Question about Kenmore Washing Machines
Water spews out drain when washer is draining
When spinning water out of washer water spews out the upright drain pipe
  • Jimmy James May 11, 2010
    make sure the hose has not worked it self out
  • 297 Answers
Call one of those sewer boys, partially clogged I would say.
Anymore drainage problems in the house.
To avoid costs could try to clean the water lock.
Ask price on before hand, avoid night weekend calls.
Posted on Apr 16, 2009
My front load washer do not spin
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp that connects the trap assembly to the pump and clean it out. If helped, pl say so.
Apr 01, 2013 | Frigidaire FAFW3801LW Front Load Washer...
MY WHIRLPOOL WTW5300SQO WASHING MACHINE WONT DRAIN WATER THE OTHER DAY IT WOULD NOT SPIN TO WRING THE CLOTHING THERE WAS A SMALL GARMENT LODGED IN THE SPIN BASSIN(?) WE TOOK IT OUT NOW THE WASHER WILL NOT...
Could be filter is blocked. Or drain pipe is blocked.
Fact it wouldn't spin, could point to blockage, as spin won't start if too much water in drum. Bad news is, it could be the water pump needs renewed.
Make sure drain pipe is properly connected to the waste pipe, and clear of obstruction.
Jan 16, 2013 | Washing Machines
Standing water in the washer hours after wash cycle completes
YES..I think drain hose @ sink too low Waste water from sink entering machine...Raise pipe....tie up ....
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer still has lots of water in it at the end of the spin cycle. Also, we notice bad oder each time the washer is used. Are these related? How do I fix this problem?
The most common problem is the water pump is malfunctioning and not allowing the water to drain all the way out, if the machine sits over a week the water turns sour and smells bad. so check that the pump is not plugged up and check that the pipe from the pump is not plugged up. if hose is not plugged up and the belt on the pump is tightened up it could still be a bad water pump so I suggest you replace it. Also with a water hose push water threw the drain pipe in the wall to see if the pipe is plugged, it should take full water hose pressure without a problem, if it backs up then you have a plugged drain pipe. remove the drain pipe form the hole in the wall and push hose onto the water hose put washer on spin and have other end off the hose bib, watch the water flow as it pumps water out of the spin cycle if the water does not come out fast than you have a bad pump or a bad water pump belt. since it won't drain all the way this will cause the water to smell sour.
Dec 13, 2009 | GE Washing Machines
Washer spin but water do not stay in drum
Sounds like your drain is laying on the floor, or your stand pipe is too low, or the drain hose is too far down in the stand pipe. The drain must be at least as hi as your water level in the machine at it's fullest level, otherwise it will just siphons out almost as quickly as it fills.
Hope that helps,
Good Luck.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Washer won't spin or drain the water
There is something inside the drain pipe that block your water outlet.
Jul 11, 2009 | Roper RAS8445KQ Top Load Washer
Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washer Will Not Hold Water
What height is mentioned in your manual for your drain pipe (the outlet pipe for your machine) There should be a height (before u bend it downwards into the drain) or the water will just flow out........... And do not over-load your washer.
Apr 24, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
67 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
