Question about Dishwashers
Dishwasher does not fill with water when started. Problem began slowly with dishes not rinsing completely. Overfill float appears to work properly. Water fills pipe leading to fill solenoid but does n
Dishwasher does not fill with water when started. Problem began slowly with dishes not rinsing completely. Overfill float appears to work properly. Water fills pipe leading to fill solenoid but does not fill washer.
  • 1 more comment
  • whalgreen Apr 16, 2009
    I pulled the wiring plug back from the solenoid about an 1/8" to put the probe from my meter to check for power and did not get a reading. I don't know whether this is because I may have pulled the plug out to far or the overfill float switch is defective. There are no exposed points on that switch that I can see to check whether it is working properly.
    As soon as I can get a new fill solenoid, install it, and run the machine I will get back to you with the results.
  • Tim Phipps May 11, 2010
    Do you think that your fill solenoid is the problem?
    It seems like you narrowed it down to that.
  • 234 Answers
I am almost certain that your problem is the fill solenoid.
If it does not work, there will be no water entering your machine.
I would either remove it and test it or just replace it at this point.
Tim
Posted on Apr 16, 2009
  • Roy Tuck May 18, 2013
    Thanks, but what is a "fill solenoid"?
Dishes aren't cleaning. Filling with water, rinsing then draining, refilling with water -- hot, soap released. When dishes come out, barely clean. Used to work like a charm... Thoughts?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 16, 2011 | Miele 23 in. Novotronic G841 Built-In...
Tip
How to troubleshoot your dishwasher
<span>Instructions</span> <ol> Dishwasher Does Not Run <li> <br /> Make sure the power is on, door is latched and controls are set properly.<br /> </li> <li> <br /> Look to see if the door switch, timer or selector switch are defective. Solve this problem by using a screwdriver to adjust the door latch's strike slightly.<br /> </li> <li> <br /> Confirm that the power cord is plugged into the electrical outlet under the sink (if applicable).<br /> </li> Dishwasher Won't Fill <li> <br /> Check your hot water supply stop valve under the sink. Turn it counter clockwise to ensure that it is open.<br /> </li> <li> <br /> Turn off the power and wait for your dishwasher to cool.<br /> </li> <li> <br /> Look inside for a float located at the base of the unit. Lift out the float device and clean around the tube. Rinse off the float and reattach it making sure it moves up and down freely.<br /> </li> Dishwasher Doesn't Drain <li>Remove the air gap cover (short chrome cylinder located at the back of your sink) and clean it using a wire.<br /> </li> <li> <br /> Check the drain hose for kinks and blockages.<br /> </li> <li> <br /> Shut off the power to your dishwasher and remove the strainer located at the base of the cabinet under the bottom spray arm. Scrub it clean then reattach it to the appliance.<br /> </li> Dishwasher Leaves Film on the Dishes <li> <br /> Add a rinse additive to your washing cycle and see if this solves the problem. In addition, do not pre-rinse your dishes prior to placing them into the dishwasher. Food particles allow the detergent and drying agents to work more effectively.<br /> </li> <li> <br /> Listen to the spray arms during a wash cycle. If they appear to be moving too slowly, use a wire to clean out the spray holes.<br /> </li> <li> <br /> Make sure the dishes haven't blocked the detergent dispenser or jammed the spray arms.<br /> </li> Dishwasher Leaks <li> <br /> Cut back on the amount of detergent used during the wash cycle. Sometimes this alone will solve your problem.<br /> </li> <li> <br /> Make sure the appliance is level by adjusting the front feet up or down.<br /> </li> <li><br />Take off the lower front panel and check the hoses for leaks.<br /></li></ol><span><br /><br /><a href="http://www.ehow.com/how_2120626_troubleshoot-dishwashers.html#ixzz18lyYrfk2"><br /></a></span>
on Dec 21, 2010 | Dishwashers
Doesn't seem to rinse completely; soapy film left on dishes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Oct 05, 2009 | Estate 24 in. TUD6700KQ / TUD6700KT /...
Dishwasher slowly fills up with water after wash cycle completed
Inside the bottom of the dishwasher under the lower rack to the side there is a float that regulates water level. jiggle it up and down a few times , it will be OK. Vitally
May 12, 2009 | Dishwashers
Put rinse liquid detergent in dishwasher rinse aid compartment.
I did the same thing with my Maytag dishwasher, several times actually, before realizing I was putting blue dish soap in the rinse aid compartment which then wouldn't empty. Then my Maytag started making ominous noises during the rinse cycle (appliance guy said it was "cavitation" noise).
