Question about Radio Communications
I inserted the jack into the slot and the microphone worked for some time. Now, it has become erratic, most of the time the microphone is not picking up my voice.
  • 31 Answers
Can be a loose solder joint on the jack or plug may be loose, try another device . not every person has a test meter but If you want to try a hand in electronics start at basic level, also any Ham Radio Operator is a great help who has been around the field for awhile or a student Electronics Engineer . Ok back to the fix it part are you able to solder ? the iron gets hot and saftey is # 1 thing and between burning yourself and the carpet , chair desk, etc I would ask for some help , don't try it on your own.
Posted on Apr 16, 2009
I have a XPS M1330 Dell Lap Top, I have logitech headphones but when I insert them into the slot on the Lap Top I am not getting any connection into the headphones..Please assist
There is 3 things you have to check:
1. The volume of the headphone
2. Check the jack where you are pluging the headphones, coul be the microphone jack
3. In the audio propertis, check that the mute mode is not on.
For further help please post again, so i cna help you.
Aug 16, 2011 | Computers & Internet
(1) Is it possible to have a bi-amp hookup to speakers that has twin wire lugs when playing just two front speakers, and how is it done ?. (2) can a regular microphone work in the microphone jack to...
1) Not with this unit. WHY bother? Sending identical program to two drivers over separate wires is the same as sending it over one pair.
2) No. Insertion of a microphone tells the unit you're doing setup. The microphone picks it up and sends it to a microprocessor for evaluation. The sound from the mic never finds its way out to a speaker. THAT would be a feedback loop and the tweeters wouldn't like it. (sizzle sizzle)
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Harman-Kardon-AVR-435-Receivers-manual/id/386bh037/t/2/
Apr 07, 2011 | Harman Kardon AVR 435 Receiver
I don't have a problem, only a suggestion. I have two of your microphones, both work well. The last one has a better base, but it is way too tall, as is the other one and unhandy to pack and travel with;...
Is this intended for logitech? If so why not go here
http://www.logitech.com/en-us/support-downloads
and click on email support.
What did you hope to gain by posting it in here, interesting though it was to all logitech microphone aficionados?
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 28, 2011 | Logitech USB Desktop Microphone
When i connect my headset, the sound come from both headset and speakers and my mic is not working
When you insert the headphone jack into the "audio-output" jack,
which should be GREEN coloured, it should mechanically disable the built-in speakers. If that does not happen, you're connecting it to the wrong socket.
Be sure to insert the microphone's jack into the PINK socket, which is the "microphone-input" socket.
Sep 27, 2010 | Computers & Internet
I am trying to use a microphone with the Insignia Receiver 5.1 Channel. I am plugging my microphone jack into the microphone set-up slot. I turn on the button but get no sound through speakers. What do I...
Check if the impedance of the microphone is the same of the microphone set-up slot. High impedances devices such as microphones have to match exactly between jack and input. Good Luck.
Flavio?BRAZIL
Jul 19, 2010 | Insignia Audio Players & Recorders
Connection problem with rode ntg-2
If you look at the side of the microphone at that end there should be a small hole. Using long nose pliers grasp one of the pins and pull the jack all the way out to make sure that no wires have broken loose. Look on the side of this (plastic?) piece and you will notice a small screw with a slot in it. Using the pliers again, insert the piece back into the microphone gently and line the screw up with the hole. There should be only one way to do this as the piece has a protrusion that guides it down a slot in the microphone. Once the screw is lined up use a small enough flat blade screw driver to fit the hole. Screw the screw out, Yes Out. What this does is secure thje plug in place and provide a ground to the microphone. Please let me know how you make out.
Dec 02, 2009 | Rode NTG-2 Professional Microphone
My microphone jack is jammed because one of my microphones broke off. I bought a new mic and now it will not fit in. Is it possible to use my blue "Line-in" jack as a mic jack?
You can try it but I don't think it will work.
I think the power levels are different.
Are you sure you can't get the broken stub of the old connector out with a small pair of pliers or something?
I suppose the sound card is built onto your motherboard.
You could disable it on the bios and get sound card to go into one of your interface slots. They are not very expensive. Just make sure you get one that matches one of your free slots.
Sep 19, 2009 | Compaq Presario S3310CL (DF246AR#ABA) PC...
I have a Sony ICD-SX35 recorder which my iMac will not recognize. Any clues out there???? I need to convert the dvf files into MP3 or WMA format but that can't happen before my Mac recognizes the...
I took the advice of one of your correspondents by connecting my Sony ICD-SX365 recorder to my iMac with a simple audio cable by inserting the output jack in the recorder's slot for headphones and the input jack in the iMac's slot for microphones. I used the freeware program Audacity to import the track onto the computer and Switch to convert the file to mp3.
Apr 15, 2009 | Sony ICD-P28 Digital Voice Recorder
Pavilion PC Notebook Verve dv2000 Microphone
yaa you have to set your microphone valume but first check if you are getting right connection.
In front panel jac there are three Jacks
  • The Left on is for microphone, i.e. you should insert the microphone node in it.
  • The second 2 jacks are for speakers you can insert speaker node in any one or both.
Try this I think it will work, otherwise ask me and let me know whats going on.
Gud Luck
Iqbal
Apr 16, 2008 | HP Pavilion dv4000 Notebook
Radio Communications Logo
97 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
