Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a sony trinitron kv36fs13. Text on the screen is distorted
It is distorted on the top and bottom of the screen. The middle looks fine. I know there is a service menu. How do I access it? I don't have the original remote, I have a direct TV remote.
  • 87 Answers
You need the original remote to get in the service menu. Sounds like a deflection yoke problem Sony has an 8 page bulletin on this depending on ser# of tv. Est cost of repair is 250.00-300.00 not for the novice. Recommend calling Sony service center.
Posted on Apr 16, 2009
How to hook up a Sony Large Screen FD Trinitron WEGA stereo color TV (KV-36FS13) to a aiwa cx-na888
first of all i did fing the sony manual on sony's website http://www.docs.sony.com/release/KV36FS13.PDF
page 32 shows the audio out jacks , run the red and white wires to the inputs on the aiwa (i did not find a manual for the aiwa) if there are no input jacks on the aiwa then you can not connect it.
hope this helps
Thanks
Roety
Dec 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY kp-51ws510 rear projection tv. recently it started showing a rainbow on the left top corner and middle bottom of the screen. what might be the problem? can it be fixed? for how much?
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 20, 2010 | Sony KP-51WS510 51" Rear Projection...
I have a sony kp-41t65 tv acting like computer screen out of whac
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can get more information and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
Nov 10, 2009 | Sony KP-41T65 41" Rear Projection...
Sony trinitron kv36fs13 the picture is fine but there is yellowish green tint on full screen
Yellowish tint in picture shows that TV needs increase in blue gain because picture tube is bit weak in result.
If you are handy with electronics repair then let me know to guide you further.
Jul 12, 2009 | Sony FD Trinitron KD-34XS955 34" TV
Top left side screen shows video 5
Get the original Sony remote. Select TV or the Video input you want to use. Then press the Display button to make the text dissapear.
Jerry G.
Nov 13, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron wega KV27FV310
Sounds like a problem with the vertical circuit. If yuo can solder and are comfortable with working inside the set, you may be able to repair this.
Keep us posted.
Dan
May 23, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Kv36fs13 picture is purple
YOU HAVE SURELY THE CIRCUIT OF RED COLOR MALFUNCTIONING , - I F YOU CAN  YOU HAVE TO CHECK ON THE BOARD CONNECTED TO TRINITRON TUBE THE CIRCUIT  OF RED COLOUR SOMETHING IS TROUBLE -- DELFO
Feb 29, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Have no red color and the other colors seem to be fading on my sony KV36FS13
in that tv you have surely the color circuit trouble - if you can you have to check  the red color circuit , first transistors then voltage or a capacitor not functioning ,
I HOPE THIS MAY HELP YOU - DELFO
Jan 19, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
1/3rd of Bottom portion of Screen is blacked out
sound like you have cloced caption text on, this is not the same as the normal cloced caption, look on your rempte for caption or "cc". if you don't see it you will find it in your menu & turn it off. have a good day.
Jan 02, 2007 | Sony FD Trinitron WEGA KV-32FV300 32" TV
WS-55809 - Video pinched in center, distorted, yellow/blue/red glow
This doesn't sound like a programming issue. I had a very similar problem about 6 months ago and I fixed problem. I had cold solder joint on the video power board. It was the board in the middle. The power supply was to the right. The video board had a driver with a bunch of legs. About 7 solder joint where cold or loose. I solder the board and my mitsu wide screen was fixed. Hope this helps.
Andy
Aug 22, 2006 | Mitsubishi WS-55809 55" Rear Projection...
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
316 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
