Question about EliteGroup 661FX-M7 (661FXM7V11) Motherboard
Installed a new Saphirre Radeon x1650 512mb, 128bit, AGP 8x card. But I am not seeing a significant increase over the onboard graphics. The card install sheet says to Disable the onboard video, but I don't know how to do that. Any help?
  • 6 more comments
  • spencermcint Apr 16, 2009
    I did go into the BIOS, but all I saw was options to alocate memory to the video. There was something about AGP slot but that had options of 4x or 8x. I don't see where I disable the video or tell it to find something else first.
    Awesome, I am looking at it in my manual now. I did see those last night just wasnt sure what they was. Now what about the AGP Fast Write Support, default is Disabled, does this help anything? for that matter those other settings in the AGP & P2P Bridge menu.
    Awesome thanks for your help! can't waitto get home and try them.
  • Anonymous Apr 17, 2009
    Tried what you said when I got home and it made it worse. I tried loading Optimized settings, it changed it to a PCI slot and some other changes. But it still sucks for video.
    I did what you said, it made it worse. I loaded Optimized settings but it still sucks. I was getting better graphics without any cards.
    Did that. The only thing showing in DM under video adapters is the new card. Primary and Secondary. In the BIOS there are two options for INT DISPLAY FIRST: AGP or PCI slot. When I set the optimized defaults it changed the setting from AGP to PCI slot, I thought that ment: AGP = onboard graphics and PCI slot = External Card. but I have worse graphics now than I did without the card.
  • Dick
    Dick May 11, 2010
    Onboard graphics are disabled via the motherboard's BIOS. As the computer is booting press the delete key immediately and repeatedly until you get into the BIOS. Then disable onboard graphics and tell it to look in your AGP slot first.
    President:
  • 948 Answers
In your BIOS on the main screen choose INTEGRATED PERIPHERIALS (get a copy of your manual here if you don't have one), then go to INIT DISPLAY FIRST, and choose AGP. It's not clear from the manual if AGP is an available option, choose PCI slot if it is not. ECS is notoriously sloppy with their BIOS programming.
While you are in the BIOS, under ADVANCED CHIPSET FEATURES choose AGP &P2P BRIDGE CONTROL then make sure your AGP DATA RATE is set to auto.
Posted on Apr 16, 2009
  • Dick
    Dick Apr 16, 2009
    The other settings in that menu I would not change unless the manual for your video card mentions them.
  • Dick
    Dick Apr 17, 2009
    I'm going to assume that you followed the instructions, then booted into Windows and installed your video card drivers. At that point the quality was poor so you went back into the BIOS and tried optimized settings. If that is NOT what you did, follow my directions below.
    Ok, boot into Windows and go to your device manager. Expand the box with the + sign next to DISPLAY ADAPTERS. What display device is shown there, your onboard or your new card? If it is the onboard, right click the adapter name and go to properties. On the general tab go to the bottom and change the drop-down menu to DO NOT USE THIS DEVICE - DISABLE. Click OK, shut down your computer, then reboot, set your BIOS to look for your AGP card and when you get into Windows use the disk that came with your video card and install the video drivers.
    Post again if that does not take care of it.
Can I use a AGP 8X ATI Radeon 9550 256MB 128bit Video Card in my pc?
No. The mainboard you are listing is not capable of AGP cards. AGP cards have gone the way of the dinosaur. Modern mainboards do not have AGP-compatible slots anymore, only PCIE 1x, 8x, and 16x slots.
Jan 09, 2016 | Intel Desktop Board DG41TY - Classic...
When i connect my graphics card to my pc i get a black screen there is no beeps and i cant even hear an windows sound. when i disconnect my gpu my pc works fine i have tried to disable onboard graphics...
Hello xvanpersiex, these are "Full Specifications" of your [Graghis Card].
"Check this to the 'Specs' of the "Motherboard to see if it 'Supports' the Graphic Card?"
"Try 'disconnecting, and reconnecting' the "Graphis Card"
Verify that 'all' the "Connections" are "Tightly Inserted."
*Go to the Control Panel > Device Manager > AGP Graphic Card > Verify Installed? >
Update Driver! > Restart Computer"
"If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9"
ATI Radeon X1650Pro (AGP 8x, 512MB) General
  • Device Type Graphics adapter
  • Enclosure Type Plug-in card
  • Vista Capability This graphics card is capable of running the new Aero interface featured in Windows Vista Home Premium and higher.
