Question about HP Compaq Business d530 PC Desktop
Scaleo P Does not Start up, No Fan, No Boot Up Nothing at All
My broter recently replaced the graphics card and mother board on my pc and it worked perfectly. I then simply moved it upstairs to my son's room and now it does not start all. All is does is when you insert the cable into the back and turn the on/off switch on the back on the mother board light flashes and then goes out and the green light on the front of the pc stays on for about 20 seconds. The power button at the front of the pc does nothing at all. Please help in very simple terms. Desperate, as need this pc up and working for my son's school work. NB Have a had a look at the inside of the pc and everything looks plugged in ok.
  • sjdbailey Apr 17, 2009
    Thank you so much for the advice. Sorry but I really need it in simpler terms. Have got as far as checking everything is seated down, presuming you mean everything is pushed in properly on the motherboard etc. I presume that I have a power supply going in as lights do come on just nothing happens.
    How do I cable off the CDRom drive and other hard ware to see if any point it starts. Sorry but never done this before and can I damage the mother board by doing any of this.
    If PSU has died can it be fixed and are replacements expensive. Do they die just by being moved?
    Sos but am really trying to learn.
  • sjdbailey Apr 20, 2009
    Fan does not spin at all. Monitor cable is completely removed now as have taken pc down stairs to work on.
    Sos but must be really stupid as don't understand the rest of your message. Can you be more precise - what connector end are you referring to and where is it.
    Sergeant:
  • 190 Answers
Something is shorted or PSU has failed
make sure cards are seated down (with power cord out)
try if works ;) your good
if not next step is cord out an remove power and cable off the CDROM drive
try it, just go through all hardware till it starts
to determin what failed, if still same no boot then PSU has died
Posted on Apr 16, 2009
  • mr Overland Apr 20, 2009
    if fans spin an lights on MB lite-up ?
    is the moniter cable in all the way ?
    grab the connector end to remove plug/ribbon or cable end
    note they are keyed (means fit only 1 way)
    note sure take a picture to know where they go on re asymbly
Fujitsu scaleo j wont load passed the fujitsu siemans logo screen
If you remove the Graphic Card and replace the original Memory will it boot?
Jan 28, 2013 | Computers & Internet
My fujitsu scaleo p tower won't display anything on the monitor! The monitor works fine with other devices.... everything spins and all LEDs light up just no output to the monitor :/ any...
Have you tried putting the Graphics card in a Different slot? If you have and it is still not working most-likely it means that your video card has gone bad and needs replacing.
Jul 11, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
I have a problem with my fujitsu siemens scaleo p, when i turn it on, only the orange light turns on, it sounds like the computer is doing something, but nothing on the screen, maybe it´s on...
Might as well try to access it thru safe mode with networking if it s working fine , if not try to connect an external monitor / or better yet if you can access safemode with networking try to disable some of the start-up programs thru msconfig.
ERNZ
Feb 08, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Asus M2N-E CMOS making PC unable to boot up.
Open the case and take out graphic card... Clean connectors with rubber and PCI-E slot with brush... Put back graphic card...
Also, download latest graphic drivers and install them and update BIOS
Nov 07, 2009 | Computers & Internet
Wires off graphics card into mother board?
The computer won't boot if there is no graphic present. If you did hook it up right and there is a fan on the graphics card, it should be turning.
Oct 17, 2009 | Gateway Computers & Internet
Does not boot to the Bios and to the hard drive.
You might have a Mother board problem
Try changing you Ram with a new one
and if you are using a graphic card remove your graphic card and use the onboard VGA to see if the card is giving you the display problem.
and if none above solution is working you might have to test your motherboard but we have to go through this step by step.
Leave a comment on this problem so that we can test your board stp by step
Feb 23, 2009 | Computers & Internet
Starting machine
Mine did this, there is a small round battery (size CR2032), try replacing that, I did on mine and then when I preseed the button it started working again!
Jul 12, 2008 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
My Fujitsu Siemens Scaleo P tower fails to boot up, sometimes shuts down after a few seconds, no output to monitor. Can you help
I also have a Fujitsu-Scaleo P, yesterday I had the same problem exactly as described here. The issue is that the CPU fan does not work anymore. It is easy to replace, only four Phillips screws to be removed. I simply don't know if the new fan replacement can be bought alone, or if the air duct will be in the replacement kit, along with the aluminum block. It is a Cooler Master Model made by Protechnic Electric model MGT 9212ZR-W25. If it wasn't that the problem, when the computer is still cold, try to boot it, press DEL which will bring up the BIOS Setup Menu, and you can see if the Fan still works: in one of its menus shows the Fan RPMs and CPU Core Temperature. Good luck.
Mar 31, 2008 | Computers & Internet
Sony vio doesn't boot up
its most probley the fan reinsert
singed greazy guy.
Feb 29, 2008 | Computers & Internet
HP Compaq Business d530 PC Desktop Logo
794 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
