Question about RCA G35851LA 35" TV
Vertical My tv just starting to give me problems. If your looking at a door or straight lines they bow in and the text bar's at the bottom of the screen seem larger. If your watching sporting events you can't read all of the text some disappears off the screen.
  • 372 Answers
Hi. Im not at all familiar with your make of TV set, I am in the UK we dont have RCA make of TV. But what you are discribing is an East/West fault this is a common problem on all TV sets. It could be quite a few things that can cause this eg (make adjustments in engineers mode, E/W coil burnt up, Resistors or caps burnt up) Its not an easy repair for a novice to tackle It requires fault finding & being able to read A meter. Usually not exspensive to put right by A shop.
Posted on Sep 16, 2007
Colours split and vertical bowed green line at to and bottom of s
This is a convergence problem that can be either poor solder connections at the convergence ICs or defective ICs. If you can solder and feel comfortable working inside the set where there are potentially dangerous high voltages, update this and further details and instructions will be provided.
Thanks,
Dan
Dec 12, 2008 | Samsung HLN5065W 50" Rear Projection...
Toshiba CX32G60 1/2" vertical inward bow center of video
change the electrolytic capacitors in the vertical section of tv. you do need a qualified tv tech to do this repair for sure
Nov 30, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Tv bows
I have the same TV and just finished having my TV repaired for the same problem. I was unable to converge the colors even in the advanced convergence setup menu. The lines were bowing so far that adjustment was not possible. I had to replace the vertical and horizontal convergence controllers located on the main electronics panel. They require a lot of soldering and should be done by a professional. Unfortunately this is a common "maintenance" repair that happens every 5-7 years, depending on the usage, costing around $500.00 for in home repair. DO NOT USE YOUR TV IF THE CONVERGENCE IS BAD AS IT MY CAUSE THE POWER SUPPLY TO BLOW resulting in addition repair costs.
Sep 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Slight bowing of picture
Only on newer TV's, yours (I dont think)has the adjustment, if it does it would be in the menu area.
Apr 22, 2008 | Sony KV-36XBR450 36" TV
Vertical black lines
I want to know the possible cause of tv with 2 black line at the top and bottom of the screen. Is it have the same causes even if the tv model is not the same..thanks
Dec 19, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Picture too tall. How do you shorten?
Picture displaced vertically, picture too high or low
This problem was cured by entering the service mode (menu then 4,7,2,5), then pressing the green fastext button to access geometry settings, selecting VP1 (vertical position) and adjusting as necessary
Very low width and bowed verticals,no ew correction. R626 o/c
C630 (390nF, 300v) faulty, located next to scan socket. This fault can also be caused by R629 (2R7 fusable) o/c. In my set C630 was dry-jointed but not faulty. Check generally for dry joints in the E/W and PSU areas. Note that R629 is a safety component
Nov 23, 2007 | Sylvania SRT2432S TV
Blue haze around image, yellow streak
the tv color circuit is off frequency change the color ic take a look on the crystal that gives the 4.8.mhz burst could be that it needs to be replace dont rule out the video IF change the two ICs you mention.good luck.from the look of your tv screen that is my conclusion.good luck.email me at nicodhem@yahoo.com
Apr 04, 2007 | Samsung HC-P4241W 42" Rear Projection...
Sony FD Trinitron WEGA KV-36HS500 36" TV - Bowed Picture
it sounds like a convergence adjustment problem. If you hava book on the tv still read it, and it will tell you what to do, other wise, look for a convergence button on the front of your tv, and take the remote and push menu to bring up setup, and go convergence adjustment click it and hit the conv. button on the front of the screen. there should be to lines going vertical and horizontal, these are the limes you adjust with your remote, you have to adjust the red and blue, the tv should blink to let you know which color you are on. when you have them lined up right the line will be perfectly white. hope this helps
Jan 31, 2007 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Convergence
You need to most likely replace the convergence output IC's probably STK392-110's and check associated resistors around it. HD is not mandated for 2009, only digital braodcast it is at that point all analog television broadcast must stop.
Jan 21, 2007 | Hitachi 46UX50B 46" Rear Projection...
Televison & Video Logo
44 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
