I have zanussi aquacycle fls1183w and it started stopping halfway through cycle light stays on
  • 297 Answers
Has still a conventional timer clock?
Then most probably a piece broke of.
In the old days on those I would open it up see which tooth broke of by revolving the timer and replace carefully with a little screw after carefully drilling into the plastic, obtaining the same heighth. Happily lived 10 years more.
Posted on Apr 16, 2009
Zanussi 1200 aquacycle fx1265w
Either it not getting water, or the motor brushes are worn out.
Sam
Jun 21, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
I have a Zanussi FLS1183W aquacycle 1050 washing machine. It has stopped spinning and I suspect the carbon brushes. How do I access the motor to examine/replace the brushes?
There is no solid base to this washing machine so if you simply lie the machine on its side you can access the motor from underneath.
Jun 01, 2010 | Zanussi Washing Machines
Zanussi Aquacycle 1050. My washing machine seemed to stop spinnin
Locate the filter at the botton front right of washer, behind a drop down cover.
Unscrew anti- clockwise to remove and clean.
If still no go, then you need to check the brushes in the motor.
Hope this helps.
Dec 31, 2009 | Zanussi ZWF1230W Front Load Washer
Zanussi aquacycle 1200 washing machine
The Timer/ECU is likely failed in this instance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 16, 2009 | Washing Machines
Zanussi aquacycle 1200 smells coming from between the drum and casing.Suspect it is caused by a build up of slime etc.
1. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it run for a minute or two, then stop the cycle, open the lid and slowly add the gallon of hot tap water. Don't overfill — you just want to raise the water level so that it is able to reach and clean the inside top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle. In a couple of minutes, stop it again and just let it sit for at least 30 minutes. Afterward, let the cycle finish, and open the lid to air out the inside.
I got it from this link: http://answers.yahoo.com/question/index?qid=20060827101905AANuYg4
and here:
http://deseretnews.com/dn/view/0,1249,600124768,00.html
Jul 02, 2008 | Zanussi FJS1225W Front Load Washer
Obstacle wire stuck in drum (model FLS1183W)
you will have to split the case u will find 6 8mm bolt under the lid remove the 2 rear looking from the front then down the sides u will see 2 round plastic covers remove them by putting a small screw driver in the centre of the lug there r another 8mm bolt in each side use a small screw driver to remove the mains and valve block now the cabinet will split u will need a 10mm socket to remove the heater and a claw hammer to get the heater out of its housing use the claw by caerfully placeing it under the terminal 1side @ a time and the heater will come out u will be able to get the bra wire out from there u may need a set of long nose plyers good luck and make sure u have unplugged the machine b4 u start any dissmanteling
Nov 28, 2006 | Zanussi FS1155W Front Load Washer
Washing Machines Logo
132 people viewed this question
Top Washing Machines Experts
