Question about Zebra QL 420 Thermal Label Printer
Can't connect via Bluetooth connection problem
When I try, I can "see" the printer but I get a request for a PIN, which is needed on both devices. I can make up & provide it for the handheld device (Symbol MC9660), but how do I put it on the 420 as well? Thanks for any help.
  • salvoty Nov 12, 2007
    gr0b,
    Here are my settings from printout:
    Bluetooth:
    .local_name XXJS05-50-5020
    .authentication off
    .discoverable on
    (Ealrier) I was not able to configure the Symbol 9660 with this local_name I think because it is alpha-numeric. Will "label vista" allow me to rename both devices?
    Thanks for your help!
  • 53 Answers
Print a configuration label from the printer to get the BT settings, you may need to use "label vista"(zebra) to configure it. the keys are generated based of the BT mac
Posted on Nov 09, 2007
  • Robert sturzbecher Nov 13, 2007
    when pairing and it asks for and encryption key is has to be a minimum of 8 digits for it to work correctly.
    Will "label vista" allow me to rename both devices? yes, but you will need a serial/usb cable.
    also be careful not to get the encryption key mixed up with the authentication key.
My Rio Bluetooth touchpad keyboard when I connect with The Bluetooth dongle supplied is asking for pin before device pairs but there was no pin supplied when bought device so what do I do please help
Something I found with a Google search:
Entering the code "0000" will often work. If not, you may need to check the device's documentation (or perform a web search) to find the PIN it needs. By default, after the devices are paired, they'll automatically see each other and communicate when they're both powered on and have Bluetooth enabled.
Mar 26, 2018 | Rio Computers & Internet
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
How do I connect my Nokia 225 mobile phone to Hands free Nissan Note via Bluetooth
Hi, I had trouble connecting to a corsa with my Nokia, I Had to try serveral things to get it working. first of all is you phone bluetooth name visible?, is your bluetooth name different from other bluetooth device names stored on the car?
Have you tried a bluetooth search from the car to the phone and from the phone to the car?, did either or both devices ask for a pin number(usually 0000)? If you can offer anymore more infomation that would be great.
Mar 09, 2015 | Nokia Cell Phones
My wireless Toshiba keyboard won't connect to my tablet
1. It connects via Bluetooth and not all devices are compatible with Tablet design. It does not connect via Wi-Fi.
2. Bluetooth devices require a PIN number to be put in the tablet for it to work.
See this web page for details.
Toshiba Wireless Keyboard Android Optimized
Mar 06, 2015 | Tablets & eReaders
I need to connect my nokia E63 phone via bluetooth but it will not respond
There is almost no way you can connect your phone via bluetooth to your car speakers. You can buy the cassette jack that allows you to connect a 3.5mm pin to your phone and whatever media you play would be projected out of the car speakers.
There are also a few devices that you can purchase to help you connect it through bluetooth,
Let me know if you need more assistance and thank you for using fixya
Jan 13, 2011 | Car Audio & Video
How to connect samsung tocco mobile to another samsung tocco mobile using bluetooth?
Turn on the Bluetooth wireless feature.
To turn on the Bluetooth follow the below steps,
1. In Menu mode, select Applications > Bluetooth.
2.. Select the circle in the center to turn on the Bluetooth wireless feature.
3.. To allow other devices to locate your phone, select Settings > On under My phone’s visibility > Save.
To connect other device to your mobile
1. In Menu mode, select Applications Bluetooth Search.
2. Select and drag a device icon into the centre.
3. Enter a PIN for the Bluetooth wireless feature or the other device’s Bluetooth PIN, if it has one, and select OK.
When the owner of the other device enters the same PIN or accepts the connection, pairing is complete.
After connecting you can start sending the files from one mobile to another mobile.
To send files follow the below steps.
1. Select the file or item from one of your phone’s applications that you want to send.
2. Select Send via or Send URL via Bluetooth, or select More Send via Bluetooth
Thank You
Aug 12, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
Connecting to printer via Bluetooth but driver is missing
using the bluetooth software on your computer, do not tell the computer you are looking for a bluetooth printer, instead, use search for all devices, then the printer will show-up and select it.
printing via bluetooth does not require a driver (it's just like printing from your cellphone)
Dec 27, 2008 | Zebra QL 420 Thermal Label Printer
I can't get my phone to connect with other peoples
I assume you are trying to connect to another phone via Bluetooth. It would help quite a bit to know what kind of phone you are trying to connect to, but here is what you need to have configured on your phone for Bluetooth file transfers:
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer, not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
4. You can now "Copy" media files to the phones nearby that you have connected to. Copy is an option while browsing through the files.
Dec 14, 2007 | Motorola Mobility RAZR V3
Can't connect with other peoples phone
Zebra QL 420 Thermal Label Printer Logo
1,240 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
