from US then the adapter power input should be 100-120V 60Hz AC, if your scanner is from Euro, UK or Australia, the it should be 200-240V 50Hz AC, while if your scanner is from others place that not listed above then it should be 100-240V 50-60Hz AC.
But the best way is look at your adapter itself, u'll notice the power input and output from the adapter sticker.
If you lost your adapter then be sure to purchase 1 that can output a 12 VDC, 340mA, 4.22W adapter to the scanner.
YBC (/\)
Oct 20, 2009 | HP ScanJet 2400 Flatbed Scanner
Dimensions 5.9"W (150mm) x 3.4"H (86mm) x 5.5"D (140mm)
Special Features Dell Proprietary Main ATX & 6 Pin Auxiliary Connectors
AC Input 100-120V/7A 60Hz 200-240V/3.5A 50Hz
DC Output Voltage 3.3V 5V12V
Total Output Max Load 200W
Jul 20, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Samsung LCD TV series 5 240Vac, 50Hz will it work with 60Hz?
no only the voltage is critical.the only point is you have to select right counrty and tv sound and picture system on setup menu!
Jun 11, 2009 | Samsung LT-P227W 22 in. HD-Ready LCD...
US portastudio 2488: Can it play when connected with a transformer
The 2488mkII manual specifies that the unit can operate with either 120VAC, 60Hz (USA/Canada), 230VAC, 50Hz (U.K./Europe), 240VAC, 50Hz (Australia) so you should be fine with a transformer which can accomodate 230VAC, 50Hz).
I have actually conversed with people who have been using the 2488 in France without any power problems.
Sep 12, 2008 | Tascam 2488 Portastudio Multitrack...
Samsung hcm5525w rear projection tv
Extensive analysis revealed this unit to be for 120V 60Hz regions. If you use it in a region where the mains supply is 220/240V 50Hz then it won't work. In addition, the PSU will overheat, with possible damage to other modules.
One possible solution is a 120V 60Hz inverter, else Samsung may be able to provide the correct PSU for 220/240V.
Jul 14, 2008 | Samsung HCM5525W 55" Rear Projection...
I'm in the UK bought my
This trimmer is only made to be used with 110V, we do not have this model in 240V. There is no way to stop the noise. If you would like to purchase a unit made for 240V please call 1-800-558-9441 and speak with one of the Andis customer service reps.
Thank you for purchasing Andis.
Dec 01, 2007 | Andis Outliner II Hair Trimmer
Liebert UPStation GXT2700RT-208 (GXT2700RT-208B) UPS System Logo
1,967 people viewed this question
Top Liebert Computers & Internet Experts
Computer Links
Are you a Liebert Computer and Internet Expert? Answer questions, earn points and help others
