Question about Hotpoint Dishwashers
HDA900XX04BA OLDER HOTPOINT DISHWASHER
THE SEAL THAT THE PUMP MOTOR SHAFT GOES INTO THE PLASTIC PUMP HOUSE IS LEAKING. CAN I JUST A THE SEAL KIT. I TOOK THE SCREWS OUT THAT ATTACHES THE MOTOR TO THE HOUSEING, AND THE SHAFT IS LOOSE IN THE SEAL. IS THAT OKAY, AND WILL THE NEW SEAL TAKE CARE OF THAT PROBLEM?
SOURCE: leaking FDW60
Had a similar problem when I removed the lower spray arm for replacement (see http://www.fixya.com/support/t234402-fdw60_dishwasher ) and didn't put the centre retaining nut back. It might be worth checking the lower arm is screwed in tightly as the retaining nut prevents water escaping.
Posted on Jan 30, 2008
SOURCE: Maytag Dishwasher-pdb2430awx-Leaking
I believe that you must buy the plastic pump housing.....And that vinyl type shaft seal comes with that..I think!!!!
I have the same problem.....I changed the regular seal kit at a cost of $30.00 CND....Which is like what? 100.00 American.
Anyways mine still leaks after all that. Turns out there is so much rust between the nylon seal that is attached to the motor shaft, that water works its way down there. Funny that seal does not come with the common seal replacement kit. Im going to check tomorrow to see If I can get that seal alone. My concern is that after I drive for another hour one way to get that seal. Am I only going to put it on just to find out that the shaft is pitted to much by the rust to seal again? I am so tired of buyin ****!!!!!!
Posted on May 26, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Dishwasher Leaks
You can easily screw up the drain diverter arm trying to replace that seal. Repair is difficult. Pump assembly is rather expensive. (especially considering this was not a top of the line model) You would be much better off replacing the dishwasher. The new GE models are much quieter and have eliminated the center tower in almost all models.
Posted on Sep 02, 2008
SOURCE: Leak from dishwasher
I currently had the same problem with mine and the culprit was the boot that screws on to the spray arm which serves as the seal from the spray arm to the motor.To find out spin the base of the spray arm loose and take off the screw tightened clamp that holds the boot to the motor. Mine had dry rotted and leaked very badly.The part as only about $10. Hope this helps
Posted on Oct 25, 2008
reddyanantha
  • 205 Answers
SOURCE: Can't get screw loose on Kenmore dishwasher(665.1559579)impeller.
try it by using a high torck screw driver then the direction for loosening the screw is anticlock wise.
Posted on Jul 26, 2009
How old is my Hotpoint dishwasher, model HDA3400G02WW Serial SG8047194 is??? My dishwasher humms, but doesn't runs at ALL. What could be the problem????
The motor is stuck. If you remove the lower cover and see a square aluminum motor it is less than 7 years old. Make sure power is off at breaker and rotate the motor shaft
by turning the fins inside the motor.
If the motor is black and round you have to turn
the fan blade which is located in a slot between the metal pump and the plastic
pump. Also once freed, a light shot of silicone or WD-40 (silicone works better) at the
bearing ends. Also check pump for leaks around the drain solenoid (shiny shaft attached
to a plastic triangle). If it's leaking during pumpout, the seal has failed. The pump runs
around 100 dollars typically. Hope this helps.
May 30, 2011 | Hotpoint 24 in. HDA3400G Built-in...
Both drawers leak in the front
If your dishwasher leaks, check these:
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Apr 01, 2010 | Dishwashers
Water seems to be leaking around where pump shaft seems to meet plastic
Go to partselect.com and type in model number there should be a seal kit for the pump and have shaft seals in the kit.
Jan 25, 2010 | Dishwashers
Water leaks between motor and pump can't get motor off
hello there this may help you out ok
best regards michael
Leaking Pump in a Whirlpool DU810DWGQ1 Dishwasher by Samurai Appliance Repair Man
function ReferThisPage779b7841ed943a9e880964fef6da376b(){var rtp;rtp = window.open('http://www.tellafriendking.com/refer/?URL='+escape(document.URL)+'&CODE=779b7841ed943a9e880964fef6da376b&JS=1','_blank','width=350,height=530, resizable=yes, status=yes, scrollbars=yes');if((null==rtp)||'undefined'==typeof(rtp) ){alert( 'The \'tell a friend\' window was prevented from opening.\n\nPlease temporarily disable your popup blocker.');}rtp.focus();}document.write(""); rn-spa-g.gif document.write(""); 3548679745_8c188ff0d2_m.jpgLeaking Pump in a Whirlpool DU810DWGQ1 Dishwasher
These are cheesy, inexpensive dishwashers that are prone to leaky pumps, as shown here (click the pic for the larger, annotated view).
3548734637_17f81a0e1b_m.jpgWhirlpool DU810DWGQ1 Dishwasher Pump and Motor Diagram
The problem is usually a leaky shaft seal kit, shown here as Items 7 and 8 (click the pic for the larger, annotated view).
Fortunately, the shaft seal kit is inexpensive; but it can be a ****** to install, depending on how much rust you’re dealing with. May require a destructive removal of the impeller, too, but ain’t no thang ‘cuz the shaft seal kit comes with a new impeller. Here’s a nice, purdy picture of a brand new shaft seal kit. And just to help motivate you a little more, the money you save from replacing just the shaft seal vs. replacing the entire motor-pump assembly is well over a Benjamin. So you go ahead and drill, cut, and chisel all you want on that old impeller!
wpl-dw-horiz-pump-shaft-seal-kit.jpg And Whirlpool just came out with a spiffy new DIY repair manual for this dishwasher, which will assist you mightily in the many repair adventures you are certain to have with this dishwasher:
whirlpool-dw-diy-manual.jpg To learn more about your dishwasher, or to order parts, click here.
Sep 14, 2009 | Kenmore Dishwashers
Leaks from handle
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Door gasket or seal
Water-inlet valve
Hoses
thanks for using FixYa
Jan 27, 2009 | Danby DDW1805W Designer Series...
Danby DDW396: pump leaks when in use.
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Jan 11, 2009 | Danby 22 in. DDW396 Free-standing...
Leaking from rear in cabinet
  • Lower rack
  • Spray arm
  • Spray arm support
Sep 30, 2008 | GE Nautilus 24" Built-in Dishwasher
Pump disassembly
I removed the impeller on my DW761UQB. The instructions were molded into the plastic pump housing. This is how I DID MINE: Remove motor mount screws. Remove the chopper screw (screw only goes into impeller, not motor shaft). Remove chopper and rotate/remove strainer. Place socket or wrench on impeller tip and place another wrench on rear of motor's plastic fan. Unscrew fan from impeller shaft ( threads are LEFT handed, turn CW). Once fan is 'backed off' of the impeller, CAREFULLY pry the motor/fan from pump housing (impeller is attached to motor shaft via splines). Don't crack the delicate plastic pump housing. Mine was stuck, but separated with moderate force. Now remove the impeller/seals from the pump housing. This worked for MY above mentioned model, I don't know what other models it applies to. I am not a pro.
Sep 25, 2008 | Dishwashers
May 22, 2008 | Dishwashers
Water Leak
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
Aug 14, 2007 | Hotpoint 24 in. DF55 Free-standing...
Dishwashers Logo
77 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
