Question about Lexmark X5470 All-In-One InkJet Printer
The paper is not feeding properly on my printer.As it advances the paper crumples or tilts at an angle and then just stops. A paper jam message appears. Solution Attempts. 1. I turn the machine upside-down and tap it at the sides to shake out any obstacle that might be blocking it. NOTHING! 2. I use a flashlight to visually inspect for any paper or debris that may be blocking the path of the feed. I see Nothing!
  • Lexmark Expert
  • 228 Answers
Most of Lexmark printers (including the Z- and X- series) pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print the self test page.
Please follow the steps given below to perform the self-test:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Posted on Apr 16, 2009
Paper mismatch officejet 6500 crumples
There could be a foreign object or torn piece of paper that's stuck further inside the printer mechanism path. Try using a flashlight and inspecting any access or clean out hatches. Sometimes something will be caught inside and cause the paper you feed in to crumple and create a jam. I watched a video on youtube giving different ideas on how to fix this problem. Fixing Paper Pick-Up Issues
May 27, 2013 | HP Officejet 6500 Wireless All-in-One...
Lexmark Prevail Pro705 printer jams each attempt to print. Reasonably new, Lexmark just replaced printhead and ink cartridges under warranty and printer gave better print results than when brand new. Joy...
Make sure your printer is updated. Please visit the Lexmark website to download and install the Lexmark Pro700 Series Firmware Update on your computer. The update will make your printer more reliable and more efficient.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 13, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
It's not feeding the paper - its crumpling up on the right side and going in on an angle, but not feeding. Thoughts?
If you had a previous paper jam, there is probably a shred of paper still stuck inside on the right. You may also have another foreign object such as a paper clip in there - this is more common in top-feed designs than others. The tricky part after finding it is getting it out - you may have to do some disassembly. I've had to use a dental pick and a mirror in some cases.
Jun 17, 2011 | Canon PIXMA iP3300 InkJet Photo Printer
Paper does not feed through, gets crumpled, jams
you have to remove all covers, then you have to clean all paper feed rollers..chek fuser assy too! If you unable to do that just go visit any special printer service!
Apr 05, 2010 | HP LaserJet IIIp Printer
The paper won't feed through. it did one minute then stopped
This is sort of scenario could be caused by dust inside the printer. Dust prevents the rollers from having a firm grip on the paper while picking paper. When one roller has a firm grip and rolls the paper well while the other doesn’t, crumples result. So I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). This, if properly done should do it. Brush especially the rollers etc.
Dec 06, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Have a hp laserjet II P printer. paper feed not
drum drive gear is broken that is why it is jamming
Nov 18, 2009 | HP Office Equipment & Supplies
Paper won't feed properly- feeds at angle and jams. Printer indicates that it is out of paper.
"paper won't feed properly- feeds at angle and jams. Printer indicates that it is out of paper."
I am having the same trouble, what was the solution?
Oct 15, 2009 | Canon PIXMA MX330 Multifunction InkJet...
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
Paper feed
Your printer is politely asking you to please get a torch, and open the lid of unit and thoroughly check inside all over for a tiny jam of paper or something else. I am willing to bet you will find some jam. I would also switch it off, and wait a while before turning on and printing again. Good luck
Aug 31, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Lexmark X5470 All-In-One InkJet Printer Logo
385 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
