Question about KitchenAid KGSA906PSS Gas Kitchen Range
KitchenAid oven shut down during self-cleaning
The oven was on self-clean and shut down, display doesn't work and door is locked. The cooktop is still working. I read someone else's same issue posted and problem solvers thought it was the thermal circuit or sensor. Is the circuit the same thing as a sensor? Is this something we can replace ourselves? Is it on the back of the range or inside the oven? How do we unlock the door? Thanks
  • 9 more comments
  • gov worker Nov 19, 2007
    This has happened twice to me. The first time the company paid for the repair. Just this last week when it happened again (2 times tried to self clean; 2 times doesn't work) repairman tells me that KitchenAid now has a "kit" that they sell to fix the problem. Now that it has been repaired though I'm too afraid to try and self clean again.
  • Anonymous Mar 16, 2008
    Mine too has given the "lost communication" message many times. Yesterday was the first time the door locked itself, and I always get the F6 E4 error code too. The first code that comes up is 04 when I power the stove back up, and start over.
    This stove had a "sensor" problem when I bought it used, and it seemed to check out fine when we tested it. The price used was really marked down, and I thought,"What a bargain". Now I'm not so sure. I hope KA has a "kit" to fix the problem. I'll call tomorrow.
  • seanfitz Mar 18, 2008
    I tried to use the self-clean mode today and my oven and display no longer work.
    I've tried resetting breaker and un-plugging the unit but cannot get any positive results.
    The top burner units work, but no display and the oven door is locked.
    Any suggestions
  • Anonymous Nov 26, 2008
    During the self clean cycle the control panel shut off and door locked. Kitchenaid will not admit this is a problem and when I contacted them they suggested I reset my curcuit breaker. Knowing this would not solve the problem I still attempted. Of course my oven is still not working. Should I even attempt to fix it.
  • Anonymous Dec 06, 2008
    me too!
  • Anonymous Jan 14, 2009
    I put my range on self clean and now it is shut off; door is still locked and the stove top elements still work. How do I get it to turn back on?
  • seanmcl280 Jan 16, 2009
    We have a KitchenaidKGSA906PBL. Last week, I tried to use the self clean feature. In the middle of the cleaning, the control panel went blank and the door locked up. This is the fourth time that we have had to replace the control panel. Obviously the oven is a lemon. I'm assuming that when the oven heats up, it fries the circuits. The repairman told us that he gets quite a number of servic calls for our model. Luckily, I sensed the oven was a lemon in the first year of purchase and bought the extended warranty. If Kitchenaid refuses to stand behind their product, they don't deserve to be in business. My solution is to never again buy a Kitchenaid product. I will also tell my friends not to buy Kitchenaid. Eventually, they will be forced out of business.
  • Kowtower Feb 12, 2009
    I've had the same problem with the self-cleaning. If part #9159243 is ordered, is it a fuse within the display module?
  • bericm Mar 07, 2009
    Like others, after self-cleaning cycle display went blank and oven door stayed locked.
  • dre0652 Apr 05, 2009
    After starting the Self Cleaning Mode the Display went blank and the Oven Door stayed locked. The Burner Igniters still work on the Stove Top and I tried resetting the power to the unit but this did not fix the problem. I will try to get the updated kit for repair, part number 9759243 free of charge. Please let me know exactly where the part is located in the oven.
  • spinsaw23 May 11, 2010
    replaced thermal fuse and cant get it to turn off when i run the oven have another fuse but cannot locate it i replaced the one on the back just above the fan in the center?
  • 4 Answers
I've had the same problem and have had the thermo-protector switch replaced four times. After the last time I was so ********** I wrote to the CEO at Whirpool/Kitchen Aid in Benton Harbor, MI with my complaint. Today I received a call from an extremely nice lady in his office who said that they were sending me an updated kit for repair free of charge. The part number is 9759243. She offered that this was a known problem but was limited to just one production run - my luck!
If you are having this problem with your KGSA906PSS write to the CEO at Whirlpool!
Posted on Feb 02, 2009
  • bethdeforest
    bethdeforest Jan 25, 2013
    what was that address please?
    Problem Solver:
  • 4 Answers
If you are still under warranty, and have "lemon laws"... repaired three times in the warranty period for the same problem... they have to replace the stove. We all need to get Kitchenaid to start replacing these ranges over and over, maybe then they will address the issue. Clean, baby clean... you paid extra for a self clean oven, hold Kitchenaid accountable!
Posted on Jan 31, 2008
I've had the same problem and called KA over the weekend requesting part namber 9759243, they sent it free of charge with overnight shipping. My problem now is , how to I install it. The thermal stat looks different than the original one in the oven.
Posted on May 28, 2009
  • 41 Answers
There is a design problem with certain model Whirlpool ranges where the thermal fuse blows during self-cleaning (auto-clean). This may be because of inadequate insulation, causing the outer panel to overheat. When the thermal fuse is replaced, the range will work, but it will blow the next time auto-clean is done. To safely work around the problem, the thermal fuse may be replaced with a thermostat, which will reset itself once the oven has partially cooled off. If the part number of the thermal fuse is 9759243, it will blow at 120 deg C (248 deg F). This can be replaced to a Selco Part# SES-L250 thermostat. The terminals are perpendicular (90 degress), so they have to be bent to 30 degrees for the wires to fit behind the back panel.
