Parallel dongle will not work with new system that only has USB connections
I have a Designer 1 with a paralle dongle. I now have a new computer and parallel connections are no longer available. I purchased a USB to parallel convertor cable and it appears to be mapped to LPT1. The software does not see the dongle. I am using the VIP software. Is there a setting somewhere that I need to check to see why the dongle is not found.
  • 3 more comments
  • nisnoger Apr 16, 2009
    I have a new Dell Inspiron 1545 and I can not find how to change or check the BIOS settings.
  • nisnoger Apr 17, 2009
    Service tag # is 19K09H1.
    Geekman, thanks for the reply, but neither Viking or the software supplier seem to want to respond to requests. Sent messages a month ago and then again this week. No response.
  • nisnoger Apr 28, 2009
    WE tried a PCI card and the dongle is still not found. So, it looks like we either maintain the old system, upgrade to the latest software or find new software that does not require a dongle.
    We are very disappointed in the lack of response or support from Husqvarna.
    Thanks for all responses.
  • mr Overland May 11, 2010
    i get laptop info from Inspiron 1545 model
    would need the DELL service tag#
    to corectly ID your system
    need to check bios an turn on USB ehci controlier
    also load your dongle driver for your OS
  • 43 Answers
Those dongles will only work on a PC that have a "legacy" parallel port. Adapters will not work and even a PCI parallel port card will not work. The drivers that access those dongles were written to access the hardware(PC) directly with the old parallel ports at their real hardware address and not through the Windows OS as an LPT.
You may want to check with the vendor that supplied the dongle if they have a USB replacement as most vendors have gone that route with their dongles.
Posted on May 14, 2009
  • 32,281 Answers
The dongle only works with a standard parallel port, not a USB parallel port adapter, It may be possible that a PCI parallel adapter card will work with the dongle. Check it first with the supplier and or software supplier of Designer 1.
Posted on Apr 17, 2009
  • Chris Hingee
    Chris Hingee Apr 18, 2009
    See if you can borrow or buy on condition of refund if it doesn't work a PCI LPT1 prnter port card. Otherwise you need to use a older computer with a standard LPT1 printer port.
I have a Husqvarna designer 1, I have windows vista on a newer computer with only usb ports. How do I hook up a parallel port dongle for customizing pro system 5 to my computer?
Here's one source for a cable: http://www.cablestogo.com/category/usb/usb-adapters/usb-ieee-printer-adapters?gclid=CPCq8pL-_LQCFQyDnQodFVMAbQ
I suspect this is only the start of your problems and that your software would really work best with an XP operating system. You may want to get an old laptop computer with XP and dedicate it to you sewing machine. Check computer shops that specialize in rebuilding and selling used computers. You should be able to get one for $100-150.
Nov 29, 2012 | Husqvarna Designer I
This printer is no support with create-a-label
If you are using CAL (Create A Label) you must have a device called a "Dongle" plugged into your parallel (or USB) port. This acts as the activation key for CAL. If there is no dongle then CAL only works in demo mode. That's why printer Icon stays grayed out. The "Dongle" normally plugs directly into the parallel port and one end of the parallel lead plugs into the "Dongle" while the other plugs into your printer.
I would suggest that you download "Zebra Designer" software from the Zebra Website..This will work without any activation.
If you use ZD you must use the correct ZDesigner driver. (Install automatically as part of ZD setup) This driver only works with ZD.
If you need to link to a database then you will have to BUY label software. Zebra Designer Pro, or Nicelabel, or Bartender....etc.
Jan 10, 2011 | Zebra LP 2844 Thermal Printer
I just installed my designer software onto a new computer that doesn't have a 25 pin printer cable, however, I bought a usb/25 pin cable and have the dongle attached...but the software says the dongle...
Your software still is looking for the 25 printer pin connection from the motherboard. I don't know computer set up from an engineering concept, but I do know that the usb connection you purchased doesn't work with that software. You'll need to either get the new software or a used computer with the printer port hook up.
Nov 01, 2009 | Husqvarna Designer I
What Version of VIP customizing is for Designer 1 USB stick
When you purchase the Husqvarna Viking software it comes with a code key called a "Dongle". It plugs into a usb port and "unlocks" the software. You can't just load the software and have it work without the dongle and you cannot just purchase a dongle. That software is about 3 versions old and is not being supported anymore by Viking. Their new software starts at $400 and is called 4D embroidery. Their web site shows what it can do.
May 21, 2009 | Husqvarna Viking 1
MY SYSTEM DOES NOT HAVE A PARALLE PORT...
you need to purchase a pci parellel port card this page will give you an idea of what i mean
http://sewelldirect.com/ParallelPCICard.asp
Mar 23, 2009 | Computers & Internet
LP 2844 not working with Create-A-Label v3.04
Oct 07, 2008 | Zebra LP 2844 Thermal Printer
Connecting Reader Writer Box To New Computer
After checking with the Dealer, I was told my old Reader/Writer Box & embroidery software is not compatible with Windows Vista. I will have to purchase a new R/W Box which has a USB cable & a different type of dongle.
Feb 20, 2008 | Husqvarna Viking 1
Dongle issue
The Designer SE software does not use a dongle. If you are attempting a "Smart Update" on the Designer SE and it asks if you use a dongle, just say no and the update on the machine will run.
If you have 3D or 4D software, it uses the dongle and it will be USB. Download the latest driver for your software from the Husqvarna Viking website. The link is through the homepage at Husqvarnaviking.com/us . Click links on the left side of the screen for 4D Software, Help & Updates, and Other Useful Software at the bottom of the page. This will have the latest 3D driver. 4D will require the latest update to the software and a firmware upgrade to the dongle. Run Smart Update on the software and then get the firmware update that is directly below the 3D HASP driver on the Other Useful Software page.
Nov 09, 2007 | Husqvarna Designer I
Open Questions:
Computers & Internet Logo
930 people viewed this question
David Payne
David Payne