  • Interface Type AGP 8x
Processor / Memory
  • Graphics Processor / Vendor ATI Radeon X1650 Pro
  • Graphics Card Performance This card's graphics processor and memory mean that it is not recommended for most games, but it will still be fine for office applications and other normal computing tasks.
  • RAMDAC Clock Speed 400.0 MHz
  • Video Memory Installed 512.0 MB
  • Technology DDR2 SDRAM 128-bit
  • Features Avivo Technology
Video Input
  • Type None
Video Output
  • API Supported OpenGL 2.0,
    DirectX 9.0
  • Max Monitors Supported 2.0
  • TV Interface HDTV out
  • Analog Video Format S-Video,
    Composite video
  • Digital Video Standard Digital Visual Interface (DVI)
Expansion / Connectivity
  • Interfaces 1.0 x DVI-I (dual link) - 15 pin HD D-Sub (HD-15),
    1.0 x HDTV output - 29 pin combined DVI,
    1.0 x VGA
  • Compatible Slots 1.0 x AGP
Miscellaneous
  • Microsoft Certifications Certified for Windows Vista
Software / System Requirements
  • OS Required Microsoft Windows XP,
    Microsoft Windows XP Media Center Edition 2005,
    Microsoft Windows XP 64-bit Edition,
    Microsoft Windows Vista
  • Recommended Power Supply 350.0 Watt
  • Peripheral / Interface Devices CD-ROM
Feb 22, 2011 | ATI RADEON X1650 Graphic Card
Nvidia geforce2 mx4oo vreau sa o schim cu una mai mare
Uite una excelenta
http://www.emag.ro/placi_video/placa-video-sapphire-ati-radeon-hd-4650-1024mb-gddr2-128bit-hdtv-agp-8x--pSPHHD4650HT1G-11156-01-20R
Feb 21, 2011 | Nvidia GeForce FX 5500 Video Card Graphic...
Wie disabled man die onboard-graphic? Ich möchte eine Radeon X1600 mit 512 MB in den AGP-Slot einsetzen. How disabled the onboard-Graphic? I want use a Radeon X1600 in the AGP-Slot
Just plug in the Radeon video card in the agp slot and the system will automatically detect the new video card and disable the onboard-graphics.
Oct 30, 2009 | Computers & Internet
Looking to upgrade my graphic card one last time. Currently running a RADEON X850 AGP 8x. Dell XPS, 3 GHz Pent4 w/875P chipset.(800MHz Bus Clock, 400MHz DDR, Hyper-threaded (2)-- I would like the highest...
I wouldnt know whether you just like ATI Graphics cards, or it was recommended for you. But I would still give you my straight forward advice, and this is : Go for NVIDIA Ge-FORCE graphics cards. Trust me, you would thank me for it later.
I didnt want to recommend a specific model for you though, because of our difference in country locations, but just try and get a high memory (like 256MB and above), NVidia Graphics card that is compatible with your system. Also check out the available slot on your system that you will use for it first before you go (So that you wont go and get an AGP slot card when you have just an open PCI Slot). I'm telling you this because I've used A LOT of graphics cards also (Over 10 years now)! and I've come to that conclusion that NVIDIA makes the best graphics card.
Hope this helps you out.
Jul 15, 2009 | ATI AGP8X (128 MB) Graphic Card
Is visiontek a radeon hd 2400 pro agp 8 compatible w/ p4s800- mx?
ATI has recently written some better drivers for the 2400 Pro AGP cards,... Make sure the setting in the BIOS for the motherboard is set to the AGP or PCI for primary video. For AGP, make sure that you have the power from the power supply connected to the video card. Make sure that your motherboard does support 8X AGP video cards. If you are not sure, please check with motherboard manufacturer for compatibility.
Dec 13, 2008 | VisionTek ATI RADEON HD2400 Pro Edition...
Blank White Screen.
cpu restart after first log on
Sep 06, 2008 | Sapphire RADEON X1550 Graphic Card
Graphics card support to motherboard D845GBV
AGP 2.0 and 3.0 4x and 8x feed with the 1.5v spec. AGP 1.0 1x and 2x was fed at 3.3v. In short, you should be fine.
May 15, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
EliteGroup 661FX-M7 (661FXM7V11) Motherboard Logo
174 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
