Question about HP Compaq Presario V2000 Notebook
Laptop not switching ON.
LAPTOP was not used for about 2 months . now it is not switching on. no power on indication in laptop. power adaptor okey
  • 31 Answers
Battery may need recharging fully after 14 hours or needs replacing.
Posted on Apr 16, 2009
My toshiba satilite L305D-S5940 Wont charge has new battery new power cord It comes on acts like its going to work then shuts off and sometimes wont come on What could it be please
1st : you can check from the power cable charge
2nd : check the adaptor charger if there is a light indicator or not, or you can check with multimeter to check the voltage on charger adaptor, does show the proper voltage for your laptop, you can check at the end of the connection that leads to the laptop.
note : Remember use DC current at Multimeter
3rd : if the adaptor running well, just plug on the adaptor charger to the laptop, dont turn on the laptop power, just see the light indicator with battery / lightning image on laptop, its explained that there is or is not the power current running to the laptop.
3rd.A : if its no power goes to the laptop then your adaptor charger is failed
3rd.B : if is there, there must be a problem with your motherboard, section power / power plugs, why do not want to charge with a new battery.
Conclusion :
- if the problem on number 1 & 2, then you can change the power cord and the adaptor charger.
- if there is problem on the 3rd.B then you can go to the toshiba services center for your problem.
thats all, hope its help.
Dec 01, 2015 | Toshiba Computers & Internet
Laptop won't switch on although blue power light on is showing power is getting to the machine
Check the power adaptor led is not flashing. Flashing Adaptor LED indicates fault with laptop charging circuit / powerboard
If it will not boot on battery, and you know the adaptor to be good, the issue lies with the motherboard.
Sometimes, removing the battery, and unplugging, pressing the power button and holding it for 30 secs, replacing the adaptor only will allow it to boot up, but this will only work if the motherboard is not damaged r the CPU fan has not failed.
Jan 27, 2011 | Toshiba Satellite P200-13Z Laptop AC Power...
How do I switch to normal power when the battery is running out please. It is a Medion Laptop. The battery warning light flashes and then the laptop warns 'switch to power' but I can't find out how to. It...
This might be an indication of a problem related to either the power adapter, the power cord, or the power receptacle in the laptop.
Please refer to the following article for detailed diagnosis & a fix:
http://www.fixya.com/support/r6395191-troubleshooting_laptop_power_failures_ac
Dec 21, 2010 | Computers & Internet
Acer aspire one won't turn on
Try another Wall Power Supply. To test. Take Out battery, Plug In wall supply to Wall & PC, without battery does it work OK? IF YES, replace battery still OK? Laptop Should work on Wall ONLY, if not, replace wall unit.
Apr 28, 2010 | Acer Aspire One PC Notebook
Laptop not used for 2 months. now not switching on. power adapter checked and found Okey
Please plug to power and charge for 12 hours before switching on again.
That fixes it.
rate this fixya
Apr 13, 2009 | HP Compaq Presario V2000 Notebook
Laptop does not power up or turn on anymore!
You seem to be in deep trouble..
It sure seems to be a motherboard issue. I will advise you to buy a new MBD. And to your relief, the data on harddrives will be "nil" affected by the motherboard change.
There might be an easier and cheap solution to the problem, but the area to be audited to find the solution is large with no guarentee that we will find a viable solution. Motherboard replacement will be an instant solution..
If you own a dell laptop, but a complete cover warranty that will include a free motherboard replacement and warranty for 1 more year..
Dec 18, 2008 | Gateway MT6707 Notebook PC
Acer 1360 ..LCD is blank, I cannot see anything along no indicator for hard disk
hmmm check out your power connection. see is the adaptor giving power to your lap when you connect this to laptop. There might be an indicator at the jack point of laptop to your adaptor.
If the adoptor is not working well then try to use another one of same configuration.
Thanks
Iqbal
Mar 11, 2008 | Acer Aspire 1360 Notebook
Toshiba Satellite 1405 - Power problem
Hi Don
Although symptom is showing that AC Adaptor is not working as its not providing power to the unit. I will suggest you to perform some basic troubleshooting steps. Check if outlet is working if not check with known working outlet. If you have a multimeter you can the output of the AC adaptor.
Also you can perform full power cycle and component discharge. Take the battery out and disconnect the AC adaptor press the power button and hold about 7 seconds. After that put the AC adaptor in and test again.
If issue persist take to nearest Service center check with known working AC adaptor. After that I believe you will figure out the best solution.
Good Luck
Jan 21, 2008 | Toshiba Satellite 1405-S151 Notebook
Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
Dec 20, 2007 | Sony VAIO PCG-K25 Notebook
HP Compaq Presario V2000 Notebook Logo
90 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
