Question about Pit SSR 110CC Pro Beginner Bike
My bike was working last night but not today it as plenty of spark i have cleaned the carb tryed a new carb but no joy so i put pertol down the head but still did not fire i have checked the piston and rings and they are fine can u help
  • neilwilli783 Apr 23, 2009
    yes i have
  • Anonymous May 05, 2009
    i hav same problem there is conpesson and spark and sounds like its doing something but nothing what can i do
  • 490 Answers
Check to make sure you have compression
Posted on Apr 16, 2009
  • Jeff Adkisson
    Jeff Adkisson Apr 23, 2009
    you have to have fuel spark and compression
    does it sound like it is even trying to fire??
  • wwall1985
    wwall1985 Apr 06, 2013
    I have the same problem. Took the engine off. When I took the exhaust pipe off the was some dirty fuel in the distributer cap. I emptied it and let it dry overnight. I suspect I got some water in there as well which diluted the fuel. I'm puting it back together now. I'll let you know what happens.
Hi my suzuki gz 125 wont idle correctly and when i rev the engine it just dies down and cuts out i cant even achieve a stable idle speed
I had this problem today with my bike and after much ado I discovered there was oil in the air filter box... check your oil level it could be too full. Mines was and the excess oil was blown into the air filter box and as a result contaminated the air filter. Spent today cleaning the filter box, carb and draining and changing oil, could not get a new air filter today so ran it without onebike runs like new!! New air filter will be here Monday!
Aug 22, 2012 | 2000 Suzuki GZ 125 Marauder
TTR 50cc Yamaha Little bit of oil comes out muffler
try a new spark plug first, take the spark plug out, put hd lead cap back on and touch it to metal and crank the bike oversee if your getting a spark at all. if not change the spark plug
May 08, 2010 | 2005 Yamaha TT-R 125 E
I have problem starting my xr 250(enduro)getting good spark plenty compression,fuel getting thru and carb all clean, ?? have changed cdi unit(original duff) but it was off mtx 125 but gives good spark,...
If you are getting gas than you have an air leak somewhere between your carb and the head. When the bike is ideling take a can of wd-40 spray slowly around every possable connection. ( rubber boot & where it bolts to the head ) When it sucks in air and wd-40 it will speed up and reveal the air leak. The boot itself could have a crack in it.
Oct 13, 2009 | 1990 Honda XR 250 R
2003 Yumbo Dakar Motorcycle -only 527 miles - will not start!!!
  • Nice looking bike. Yumbo Dakar is not a bike I have ever worked on but I will try to help.Remove the air filter and look into the carb as you twist the throttle. Does the slide open and close as it should? Open the slide and spray starter fluid into the carb bore as the electric starter is used. Not starting? NEXT >
  • Drain the carb just to see that it is filling with gas.
  • Remove the flywheel cover and put a timing light on the bike. Use the starter button and see if the timing marks are on. The CDI could be bad or the cam chain could have jumped.
  • Remove the cylinder head cover. Turn the flywheel to TDC compression. Look at the OHC gear. There should be two marks positioned parallel with the head surface, (or an '0' at the top of the gear and in line with the centerline of the crankshaft). Are the valves in time?
Aug 14, 2009 | 2004 Yumbo Dakar 200
93 CBR decided not to run today
Well, depending on what your mechanical skills are, it may be tough to troubleshoot and fix your problem. I have the same exact bike, and it along with all other sport bikes are tough to work on because everything is very confined. You first have to start with the basics, Fuel, Spark, and Compression. Your going to have to get the fairings off and remove the gas tank before you test any of that. Once the tank is off, you can get access to the spark plugs and wires to do a spark test. Also while you are there, check to make sure the carb is getting sufficient fuel, or even possibly too much fuel. Leaky needle and seats in the carb bowls can cause lots of problems for starting and idling. And please don't blow yourself up! Exposed gas and spark test can equate to big flame balls if your not careful. If you need more help, I'd be willing to do what I can for you so shoot me an email at jmegashiftstyle@aol.com.
Jun 16, 2009 | 1993 Honda CBR 600 F(2)P
Bike wont start
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Clean the air filter. Install a new stock NGK spark plug.
Please rate this solution. Thanks!
Apr 19, 2009 | Honda XL 125 R Motorcycles
Bike wont start
First thing > install a new set of the stock NGK spark plugs for your bike. Check for spark before installing. If no spark, then check to be sure the battery wires are clean and tight. Is the kill switch on? Is the side stand up? It should be up when starting. Is the bike in neutral? Check the fuses. Check the wiring connections, are they tight?
If spark is present, is the gas turned on? Clean or replace the air filter. If the bike still will not start go ahead and drain the
carbs. There should be a screw on the lower side of each carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carbs to fill with gas. If the bike doesn't start properly then shut off the gas and remove the carburetors from the engine.
For both
carbs > remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray all the little airways and fittings in the carb. Remove the two screws on the outside throat of the carb and spray into the screw holes as well.
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the
carb back together. Remount the carbs.
Next, remove the water trap bowl at the bottom of the petcock, (gas valve). Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ). Turn the gas back on to let the float bowls fill then start the engine. Be sure to balance and sync the carbs when finished. If you don't know how to balance and sync the carbs, get back to me after you do the stuff mentioned above. This process should get you back on the road.
Please rate this solution as " FixYa " if all goes well. Thanks!
Mar 28, 2009 | 2008 Harley Davidson VRSCAW V-Rod
Bike wont start
sounds like carb issues, check fuel contamination and **** in carb first.
Mar 22, 2009 | 1998 kawasaki KDX 200
Hi i have a cr125 on a 96 it starts with a bump and when warm kicks up quite nice but now it wont start at all i have tried a new plug got a spark ,compression is fine, plenty of fuel ,drained the carb...
You may need a carb kit. Sputtering is usually one of two things. 1) bad seals in the carb, install a kit.
2) water in the fuel.
Clean the pitcock water trap, check the air cleaner, drain the carb
The generator stuff sounds pretty weird and off the wall.
Mar 14, 2009 | Honda CR 125 R Motorcycles
Pw50 problems stating bike
hey there matey,, just to run a few things with,, have u taken the spark plug out and cleaned it up,,try a new plug 1st,, to be sure, or if u have a new plug,, take out the spark plug place it back in its cap and rest it on the cylinder head and either elec start it or kick it over and make sure u have a spark ,, if all is ok on the above,, then turn to fuel and carburetta, make sure fuel is gettin to the carb 1st,, but u say u do eventually gettin it goin ,,then theres a blockage in jets ,,undu the bottom of the carb clean out the bowl, ,in the carb u will see a brass jet, un screw that and the needle guide that the jets screwed in to and using a pin or needle,poke the small hole clean so u can see light threw them,, bung it all back together and pray,, if no joy il get back to ,, ok m8, enjoy
Jan 10, 2009 | Yamaha G5 Motorcycles
Pit SSR 110CC Pro Beginner  Bike Logo
221 people viewed this question
Top Pit Cycling Experts
john h
Mack Baxter
Tim Rickards
Tim Rickards
Are you a Pit Cycling Expert? Answer questions, earn points and help others