Appliance guy wanted to replace the whole detergent/rinse aid compartment but since he told me the noise was probably caused by the dish soap stuck in the rinse aid compartment, I decided to try to get rid of it first. Here is the method that worked for me; it took most of a day but saved me parts & labor:
1. Get some white vinegar--I used nearly a quart.
2. Fill the rinse aid compartment to brim with the vinegar (overfill) but don't put cap on
3. Raise the dishwasher door slowly until the vinegar drains into the lower part of the chamber (at least this is how my Maytag worked)
4. Agitate the contents as best you can by rapidly shaking the dishwasher door up & down.
5. I also used a small plastic medicine dropper jammed into small openings on each side of the rinse aid compartment to agitate the vinegar by squeezing air into them.
6. Drain the compartment by closing the dishwasher door (move it to full vertical)--vinegar will drain into the bottom of the dishwasher.
7. Repeat above steps a couple times, then fill again w/vinegar, put the cap on and let it stand for awhile. Then drain and repeat the whole routine several times.
8. Blue-colored vinegar will come out which is a good sign (or whatever color your dish soap was).
9. After awhile, I started pouring generous amts of very hot tap water thru the rinse aid compartment, alternating with white vinegar. (No reason you can't use hot vinegar also.)
10. Eventually, all the blue stuff came out & the see-thru levels of the rinse aid compartment were completely clear/empty.
11. Run the dishwasher (I decided to not put any rinse aid in). I got some overfoaming (from the washed out soap) the first time I ran it which I probably could have remedied by adding more vinegar & possibly salt, but the noises were gone!
I just ran the cleaned out dishwasher a 2nd time & it was back to its quiet self with no overfoaming.
Takes some patience but hey, beats a big repair bill!!
Apr 04, 2009 | Kenmore Dishwashers
Dishes not completely clean or rinsed, and mold
get some dishwasher salts and unscrew the cap at the bottom of the dishwasher empty the filters and run the cycle. fill up the water with dishwasher salts in the white unscrewable cap put about two cup fulls in.there it should work better then. there is also a product called rinse add you can by this from the local supermarket. hope this helps
Mar 27, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher has a overfill problem rinse light flashing
An Idea: the Overflow sensor or float is bad, stuck, disconnected and its messages to STOP filling aren't getting thru to the CPU
This is usually located in the right frony of the machine or in the side wall. Float types get gummed up with 1/2 dissolved soap powder (god what we do tho the water systems) see if it moves. Sensor types have a hole that feels or senses water. If clogged, they lie. Clean out with toothpick and blast with a bit of hot water and air. Retry
If fixed, let me know... if not, see the yellow pages for parts dealers ;-)
Cheers
Mar 26, 2009 | Smeg 24 in. DWD612SS Built-in Dishwasher
"clean" light is blinking
Check the following:
1. Is the overfill protection float able to move up and down
freely? Press down to release.
2. Be sure the water supply is turned on to the dishwasher.
3. Check for suds in the dishwasher. If foam or suds are
detected by the dishwasher sensing system, the
dishwasher may not operate properly or may not fill with
water.
Suds can come from:
1. Using the incorrect type of detergent, such as
laundry detergent, hand soap, or dish detergent for
hand washing dishes.
2. Forgetting to replace the rinse aid dispenser cap
after filling (or refilling) the rinse aid, or spilling rinse aid into the tub (rinse aid causes suds to occur).
3. Using an excessive amount of dishwasher detergent.
Mar 16, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kitchenaid dishwasher (nearly new) does not fill with water
first I would check screen on the water fill valve. make sure it is not plugged.
also check the fill hose make sure the hose is not pinched
check that the water is turned on all the...
this dishwasher is time filled the float is to stop the dishwasher at a overfill problem...
Mar 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
E4 fault code
Hi, when a dishwasher goes into overfill mode it usually means that the bottom tray has water in it that operates a float connected to a microswitch. Open the bottom panel and soak up all water then check to make sure the float is down completely.then restart dishwasher. Why it has overfilled is another problem. It could be a faulty pressure switch,pressure switch hose may have a hole in it, water valve may be faulty. Too much soap or wrong soap can cause too many suds and hence overfill.Also if rinse aid is spilt when filling. Or seals leaking. etc.
Feb 02, 2009 | Dishwashers
Dishwashers Logo
1,851 people viewed this question
Top Dishwashers Experts
