Power pack beeping, no lights turning on
I have a Toshiba A100. it was working fine up until a couple of days ago. then the power started cutting out randomly. now it will not turn power on at all. no lights light up or anything. and the power back is making a high pitched beeping noise. any way i can fix it??? or do i need a new laptop? thanks!
    Problem Solver:
  • 12 Answers
Unfortunately your laptop is suffering from hardware failure. You may try removing the battery and using only the power cord.If this solves the problem then you either have a defective battery or bad power circuitry on your laptop. Aside from that if its still under warranty sending it to Toshiba for repairs will be your safest and cheapest option.
Posted on Apr 16, 2009
Toshiba laptop will not turn on
The motherboard might have died. If lights come on but nothing happens this is usually the case. The best suggestion is pull the hard drive out and get an enclosure. This will allow you to put the hard drive on another computer and pull the files. You should probably take the hard drive out when buying the enclosure to ensure proper connection.
Aug 11, 2009 | Toshiba Satellite A60 Notebook
Motherboard problem
Most likely the contact point of your battery pins are not snug enough. If under warranty, then replace the battery, else give it to a technician to do this clean-up operation. Try another battery too to crosscheck!.........sodeep
Mar 10, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satelite A100 no power at all
The ac power pack may be faulty, check it with a multimeter, the voltage should be slightly higher than the voltage printed on the label on the power pack.
If you can borrow another working ac power pack (has to be the same as the ac power pack), test it on the laptop.
Also reseat the RAM modules and the hard disk and see if it boots up.
If it is a bin job remove the hard drive, if the hard drive is OK, put it into an USB drive case and use it as an external hard drive.
Feb 17, 2009 | Toshiba Satellite A100-S8111TD Notebook
Remote wont make truck start?
ok this happend to me once take the key and stick it into the ignition and turn it 8 times only turn it untill the lights go on DO NOT START THE ENGINE EACH TIME after this try it again
Jan 06, 2009 | Crimestopper RS1505DP CoolStart(TM) FM/FM...
My Satallite A100/A105 Laptop computer fails to come on at all.
Remove the battery pack and power up the laptop from the mains only....then replace the power pack when the machine has booted
Nov 24, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba A100 Power problems
here are few laptop troubleshooting guide to troubeshoot ur laptop. it has one post about power problem of laptop.
I hope this laptop troubleshooting help to solve ur problem. or chekc ur laptop with another working battry or try to start laptop to without battery. and chekc ur power cable for charging is working or not
May 05, 2008 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
288 people viewed this question
David Payne
David Payne
