Question about Kenwood DNX7100 Car Video Player
Audio seems to lock out
The audio seems to work, then will lock out and the main menu tab will also turn gray. Could this be because I do not have the parking break wire attached to anything? It seems to work when I reset, then lock out and go silent again.
You must ground the parking break wire. Just ground that wire to the frame. This will make the radio think it is always parked, but you now will be able to access GPS directions while on the move and the grey out will not happen. Worked for me.
Posted on Nov 03, 2007
SOURCE:
How to re-enable inaccessible TV menu options?
Go to thru the main menu until you reach the menu item that says "Reset all".
Jul 18, 2016 | Seiki 39" Class 1080p 60Hz LED HDTV...
I have a Mitsubishi dlp wd-65737 that when turned on goes to a pink screen with no picture what could this be is it worth fixing
  • If your TV issues involve the appearance of your TV's picture, the remote may be your answer. Press the "Format" key on your Mitsubishi rear-projection TV's remote control if the shape of the picture seems incorrect. Press the key repeatedly to cycle through various aspect ratios until the picture looks correct. To restore all audio and video settings to their defaults, enter the TV's main menu and select "Reset" from the Picture tab. From the same tab, you can reset colors to their defaults by canceling optional image features such as PerfectColor or PerfectTint.
Aug 05, 2015 | Mitsubishi Televison & Video
I cant hear the other person on skype but they can hear me
make sure your version of skype is the latest version. open up skype. in the main window that you see after logging in point your mouse to the tools dropdown menu. then click on options. then click on the audio settings tab on the left. under the microphone tab select your computers microphone or the microphone you are trying to use such as the webcam microphone. click on save. if it still doesnt work then try using a different microphone. if that doesnt work then reinstall your microphone driver. and repeat the steps before the reinstallation.
Feb 10, 2013 | HP 2000-369WM AMD E-450 DC 1.65G4GB 320GB...
I can't change the audio settings in the setup menu on my marantz dvd7600
Gray means they are locked out---consult the owner manual to see what can be done----sometimes it is how the unit is hooked up and to what.
Dec 04, 2012 | Televison & Video
There is no volume on the tv, the volume bar goes all the way to 99 but there is no sound, i plugged in external speakers it worked but the tv volume is not working. How do i fix this problem?
Go into your Audio menu on the TV and make sure the TV speaker are set to “ON”.
If the external speakers work when connected to the TV and the TV’s internal speakers don’t work when you remove the external speaker’s plug from the TV, then you will need to replace the main board.
The main board has all the function for the audio for the internal speakers. This was a known issue for some of the LG TV’s. So if you call LG about this issue, LG may fix it under a warranty.
Good luck.
May 21, 2010 | LG 26LG30 26 in. LCD TV
No audio
stupid answer but did u check the audio settings in the main menu from the ps3? i reset my ps3 on accident n the audio changed to component but picture stayed on HDMI
Jul 13, 2009 | Sony Playstation 3 (PS3) Console
Chrysler town and country wiring diagram
Where is the amplifier located on a 2002 Town & Country? My stereo seems to be working, but there is no sound coming out of the speakers.
May 25, 2009 | 2002 Chrysler Town & Country
Can't get Audio tracks to play on any myspace page
I'm wondering if you can't play .mp3, .wav or other audio files on your computer, or just Internet Explorer, or just specifically myspace.
First try: Open Internet Explorer. Select Tools from the Menu list. (If you do not have a menu list, right click the gray area below the url bar and select menu bar from the drop down list)
Select Internet Options from the Tools Menu. Select the Advanced Tab. Scroll down to the Multi-Media heading. Make sure that "Play sounds in web pages" is checked. Close Internet Explorer, re open and test.
Apr 15, 2009 | MySpace Social Network
I have the toshiba 42hl167 and the volume is not working. only works with play station. cant here cable or bose system.
I would reset the factory defaults on the TV, but some complicating information follows these instructions:
Reset Factory Defaults
To reset all settings and channels to their factory
default values:
1 Press Y and open the Setup menu.
2 Highlight Installation and press T. A new set of
Installation menu icons will appear.
3 Open the System Status menu, highlight System
Information, and press T.
4 Press C c to scroll through the menu bar to select
Factory Defaults.
5 Enter your PIN code (or 0000 if no PIN code has been set).
Because the PC and HDMI-1 inputs share the same set of analog audio inputs, the PC Audio menu setting influences the HDMI 1 Audio menu setting. If PC Audio is set to “No,” the HDMI 1 Audio setting changes to “Auto.” If PC Audio is set to “Yes,” the HDMI 1 Audio setting is set to “Digital” and is grayed out in the menu. (Also see item 5 on page 12 of manual and “Setting the HDMI™ Audio mode” on page 43 of manual).
There is also some good information on pp.20-22 and 54-57 of the manual - this one has a lot of audio hookups and settings.
-Tha Mp3 Doctor
Dec 17, 2008 | Toshiba 42HL167 42 in. LCD Television
Rear speakers do not work , also in set up menu they are grayed out.
hi there
when playing radio, the rear speakers do work because you have configured that. in your dvd player however, you may not have configured it yet.
Correctly insert the jacks at the back of the dvd player and at the same time, check the menu of your dvd player and check the audio settings. Under the audio settings of your dvd player menu, select the 5.1 or 6.1 audio profile.
hope this helps.
Feb 05, 2008 | Mintek DVA-8700 System
Kenwood DNX7100 Car Video Player Logo
136 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
