Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
Burner One burner will not turn on all others ok? They click when turned on -- but the burner that doesn't work when turned on doesn't click?
    Scholar:
  • 146 Answers
You probably have an open or shorted igniter that burner. Check the igniter if defective replace it.
Posted on Dec 21, 2007
SOURCE:
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
The top burner {broiler} workes OK. The bottom burner doesn't lite at all. Both glow plugs [liters ] work fine.
ould be the thermocouple or sensor senseing the ignition. more info would help
Feb 12, 2013 | Kitchen Ranges
5 burner gas Vicking stove top keeps clicking after is on
Their are 2 possible reasons the igniters would continue to click after the burner is lit.
1) the burner is slightly dirty and the part of it very near the electrode is not burning correctly so the igniter doesn't think the burner is lit so it will not tell the spark to turn off. It could be cleaned by using steel wool and cleaning the burner holes near where the electrode is and then use a paper clip and poke through the holes on the burner to clear them so they burn correctly.
2) the electrode (the spark plug at the burner) is cracked so even though the burner is lit so the electrode can not sense that the burner is lit and wont tell the spark to turn off,so if having cleaned burner it still clicks after burner is lit the electrodes would need to be replaced.
GENE
Oct 08, 2011 | Kitchen Ranges
No matter which burner I try to turn on, the same one tries to light - I thought the gas was turned off, but the fact that just the one burner tries to turn on makes me nervous. thanks
Hello- On modern gas cooktops and ranges when you turn on one burner ALL the burners will click, spark, until that burner is lit. I would ask if the other burners are lighting ok or do you have to use a match? Do you smell gas when all the burners are OFF? Feel free to reply and if you could provide the Model number of the unit that would be helpful. Best regards.
Sep 27, 2010 | GE Cooktops
When I turn on a burner, all the other burners click like they are trying to turn on as well. The clicking is continuous and really annoying! Thanks for your help! Tammie
Anytime you turn on a gas range all burners click for safety reasons. If a knob has been turned by mistake the gas lights to prevent gas from escaping into the room. If you turn the control knob past the LITE position after the burner lights you should be OK and stop the clicking. If the clicking continues regardless you have a defective ignitor switch that must be replaced.
Aug 26, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
One burner will not turn on - This is a Maytag Precision Touch control 500 electric smoothtop
hi there,
on this case try to clean the gas burner for any dust and corrosion inside. also check and test the ignititer of the stove/
let me know.
Jun 02, 2009 | Maytag MER5770 Electric Kitchen Range
Burner won't light
hi gud day,i think the sensor is we have problem is hard to repair in ur own,try to call the person have expireince for repair that unit, or ur igniter ligther have damage like small broken if u hear have click is ok but much better to check the igniter coz the broken igniter is not directly spark in the burner that why is not light.to check if remove the burner base cover then see if the igniter like a small niddle color white,turn the knob to click the igniter then see it wer the spark directly if u not see it means have a broken igniter.
tns gerbee
May 26, 2009 | Amana AKS3040 Gas Cooktop
Only one burner of four not working
sounds like a bad switch in the knob, turn on the defective side, turn on the one that works and keep the clicking going then turn on the defective burner while "other" is clicking if this lights then it means you have a bad switch or loose connections
May 31, 2008 | GE JGBC20 Gas Kitchen Range
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
103 people viewed this question
Top Viking Kitchen Ranges Experts
wrtsjr
Level 1 Expert
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
