Question about Dremel Variable - Speed Multipro Rotary Tool 395
Variable Speed Control is faulty
I can't seem to get the full range of the speed control to power my tool anymore. It intermitently works as I slide the speed control to different speeds. I'm thinking that the speed control needs to be replaced. Does anyone have any experience replacing this part?
  • 154 Answers
Unfortunatly Dremel who is owned by Bosch has discontinued that tool and parts are no longer available.
Posted on Apr 16, 2009
  • Corey McConnell
    Corey McConnell Apr 16, 2009
    Its not a very hard repair, if you decide to go that route let me know and I can walk you throught it.
  • John Rumming Oct 10, 2010
    Check out the Dremel forum and they tell you how to take it apart to fix it.http://messageboard.dremel.com/Topic4517...
    John
What is the difference between a variable and non-variable speed sewing machine foot control?
variable foot control==the farther you push it...the faster the machine goes....
non variable....only has stop...and run....
Jun 05, 2015 | Sewing Machines
My stove have code f 23 What this mean?
Thanks for your inquiry, Adrian Gonzalez!
From the information you have provided your Electrolux range is displaying an error code of "F23". "F23" stands for communication failure between the EOC (Electronic Oven Control) and ESEC (Electronic Surface Element Control) I would attempt to perform a reset on your range and you could do that by disconnecting the power from the range for ten minutes. If you continue to experience a problem with the error code it could be an issue with the EOC or VSC (Variable Speed Control) board. Hope this helps. -Matt
Nov 22, 2014 | Electrolux White Gas Slide In Stove Range...
Dremel rotary tool variable speed, low speed speeds up after short use. Will brush replacement solve this issue?
How stable is your line voltage? The SCR phase control used for speed control is more sensitive to line voltage changes at low speeds than at high speeds. Brushes should be changed when they are worn down to about 1/2 of their original length. Much more than this and they don't have enough tension to properly contact the commutator ring. Check with power off when the tool is cold and slowly turn the chuck by hand to feel the resistance. Run it a while and let the bearings warm up. Turn off power and turn by hand again. If it feels looser when warm (which would cause it to speed up at slow speeds), the tool might need to be disassembled and bearings oiled. I use Dexron automatic transmission fluid to lube most motors. Wipe down any excess.
Nov 14, 2014 | Dremel Variable - Speed Multipro Rotary...
How do I test a variable speed switch on a band saw (craftsman)
Connect all the red to the black, so the switch is not in use. It should run at full speed. If it does the switch is faulty.
Mar 21, 2013 | Tools & Hardware - Others
I have a Bosch 1/2"
Sounds as though you are on the right track. I would take it apart, and see if the trigger could have some dirt or other material causing it to stick, or is it worn to the point that it needs to be replaced. Good luck!
May 30, 2017 | Bosch Tools 8.0 Amp Corded Hammer Drill,...
Gr450 grinder variable speed has stopped woking, grinder goes to full speed when turned on with no affect from variable speed
i woulkd take switch off and rewire it. It is not a very difficult thing to do. As you take it apart just pay atention to where the speed control wires are running from and go from there. If it still dosent work than the switch is burnt out
Apr 17, 2011 | Delta GR450 ShopMaster 8'' Variable Speed...
My windshield wipers will not work on variable speed. Only the fast and slow speeds work and when switched to the variable speed position they stop instantly in middle of the windshield. Replacing the...
Alarm control unit has a chip in that controls the delay wipers, this chip cost about 2 dollars, but it has to be sodered in. the whole box cost about 200 dollars. It is located behind the glove box on above the right kick plate ive been told. chip can be bought from mouser.
Dec 09, 2009 | 2002 Isuzu Rodeo
Range Hood Issue
Definetly need a new motor control.
Nov 26, 2008 | Kitchen Ranges
Minn Kota 65lb
Hello hfreel, check control board and wiring in the head of the trolling motor, The variable speed control element or the connection has shorted to provide only full speed. Merry Christmas.
Aug 09, 2008 | Boating
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
738 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
