Question about Metabo W14 150 ErgoD Angle Grinder
AFTER USING FOR A WHILE THE POWER CUTS OFF.
THE GRINDER SHUTS DOWN AND SECONDS LATER STARTS AGAIN.
  • 226 Answers
The grinder is shutting off because of the temperature overload switch. This is normal if you are using it for a long time. Sometimes these switches go bad and need replaced as the grinder shuts off after 15 seconds or so. I don't reccomend disassembling the grinder and bypassing this, but it can be done. Hope this helps you, Rick
Posted on Apr 29, 2009
    Problem Solver:
  • 14 Answers
You may want to verify the model you have. in the question it says W14 150 Ergo. this grinder does not come offered with any electronics. This is very important to help with your situation.
Posted on Oct 08, 2014
While using my dewalt 7amp small angle grinder (using it on and off about an hour grinding hard walnut wood) I heard a pop inside the unit so I turned it off, then a few seconds later turned it on again it...
burnt out the motor
the fix is a new unit
when grinding or sanding you use light pressure and let the disc do the work
change or unclog the pad or disc on a regular basis
for fast rip down use very course then finish with a fine pad
Jul 31, 2017 | Dewalt 65091601 Brush Set D28110 D28112...
Flat panel TV comes on by it's self
It sounds that the voltage output from its internal power regulator board is not proper. Check it.
Feb 04, 2013 | Samsung UN19D4003 TV
E machine monitor turns itself off and on
The same thing happened to me today. I was just sitting in my room then i hear a click and the cpu is on it stays on for a while then cuts off. It then cuts on and off with few seconds in between. It then stays in that way cutting and off for about a minite or two and then cuts off completely. A few minutes later it starts again. Also in the time it its off it will not turn on by pressing the power button. Sometimes it completly boots up by itself and then shuts itself down. If I shut it down manually while its on it'll turn itself on immeditaly after. What's going on! Will the warranty cover it? Do I need a new computer?
Feb 01, 2010 | E-Machines eMachines Monitor E15T4
Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
May 09, 2009 | Compaq Presario R3000 Notebook
Neptune MAH3000AWW will start to fill when start is pressed, but stops seconds later
either a faulty pressure switch / pot or faulty controller - either way you will need to call someone in.
Jul 24, 2007 | Maytag Neptune Washer
Metabo W14 150 ErgoD Angle Grinder Logo
463 people viewed this question
Top Metabo Saws Experts
Vernon Taylor
Spud Howell
JOHN LAPIER
Are you a Metabo Saw Expert? Answer questions, earn points and help others
