Question about Harley Davidson Road Tech HA90 MP3 Player
Wondering what makes the slide in my carburator go up, is it connected to the throttle cable somehow or does it run on vacume?
    Scholar:
  • 150 Answers
Vacume operated. faster you go the slide travels up.
Posted on Jun 14, 2009
Why wont my 1993 isuzu run without a air filter
I have a 1993 isuzu pickup and because of the design of the carburator and the polution control there are so many vacum lines that without the air filter the vacum, is off just a tip I had lost my air filter cover and was having carburator problems I bought a new weber carburator came with its own air filter was able to plug up alot of the vacum lines runs alot better better gas mileage was only 270 on ebay
if it's not running right check the vacum hose's
hope that helps good luck
Jan 27, 2013 | Cars & Trucks
1979 dodge d100 318 motor,hesitates from stop,idles rough,lacks power at low throttle
check timming , also check prime pump in carburator,look for vacume leak,(carb,and intake gaskets,vacume hoses)
hope this is helpfull
Jun 30, 2011 | 1984 Dodge D150
How dose egr valve connect to intake on 93 buick lesbre 3.8
Just find a vacume hose that has vacume to it when you accelarate with car running pull a vacume hose off from carburator check by putting your finger or a vacume gage to it to see if you got vacume if not accelarate the carb by pushing accelarator (left side of carb driver side) if you have vacume when you accelarate you can use that vacume line
Jun 27, 2011 | 1993 Buick LeSabre
Where do the three vacum line go on the egr on a 1985 corvette
You do not need to connect the three vacume hoses to the EGR just find one that has vacume to it upon accelaration with the car running pull a vacume hose off the carburator with a vacume gage or your finger check to see if you got vacume if not accelarate carb if you do connect vacume line to EGR
Jun 27, 2011 | Chevrolet Corvette Cars & Trucks
1972 honda cb 100, trying to get throttle cable diconnected from the carburator, i loosened and took the top off but the cable goes through and is connected down about an inch in there and i cant figure...
When you unscrew the top of carby with cable attached, the whole slide and needle will come out, take this out and sit on a chair next to your bike and simply compress spring by pushing cylinder slide closer to cap. The cable end can then be moved out of the slot that holds the end fast. Some carby's may have a small sliding clip to hold cable end. Cheers.
Apr 22, 2010 | Honda CB 100 Motorcycles
My 1993 sportster 883 is restricted, where would it be, at just over half throttle, it wont accelerate any more.
It sounds like the slide in your carburator is not operating properly. You bike should be equipped with a Kehein CV type carburator. In order to check for proper operation, remove the air filter from the engine leaving the backing plate in place. Start the engine and allow the engine to warm up. From a safe distance, rev the engine while watching the piston. It should rise whent he throttle is opened. If not, the piston and diaphragm assembly needs to be removed and checked for holes. If no holes are found in the diaphragm, a thorough cleaning of the carb is in order. Check the intake and make sure there are no vacuum leaks. There is a vacuum hose that runs from the carb to the VOES switch. Make sure it is connected and has no holes in it. Good Luck.
Oct 14, 2009 | 1993 Harley Davidson XLH Sportster 883
Banshee running wide open after a couple of revs
The problem with vents is that a vent can get plugged and lessen or completely kill the flow of fuel. They will not make an engine rev wildly. Your banshee has standard carbs. The throttle cables may be routed incorrectly, pinching or stretching the cables. Remove the air filters. Look inside the carbs. Do the slides move freely up and down when the throttle is twisted? In the diagram below note the junction tube on the throttle cabel. The cable can stick at inside the tube. Is the connector hose between the carbs in place? Also, there is a switch on top of the carb. This can go haywire also. Odd that the problem was not present before they cleaned the carbs.
Can I get a “very helpful” rating on this answer?
Aug 27, 2009 | 1986 Yamaha RD 350
How to change throttle cable on 2005 rm 125
The carburator end...you will need to remove the seat and gas tank.The top of the carb will turn off counter clockwise, then you can pull the "slide" up out of the carburator. Note which is the front for re-assemble. There is a spring between the slide and cap, and look into the slide to see if your cable clips in, or may have a phillips screw and plate to remove to get the cable free. I use needle nose pliers to hold the spring back to remove and replace the cable.
The throttle end is easier. Remove the plastic cap and unthread the adjusting worm nut. The cable end "ball" will come out with the help of needle nose pliers also. Pull the cable slack up to rotate the "ball" out of the throttle tube.
Hope this helps!
Jul 19, 2009 | 2003 Suzuki RM 125
I need to know how to hook up linkage for throttle.
Take off the two scress that bind the throttle to the shaft, within the throttle you will see your cable at the hand lever end. The cable will slide out of a hole in the lever. The other end is attached to the carburator by a little ben in the wire. Use needlenose plyers to remove from the throttle body of the carburator, replace as dismantled. Your good to go.
Jul 05, 2009 | Garden
Problems with my dodge raider 87, carburator not working well
try checking all vacum hoses with a water spray bottle .cable sticking try a graphite lubricant sprays liquid dries to a powdered lubricant .good for hot or cold tempeters.
Feb 21, 2009 | 1987 Dodge Raider
Open Questions:
See all Harley Davidson Road Tech HA90 MP3 Player Questions
Harley Davidson Road Tech HA90 MP3 Player Logo
35 people viewed this question
Top Harley Davidson Audio Players & Recorders Experts
Jim Goldsmith
Jim Goldsmith
Stephen Burdy
Level 1 Expert
xxxxxx xxx
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
