Question about Hitachi 57SWX20B 57" Rear Projection Television
Blue lines will not line up
I have a 3-d image and it was like this for about 10 min. then the picture back to normal for the rest of the time watching television. but when i turned it on this morning it went back to the same 3-d thing. i ve done the magic focus manually and auto but cant line up blues
  • Hitachi Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a blue lines will not line up - 2c07611.pnglem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Pictblue lines will not line up - 578ba6c.jpga set that needs the fluid changed.
TV set after fluid chablue lines will not line up - 2c07611.pngr />65af323.jpg
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Apr 24, 2009
    Problem Solver:
Ceck solder connections on the convergence Output Amplifier IC's Mounted to big heat sinks on right side of chassis from back of set. If this does not solve problem then change them
Posted on Apr 16, 2009
My camera takes pictures which look fine on the monitor, but the captured image is covered with horizontal jagged lines. Any ideas what may be occuring .... help please?
It is an error in the camera as the picture/image caught into the memorry is having some noise when reproduced.
remove the battery for some time (10 min) and put it back without the memory , then after some time remove battery and insert the memory. Iff possible put the camera on charge for some hours .Also put the camera on continuosuly . check if the fault has changed, if so some capacitor is weak and on charge gets rectified.
Sep 01, 2010 | Samsung V70 Digital Camera
Sony BRAVIA KDL-46XBR 46 in. HDTV LCD Television. I have a problem when the unit is switched on. The screen has 2/3 lines running across it. The picture stays like it for about 10 mins then goes back to...
I hope this helps
It seems Sony is extending the warranty on your TV
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank and Good Luck!
Jan 19, 2010 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Tv works like 10 min.then retrace lines appear,
the model number 53fdx....etc is not a Toshiba model number---It is a Hitachi model number.
First if it comes on and you get trace lines before it shuts off----does it just get very bright and if so does it get bright red, green, or Blue?
if one of the picture tubes or the circuit around them has a problem you can get this and the set will shut down because it detects something is pulling way too much current.
I would be happy to try to help you but look at back of your set for brand and model number and if possible try to give me a better idea of what the picture looks like before it goes out.
SD TECH
Oct 17, 2009 | Televison & Video
Horizontal lines in picture
my friend CCD imager is going bad !
u have to contact GE they will do it free of cost even if ur not in warranty bcoz it is considered a manufacturing fault by all manufacturers BAD CCD is a big problem these days
actually if the pics are discolored have pink and blue shades or puple and differentt skin tones then my friend ur CCD imager is going bad
u can contact sony they might do it free of charge bcoz it is a big problem in thousands of camera models and all are repairing free of cost as it is considered a manufac fault pls contact SONY in ur area and they will do the rest insist on free repairs and tell them abt bad ccd
see this
http://www.imaging-resource.com/badccds.html
Pls rate me FIXYA for help
Apr 03, 2009 | GE A730 Digital Camera
Lines aftering watching 2 hours
Sound like the logic board or panel. Don't do any repairs if the set is under warranty contact Philips and have get a tech to your house and do the repairs.
May 16, 2008 | Philips 50PFP5332D 50 in. Plasma...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
45" Rear projection image warping
you can check the self diagnostic test by going to ctechnicians.com
Dec 22, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Lines in picture
I had this problem around the time my TV was 3 years old. I ended up having to get it repaired at a TV repair place, it cost me $375.
Sep 24, 2007 | Toshiba 57H83 57" Rear Projection HDTV
Blue vertical lines - no picture
you did not mention if you have sound.but if you have sound your problem is in your video and vertical section.if no sound then you have to look into the IF section.if you are not a tech then you will have to take your set to repairman.goodluck.the tuner must not be over looked.an estimate of about $200.00 could be less.
Mar 29, 2007 | Zenith D52WLCD 52" Rear Projection...
Hitachi 57SWX20B 57" Rear Projection Television Logo
99 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
