Question about Maytag EPIC MFW9700S Front Load Washer
Error FH Maytag front loader MR@9700sQ1
I was running a load of wash when the water got shut off (have a construction crew there and they didn't know I was washing a load of laundry) Now the code FH comes on. I've unplugged to reset. Put another load on and it runs great until the rinse cycle then the FH error code comes back
Your drain is clogged, not the one in the wall where the drain hose goes, but the internal drain, you have to use a 7mm quarter inch drive socket and a 2 inch or longer extension. There are three screws at the very bottom of the washer which must be removed. When standing you cannot see these screws, you have to lay down and look under the washer, between the feet of the washer to find them. Once the bottom cover is removed there is a "cylindrical box" thing with a front cover, the front covers is simply screwed into the cylindrical box housing, unscrew it. Warning, there is a lot of water in here so don't be sitting when you remove it. When you get it open you will discover that this is the internal filter, you'll find small socks and coins and god knows what else in here. Now follow the drain line out and feel it from the outside by pinching it to see if it is clear, if it is clear it should compress quite easily if it is clogged remove it and **** it out with a wire hanger. Reassembly is the opposite of disassembly. This should fix you error message. And buy the way if you remove the top cover there is a "Technicians Manual" stored inside the washer under the top cover that describes some of this procedure and defines all of the error codes.
Posted on Aug 03, 2009
  • 297 Answers
Bad wire harness connection. Check all connections for loose or corrosion, etc.
Posted on Apr 16, 2009
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Timer display blinks fh on maytag epic front loader
First try turning off the machine for 30 minutes. Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within 1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear for several minutes then the pressure switch can be the source of the problem.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
Inlet valves can be purchased thru the net and fitted by you easily.
Feb 25, 2013 | Maytag EPIC MFW9700S Front Load Washer
FH SIGNAL MEANS ......... WHAT IS THE USE OF FH SIGNAL........ AND APPLICATIONS
The error code FH means no water is detected entering the machine which can be due to a faulty flow meter not registering the correct amount of water that has passed through it or the pressure is not tripping from the empty position to the full position when the correct water level has been reached. Your machine is definitely made by Whirlpool like other Kenmore and Maytag washing machine so they are basically the same and troubleshooting is then the same. The link below contains the detailed troubleshooting of this error code for a Whirlpool Duet and should be applicable to your machine.
Error Code FH on Whirlpool-made Front-Load Washers
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
F11 error code
The F11 code means there is an electrical with the Maytag Epic washer. This could involve wiring, fuses or a number of other issues.
Press the "Pause" button twice to stop the current cycle. Press the "Drain" button to remove any excess water. Try to run the washer again. If the F11 code repeats, shut the washer off and contact a service agent
The FH error code may be mistaken for the F11 code. The FH code signals a water supply issue and has nothing to do with electrical problems. Check the LCD screen to ensure you read the proper code
Dec 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
What does FH error stand for
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Jul 23, 2010 | Maytag EPIC MFW9700S Front Load Washer
My front loader is saying error FH ? Do you know
Here's the FH troubleshooting guide
or check out link go to this
http://www.repairclinic.com/0078.asp
WHIRLPOOL
Duet & Duet HT Failure
Code
Condition Check/Repair F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operati
Mar 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-h is the problem magtag neptune front load
fh is a NO WATER fault, check your incoming water supply, watch out some new stainless steel inlet hoses marked" floodsafe" are imfamous for shutting water supply, if you have these hoses i strongly reccomned replacing with "NORMAL stainless steel inlets" FLOOD SAFE brand no good
Jan 21, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag epic
hi there,
the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Oct 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
1,039 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