Selco part# SES-L250 specs:
Surface Mount
3/4 in. disc
120/240 VAC
25 A
SPDT
open on-rise (normally closed)
open (cut-out): 250 deg F
close (cut-in): 220 deg F
temperature differential: 40 deg F
Info: http://catalog.selcoproducts.com/item/3-4-disc-thermostats/surface-mount-automatic-reset-open-on-rise/pn-5113?&seo=110
Available: Selco distributors: http://www.selcoproducts.com/distributors.php
and online at
Allied Electronics http://www.alliedelec.com
If the Selco SES-L250 'surface mount' thermostat is not available, an 'airstream type' thermostat can be used with a few differences:
1) I recommend to replace it to a 240 or 230 deg F thermostat. The reason for the lower cut-out temperature is that an 'airstream mount' thermostat will not be flush with the back panel, as is the original 250 deg F 'surface mount' one, so it may cut-out at a higher (unsafe) temperature.
2) I recommend to add Heat-sink compound between the thermostat and the sheet metal. This is used for computer processors and is available at computer and electronic component stores.
3) An 'airstream type' thermostat is thicker than the original 'surface mount' one, so longer screws will have to be obtained. The sheet metal tabs on the thermostat will bend slightly when installing.
4) The terminals are perpendicular (90 degress), so they have to be bent to 30 degrees for the wires to fit behind the back panel.
Recommended 'airstream type' thermostats:
Supco L240
Info: http://www.supco.com/images/pdfs/2009%20HVAC%20Caralog/2009%20Catalog%20for%20Web2.pdf
Available: http://www.appliancefactoryparts.com/applianceshvac/supco/crossref/thermostats2.html
Selco SE-L240
Info: http://catalog.selcoproducts.com/item/3-4-disc-thermostats/ts-3-4-disc-se-series-airstream-mount-open-on-rise/pn-5096?&seo=110
White-Rodgers 3L01-230
Info: http://www.white-rodgers.com/wrdhom/pdfs/06_Cat_pages/Cat_06_pg0092.pdf
General Electric LS2-240
Posted on Nov 03, 2009
  • 1 more comment
  • Chris Goulet Nov 08, 2009
    Available: eBay store: Store: Patriot-Supply
  • webjerry Nov 26, 2010
    Would like to know if the oven gas is off when self-Clean killed panel as mine has done. I also has killed panel 3 other times where stop button stopped working.
  • Chris Goulet Nov 26, 2010
    Sorry, I was writing about an electric range, so I'm not sure how to answer your gas question.
SOURCE:
Self oven clean. When we set it to clean and set the time it locks the door, starts for 8seconds and then shuts off and will try to restart 2 more times
Repair - Dead oven after self clean mode, blank display ...
? 9:38
www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen ... How to fix a Kitchenaid
Oct 31, 2015 | Kitchen Ranges
I started a self clean on my oven, and then shut it off, the door opened, now it will not close, seem like the latch is in the lock posistion. help
For an oven self cleaning problem, the first thing to check is the door lock motor and switch assembly. Every self cleaning oven door has a locking mechanism to prevent the door from being opened during the cleaning cycle. An oven self cleaning problem often happens after a clean cycle has been run. If that happens, more often then not the lock assembly will need to be replaced. The door lock motor and switch assembly, over time, fail due to the high temperatures that are encountered during the cleaning cycle.
Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 02, 2013 | KitchenAid KGRI801PBS Gas Kitchen Range
I entered the "quick" option for self-cleaning my
It has a safety that will not allow the door to open while the temperature is high in the oven. oven temps can reach 700 degrees during the self clean cycle. allow the unit to cool completely and see if it works then. if not, let us know.
Nov 20, 2010 | KitchenAid KGSI901PBS Gas Kitchen Range
Oven shur off during self clean cycle
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
May 04, 2010 | KitchenAid KGSA906P Gas Kitchen Range
Whirlpool Oven Died During Cleaning Cycle No Display Now Locked
Had same problem with my KitchenAid. 10 years old. Ran self cleaning cycle, oven died!!!! Called repair. Appears to be thermal fuse. Part on order. Microcomputer had some brown spots on it. Tey wanted us to replace it too. But will wait to see if fuse is problem. Repair - $150 vs. $570. If it's the higher price, we'll buy a new oven before putting that kind of money into it. Will NEVER run a clean cycle again even if I have to buy a new oven.
Jul 16, 2009 | Whirlpool RBS275PD Electric Single Oven
Oven shut down
IT IS THERMOSTAT IN BACK PANEL ABOUT A 48.00 PIECETWO CLIP WIRES AND TWO SCREWS IT IS NOT IN TOP OF STOVE IT IS IN FLAT ACCESS PANEL BELOW
Sep 21, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Oven shut down
Please call directly to KitchenAid/Whirpool and speak to the 'executive management team' - when I spoke to them they said this wasnt a common problem, they were not aware of the fault.. EVERYONE with this fault please call again.
Replacing the fuse each or not using the self clean function is not a fix!
Jul 20, 2008 | KitchenAid KGSA906PSS Gas Kitchen Range
Kitchenaid kgri801pbs
there is a thermal fuse in the back of the oven that more than likely has tripped during self clean poor air flow around can cause this power surges during self clean can too you have to pull the oven out and remove back panel to find it
Jan 10, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
Kitchen aid model# kgri801pbs
On most models, the door stays locked during a self clean, until the temperature returns to normal for safety reasons.
It sounds like your unit may have tripped a breaker during this self clean event. Check your panel for a tripped breaker. If the oven has cooled down, and the lock is still engaged, then we may have a different problem.
Let me know what you find out!
KitchenAid KGSA906PSS Gas Kitchen Range Logo
6,807 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
