Question about Sansui DTV2760 27" TV
Manual sv2118si - Sansui DTV2760 27" TV
Free manual sansui sv2118si tv
Google (sansui)(sv2118si)(manual) without parens.
Oct 18, 2018 | Sansui Televison & Video
Hi what's the no. of the vertical output IC for sansui sv2118si?
Contact Sansui or purchase the schematic, I don't think your going to find anyone with the information you need on here as if it has a vertical out IC its a really old set.
Dec 31, 2017 | Sansui Televison & Video
My sansui model sv2118si is having smal lines on the screen
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Jan 03, 2017 | Sansui Televison & Video
How do I program KL-2010+ universal remote to sansui SV2118SI
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Feb 07, 2015 | Sansui Televison & Video
I need to find a code for my sansui SV2118SI
0039.0033. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Feb 28, 2014 | ShopBroker 3 in 1 TV, VCD, DVD Universal...
Sansui sv2118si
Feb 28, 2014 | Toshiba MR120 Remote Control
Instuction maual for hitachi plasma tv model no P50X01AU
These are the only manuals available. Maybe one of them will help.
  • Hitachi P60XR01U manual for Plasma TV
  • Hitachi P60XR01E manual for Plasma TV
  • Hitachi P60X901 manual for Plasma TV
  • Hitachi P55T551 manual for Plasma TV
  • Hitachi P55H4011 manual for Plasma TV
  • Hitachi P55H401 manual for Plasma TV
  • Hitachi P50XR01U manual for Plasma TV
  • Hitachi P50XR01E manual for Plasma TV
  • Hitachi P50X902 manual for Plasma TV
  • Hitachi P50X901 manual for Plasma TV
  • Hitachi P50V702 manual for Plasma TV
  • Hitachi P50V701 manual for Plasma TV
  • Hitachi P50TP01UA manual for Plasma TV
  • Hitachi P50TP01U manual for Plasma TV
  • Hitachi P50TP01EA manual for Plasma TV
  • Hitachi P50TP01E manual for Plasma TV
  • Hitachi P50T501A manual for Plasma TV
  • Hitachi P50T501 manual for Plasma TV
  • Hitachi P50T01UA manual for Plasma TV
  • Hitachi P50T01U manual for Plasma TV
  • Hitachi P50T01EA manual for Plasma TV
  • Hitachi P50T01E manual for Plasma TV
  • Hitachi P50S602 manual for Plasma TV
  • Hitachi P50S601 manual for Plasma TV
  • Hitachi P50H401A manual for Plasma TV
  • Hitachi P50H4011A manual for Plasma TV
  • Hitachi P50H4011 manual for Plasma TV
  • Hitachi P50H401 manual for Plasma TV
  • Hitachi P50A402 manual for Plasma TV
  • Hitachi P50A202 manual for Plasma TV
  • Hitachi P42TP01U manual for Plasma TV
  • Hitachi P42TP01E manual for Plasma TV
  • Hitachi P42T501A manual for Plasma TV
  • Hitachi P42T501 manual for Plasma TV
  • Hitachi P42T01UA manual for Plasma TV
  • Hitachi P42T01U manual for Plasma TV
  • Hitachi P42T01EA manual for Plasma TV
  • Hitachi P42T01E manual for Plasma TV
  • Hitachi P42H401A manual for Plasma TV
  • Hitachi P42H4011A manual for Plasma TV
  • Hitachi P42H4011 manual for Plasma TV
  • Hitachi P42H401 manual for Plasma TV
  • Hitachi P42H01U manual for Plasma TV
  • Hitachi P42H01E manual for Plasma TV
  • Hitachi P42A202 manual for Plasma TV
  • Hitachi P42A01 manual for Plasma TV
  • Hitachi CL42PD2100 manual for Plasma TV
  • Hitachi CL37PD2100 manual for Plasma TV
  • Hitachi CL32PD2100 manual for Plasma TV
  • Hitachi 70VX915 manual for Plasma TV
  • Jan 31, 2011 | Cell Phones
    My fridge was damage by high voltage of electricity is doesn't switch on at all ,Model sv2118si 660 litre Sumsung
    Hiya,
    When you say that your fridge/ white goods appliance was damaged by high voltage, we need to exactly what the voltage source was that did the deed.
    If you are talking about a bigger voltage input source, from the mains suupply, then it is likely you would have had a fuse within the plug that would have blown. This should be the first thing you will check regardless of the voltage.
    If however, you are telling me that your house took an in-direct or worse still a direct whack from a lightning strike, then my dear friend you have quite possibly a totally deceased appliance. For a start, such a strike could melt your plug and possibly socket. The fuse inside the plug wouldnt be a relevant factor here; because if the lightning made it from the sky to the ground, I am sure it can cross a 40mm gap within a plug. Then the lightning surge would simply travel up the power cord, knock out your gas pump, stepdown transformer and any lights or motors within the appliance. The cost of changing every part here is not worth it. You would be better off claiming on insurance or simply buying new.
    there are a few ways you can investigate what has caused this, and possibly cure the fault, unless it is a lightning strike of course that is responsibe.
    The first thing to do here is dismantle the mains electricity plug that is attached to the fridge. Check the small fuse inside this to see if it is functioning. You can do this in many ways. The best I find is to get a multimeter or the appropriate tester and perform a continuity test. See this link below
    http://en.wikipedia.org/wiki/Continuity_test
    If the fuse is broken, then change it and repeat the test; YOU MUST replace the fuse with what the original one from the manufacturer was.
    If the fuse is working, then your fault is elsewhere and you will need to perform the above tests on various components relevant to your fridge.
    The worst case scenarioo is the lightning strike; and in order to identify this, you will need to do one or two simple things.
    Firstly, head to your main consumer unit (fusebox) and check that all of the fuses are in the "closed" or "on" position. Open fuses indicate a power surge or a short circuuit somewhere on your supply, but relevant to your fridge. RCD circuit breakers all narrow down the searching to one localised area. You should also do this test for identification of original fault.. The same for when you as above check your main fuses.
    If the fuses on the consumer unit are "open", then either replace them if you have to, or you simply either push them back in or move them to the "closed" position. Also check that the consumer unit is not damaged in any way, as you would expect from having too much electricity put through it. Fire damage, warping, blackening, discoluration, bent or broken components are all good indicators of this.
    Another test you may have to do, is simply look around your house. Has anything else been effected. If it has, then it is likely that it was a lightning strike or something equally as damaging, if no, then it could simply have been a power surge that only really effected your fridge. Even so, is any of your other electronic and white goods items behaving oddly? TV menu keeps appearing or going into standby? Is the lights on your DVD player behaving erratic or does discs keep being ejected at atrange times? What about your computer or laptop; do these strangely start playing up? If so, then either the lightning strike is to blame or you have had a powersurge.
    Once you have done theseinvestigations please let me know the outcome and if it is negative, Iwill gladly advise you further.
    I look forward to hearing from you soon and hopethis is the fixya for you;
    Yours sincerely
    Oz
    Mar 08, 2010 | Refrigerators
    Sansui DTV2760 27" TV Logo
    26 people viewed this question
    Top Sansui Televison & Video Experts
    matt martin
    matt martin
    Steve Allison
    Steve Allison
    Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
