Question about Brother HL 5250DN Laser Printer
Can smears when priting be fixed
When printing there are three dots on the left hand side of the paper and now there has been black smears with each print. I changed the printer cartridge to see if that would help, There are still dots and the smears are more consistent. How can this be fixed?
  • Anonymous Apr 23, 2009
    I also have the three dots showing up on the right hand side, but no smearing. It's frustrating when I have to print out legal letters!
  • nconway May 09, 2009
    I also have a similar problem. I show lines on the left side of the paper when printing. I purchased and installed this today. I have tried printing several times.
  • 37 Answers
Have you tried cleaning the corona wire on the drum unit (the blue slider bit)?
Replace the drum unit (assuming you have already replaced the toner cart?)
To check the remaining drum life press the go button 3 times. A report should print out with the info on. Even though you may have some remaining life, the drum can fail early.
If the dots/marks are repeating about 3 times down the page it is almost certainly the drum unit that has the problem.
Posted on Jun 19, 2009
Ricoh aficio 2075
R u using original toner? if no, replace ori. if yes, r the hot roller in the fuser hot enough? is there any gap between hot roller and pressure roller? toner smear can only be caused by non ori toner or faulty fuser unit. Faulty developer can cause sandy print out
Mar 22, 2014 | Ricoh Office Equipment & Supplies
DELL 3100 CN LEAVES DOTS ON LEFT SIDE OF PAPER. when the paper is printed there are black dots even spaced on the left hand side of the paper
replace the drum unit, if the problem persists check the Leser unit (unit scan), open it and clean the mirrors and lenses gently with alcohol and toilet paper
Oct 27, 2011 | Dell 3100cn Laser Printer
Black dots are printing on the left hand side of the page when I print from my hp laserjet 1015. Any ideas how to fix this?
Run a "half test". Put paper in the manual feed tray. Print anything. Watch the paper, when it feeds about 1/2 way into the printer, open the cover. Pull out the toner and look down at the paper. If it has the dots, replace the toner. If it doesn't have dots, the fuser is probably bad.
Aug 31, 2011 | HP LaserJet 1018 Printer
The printer is printing little black dots on my documents
If the dots are all over the paper you may need to replace your toner cartridge. If the dots are smearing, you may need to check your fuser assembly (have it checked by a professional).
Oct 06, 2009 | HP LaserJet 1012 Printer
4 colour dots on printout but not 150mm apart
Measure the distance between two of the same coloured dots down the page, if it is just over 150mm then it is caused by scratches on the photoconductor drum (this is the only thing that has a 15.4mm circumference). Try printing a black and white only document, only the black dots should appear. Removing the photoconductor and gently polishing the blue drum with a soft cloth can help if the scratches are not too deep, otherwise a new photoconductor is the only route.
Sep 06, 2009 | Epson Aculaser C1100 Printer
It prints three dots on the left side of the page every time.
These dots may be called as "Garbage Valley"
This means ur printer has got lots to print but it was stopped due to certain reason.
I'll ask u to go through ur printer manual & print atleast 5 pages of garbage valley & while u do this, i'll ask u to reinstall ur printer driver.
Hope it works out.
Thanks
Sep 01, 2009 | Brother HL 1440 Laser Printer
Black ink smears everything.
you may have to clean the print head. since the jam cause the smear, and there still have some ink left on the print head.
you wouldn't get aclean copy till all of the ink trace are gone.
May 20, 2009 | Canon Office Equipment & Supplies
Printing problem
the problem exclusive between the drum or the fusser unit
Apr 25, 2008 | HP LaserJet 2550L Printer
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
Colors faded on left side of paper black and blue
Is it possible for you to clean the printheads manually with cotton buds and cleaning solution on this unit. Clean all thoroughly and this might just correct issue.
Sep 01, 2007 | HP Color LaserJet 3500 Printer
Brother HL 5250DN Laser Printer Logo
714 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
