Question about Lexmark X4270 All-In-One InkJet Printer
COPIER MODE IS NOT WORKING
WHEN I TRY TO COPY IN GET IT TELLS ME IN IS "UNSUPPORTED MODE"
    Sergeant:
  • 390 Answers
Try turning the unit off completely to reset it first, especially if it used to copy and now will not.
Posted on Feb 12, 2008
SOURCE:
I have an lexmark all in printer and i just recently brought refill ink and when i install them it keep telling me unsupported cartridge please help
Though Lexmark does not recommend using refilled ink cartridges, you may try to refer to this article in the Lexmark website on Unsupported Cartridge Error on a Lexmark X3330/X3350 All-In-One to determine and resolve the problem. If error continues, try to insert a different known working cartridge. Thanks.
Feb 15, 2011 | Lexmark OfficeCenter X3350 All-in-One...
Says unsupported mode.. what do i do to fix it
Mode unsupported error message usually appears when having problem sending a fax to a specific fax machine. Here's a link to the Lexmark website to guide you on what to do. http://bit.ly/alsndu. Follow the instructions carefully. Hope this helps. If problem persists, I strongly suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jun 27, 2010 | Lexmark X4270 All-In-One InkJet Printer
Vista driver for canon cp 300 printer
if Vista and 7 is unsupported by the printer manufacturer, you are pretty much out of luck. If Vista and 7 say the printer is unsupported or un certified, run the manufacturer software if you want.
You doult run in emulate mode ... but for as cheap as printers are these days, why would you want to run in that mode?
Oct 09, 2009 | Canon CP-330 Thermal Photo Printer
Wrong cartridge 093-982 cyan toner unsupported
are you using a dell-branded toner cartridge? if yes, then you should replace the toner cartridge sensor and machine control unit (MCU). if no, you can enable the non-dell toner mode on your printer's operator panel. how? press menu, down until "configure" & press select; down until "maintenance" & press select; down until "non-dell toner" & press select; down until "on" & press select.
Aug 12, 2009 | Dell 3000cn Laser Printer
Cannon 2200 always copies in landscape mode
Hello sir;At least you have to set up one paper tray to portrait direction, then when you make copy, use auto select tray. check user guide how to program it.
Jun 03, 2009 | Canon imageRUNNER 2200
Unsupported file format
You phone will only support certain file formats.
Go to Samsung and get the manual Click Here
The owners manual will tell you what music files, video files, picture files are supported by the software.
Then you may have to convert your files to work in your phone.
Let me know if this helped by rating the post...Thanks
Mar 02, 2009 | Samsung SGH-t629 Cellular Phone
Printer will not work
Hello trudyann,
I think you re-filled the cartridge and that's why you got this message
Use genuine cartridge and it will be work correctly.
But if you can copy papers by this All-In-One device .. and you can't use it as printer .. re-install the driver .. While installing if you got error message like [Unsupported cartridge] Press [Alt+F4] and continue the installation.
Thank you for using FixYa.
Aug 03, 2008 | Lexmark X2470 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
42 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
