I am getting the error message from the Pixma ip4300 paper jam despite the fact the paper has been cleared. I have restarted the printer and the computer repeatedly to no avial.
  • stephanib Apr 16, 2009
    I do not see the metal bar between the top panel and the lower panel. I am looking for this in order to take the top off.
    Are you saying that I have bent the pin, if I did pull the paper out through the paper feed?
  • stephanib Apr 30, 2009
    I am not able to see the metal bar that you refgered to in your first solution. Could you describe it better so that I can take the lid off the ip4300 canon printer
  • 3,866 Answers
There is a snsor inside that is malufucntioning because of the jamed paper, the way it was removed, thus the sensor needs to be replaced, thus you geting this error
Rulds2008
GURU
Posted on Apr 30, 2009
    Brigadier General:
  • 3,614 Answers
Paper can jam inside the printer for a number of reasons. Open the cover to the printer and look inside to see if there are any pieces of paper or debris that may be blocking the print path. Be sure to unplug the printer before touching anything internal to avoid electric shock. If there is something blocking the print path, remove it, close the printer, and try printing again. You can also check inside the printer to see if any components have come loose.
  • 226 Answers
Did you pull the jammed paper backward to remove it? I'm afraid you've bent the paper sensor lever. seen one exactly same situation done by a customer
afraid it's not easy to get to the sensor lever, so......you decide if it's worth sending it for repair.
You might be able to bend the sensor lever back enough to get it going without actually pulling apart the paper feed assembly from the machine.
if you turn the machine around to face it's back and then look into the paper feed tray. the sensor is down the left side passed the roller, but before it gets to those tiny "rolling pins" on the inside of the machine. it's located between the first and the second rolling pins.
to even see it you need to remove the cover around it.
the trickiest part is at the front where you lift the top panel up. you'll see a connecting metal bar between the top panel and the bottom panel. you need to disconnect this bar first in order to remove the cover.
once you get the cover's off, just use a spring hook and a flat head screw driver, one in each hand, to straighten the black sensor lever through the gaps. the proper way is of course to remove the paper feed assembly from the machine. but this is tricky.
the sensor lever should be mounted on a bracket and "swinging" freely. at normal position the top bit, which is flat, should be blocking the center of the u-shape optical sensor mounted next to it.
when paper passes through it, the lever is pushed at the bottom end so that the top flat end moves out of the sensor so that it can see light shining through it. if this is the current position, the printer is going to think that there's a paper jam and hence keep trying to push the paper out. after numerous turn if the sensor still see red it then stop finally and give you a paper jam error.
and i presumed this is the problem you're having ?
the case that I've seen was that the bottom bit of the sensor lever, which should be straight, has been bent backward about 90 degrees and it's sitting on top of the bottom frame. this causes the lever to be permanently "open" at the top end.
BTW is the lever dislodged from the mounting, or worst, has broken hinges?
that sensor lever has to be in faulty condition for the machine to behave the way you described it,especially you said it happened after a paper jam.....unless....it jammed in the first place because the sensor itself or the control board has gone south? not very likely though :)
Hope this helps and thank you for choosing FIXYA
Posted on Apr 16, 2009
Error 1250 on PIXMA ip4300 printer. Despite open tray messae will not o away or allow printing to start.
the error message means there is something wrong with the printer and if the problem is not attended to, the error message will not go away.
In this case, the error message showing on your canon ip4300 is related to a door problem. It has something to do with the front door of your printer. I think the front door of your printer is closed of which is supposed to be opened.
So, the solution is to Open the paper output tray of your printer and the problem should be solved.
Good luck.
May 24, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Erro 6A00
The 6A00 is a Canon code for paper path jam. In the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 .
The purge unit is stuck and not able to move freely .Move the purge unit back and forth for around 10 times and then restart printer ,it should work fine .
If you still get the error code then purge unit needs replacement.
Hope this helps .
Mar 27, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Cannon Ip4300 - Orange light flashes on printer.
A possible paper jam has happen on the unit. Did you have an paper jam error before you have this problem?
You must clear any paper jam on the unit, check the unit for any stuck paper or object or check if there was misaligned parts inside.
Let me know for any clarifications.
Thank you for using fixya.
micro-
Dec 12, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon ip4300 Error code 1300
u have to reset ur printer try to hold ur finger on power button for more than 15 sec then turn it on again
Jun 09, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
There's a small white light below the power light that's flashin.
In this case you may have to clear the memory of the printer or set the printer to default.
May 07, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
"Paper Output Slot Jammed" Canon Pixma iP4300
These printers are FULL of very sensitive sensors, and chances are that one of them may have a small piece of paper blocking them. If you can get the covers off by finding the "Triangle" arrow markers, you can inspect all these sensors.
Good luck!!!
Mar 12, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Paper jam
After assisting the card through the printer I opened the cover for another inspection, the card had dislodged a twist-tie which had somehow fallen into the printer
Aug 26, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Hp all-in-one ->Paper Jam: Clear jam, and then press OK error message
it may have more to do with the type of paper and your canon printer. did you check to see that the paper is compatible with the printer specifications?
Apr 22, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Error Code B200 on Canon Pixma IP4300
Just restart the system and turn off the printer and turn on the printer it will work.
Check did you correctly placed your cartidges.
Mar 03, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
52 people viewed this question
jasbo
jasbo
