Question about Sony KP-53V80 53" Rear Projection Television
Working fine next day red light on solid
I have a sony kp53v80 was working great turned it off last night when i went to turn it on today nothin happens no picture no sound the red light on the front is staying on as if the tv was on....has anyone run across this problem or know of a fix? Thank you and have a nice day ......Dan
  • vagrant Jan 08, 2008
    tv kp53v80 turns red light on and blinks but no pic,no sound and wont even get on screen menu
  • Anonymous Apr 19, 2009
    worked fine, next day standby light on solid no vid or audio. Unplug and repower, relay click click and solid light, nothing else.
I have this same problem
Posted on Dec 19, 2008
  • Sony Master
  • 5,138 Answers
Shorted hori output transistor and bad 1200pf 2k volt capacitor.
Posted on Feb 01, 2008
SOURCE:
My sony trinitron is blinking red and won't turn on
THIS IS NORMALY CAPACITORS IN THE POWER SUPPLY THAT NEED REPLACING
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Screen turned solid red, and tv shuts down . worked fine last night.
Most likely cause of that is a red CRT has shorted which will shut the set down.
Mar 04, 2010 | Sony KP-46WT500 46" Rear Projection...
My ps3 will not turn on. it tries but then the light just starts blinking red. it was working fine last night though
It sounds like a power cycle is needed. If you are using a power strip, please turn off the PS3 and then the strip. Count to 30. After 30 seconds turn the strip back on, followed by turning the PS3 on.
Hopefully that will solve your issue. Hope this helps and have a great day!
Feb 17, 2010 | Sony Playstation 3 (PS3) Console
TV makes a spinning noise coming from the lower right side.
If there is a red light blinking that means that the projection light needs to be replaced.
Jul 26, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
RED BLINKING LIGHT ON HITACHI TV CANNOT TURN ON
Check the resisters, that could be the burnt small, also you may need to replace the ICs
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Mitsubishi wd-65831 one night worked fine next day nothin..
If you hear a whining noise, the odds are it is the color wheel, the bearings are bad in it and will need to be replaced as a whole unit, kinda pricey, my suggestion, sale the bulb and all boards in it and which should fetch about 400+ and invest in a new TV, a color wheel is pricey unless you can find a deal
Dec 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Power light blinking continuosly
First off check your lamp or replace it. You can never have too many lamps..........in the last minutes of overtime ! Are you kidding Me! If lamp doesn't work, you will need to find qualified servicer. Try craigslist or tv repair in yellowbook
Craig www.classtorations.com
Jun 08, 2008 | Hitachi 70VS810 70" Rear Projection HDTV
Ps2 wont turn on
it might be the disk...when the ps2 cant read the disk sometimes it justs turns off...mine does the same thing....when i put in a another disk it works fine
May 17, 2008 | Sony PlayStation 2 Slimline Console
SONY KP51WS500 bought Feb. 2003 from Circut City
possible clod solder connection in the scan b+ voltages,contact sony and get them to check their dealer store locations in your area and have them send a message to the dealer describing your fault to them also.
Aug 06, 2007 | Toshiba 43H70 43" Rear Projection...
Sony KP-53V80 53" Rear Projection Television Logo
183 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
