Question about Ricoh Aficio 1035 Copier
I have sc 546 problem - Ricoh Aficio 1035 Copier
  • nagarajurj Apr 17, 2009
    i have sc 546 code problem
Fuser warm up error.
Posted on Apr 17, 2009
  • 162 Answers
Fusing ready temperature unstable
The fusing temperature is fluctuating.
Thermistor connection loose
Fusing unit connector loose
try clean or changing the thermistors.
Posted on Nov 15, 2009
    Problem Solver:
  • 9 Answers
What id your probelm
Posted on Apr 16, 2009
2 Suggested Answers
joel_baleta
  • 155 Answers
SOURCE: ricoh 1045 showing code SC545. First was SC 546
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
Posted on Jan 26, 2010
Ricoh aficio SP4100NL error sc 546
Ricoh uses error codes in order to alert users that there is a problem with the functioning of the copier. Codes that begin with "SC" refer to issues with the fuser components, which heat up to bind the toner or ink to the paper. While clearing the code can be accomplished by most users, it is important to point out that clearing the code does not fix the problem. Codes that reappear should be addressed by a certified Ricoh technician.
Instructions
    • 1 Press the "Clear Modes" button. This button will be on the main panel.
    • 2 Press the "1,0,7" keys in succession. You do not have to hold the buttons down together but need to press and release them in this exact order
    • 3 Press and hold the "Stop" key. You will need to hold this button down until the Ricoh enters service mode. The touch screen display will say "service mode" and three soft keys will appear.
    • 4 Press the "Exit" button. This button will be on the touch screen display in the upper right hand corner. Once pressed, the copier will return to normal operation mode.
    • 5 Turn off the main power. The main power button will be located on the side or front of the copier.
    • 6 Turn the power back on. Once the copier is powered back up, the service code will be cleared.
Jul 20, 2014 | Ricoh AFICIO SP4100NL MONO-LASERPR 31PPM...
Je possède un copieur Ricoh 1022 .il est en panne . il affiche SG 546 . Aussitôt j?affiche 107 en appuyant sur le bouton jaune pendant un moment .l?appareil se mit en marche pendant quelques...
SC 546: Unstable fusing temperature
Symptom: The fusing temperature does not rise
3 °C or more within 5 seconds after the
fusing lamp has been on over 8
seconds.
Possible Cause: • Thermistor defective
• Power supply unit defective
Oct 20, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Savin 8025 SC-546 error message
you have an over heat error. you need to test your thermistors, s and lamps for continuity.replace bad parts. then you need to go to service mode and reset the code
Jan 28, 2010 | Savin Office Equipment & Supplies
Ricoh 1045 showing code SC545. First was SC 546 and now SC 545 can somebody help?
Jan 26, 2010 | Ricoh Aficio 1035 Copier
Functional problem code displays sc546
sc 546 fuser temp changes more than 20 degrees after warm up. clean thermistor if tat dosent work check fuser connector. reset= enter service mode turn copier off wait 5secs then on.
Dec 01, 2009 | Savin Office Equipment & Supplies
I have always error code 546 and 960
Error Code SC 546 is for fusing & SC 960 is for Current leakage, If u getting it regurally , change the thermistors for error code 546, & for error 960 change drum & charge roller.
Aug 16, 2009 | Ricoh Aficio 450 Copier
I have a Savin 9922DP red wrench and code SC 546
Parts availability ended for this machine Jan of 07, now is a good time just to chuck it.
Jun 02, 2009 | Ricoh Aficio 450 Copier
Ricoh aficio 1022 sc 546
problema ricoh aficio 1022 copia en blanco aparece codigo
sc 193
Oct 20, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
Ricoh MP 2510
Fuser installation error. Fusing unit set error. Remove the fusing unit out of the machine and reinsert it. It isn't seated in there properly. Once you do that the error code will go away.
Sep 15, 2008 | Ricoh FT5832 Copier
Service code 546
SC 546 Heating roller
fusing lamp
temperature
fluctuation
The heating roller temperature
changes by ±20°C or more in
one second. This occurs three
times in one minute or two
consecutive times.
• Loose connection of
the thermistor
• Loose connection
between the fusing
unit and main frame
1. Check if the fusing unit is properly set
and connected to the main frame.
2. Check if the heating roller thermistor
connector is firmly connected.
3. Replace the fusing unit
Aug 19, 2008 | Office Equipment & Supplies
Ricoh Aficio 1035 Copier Logo
270 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
